Raleigh North Carolina and surrounding areas
Discussion in 'South East' started by Sandman614, Aug 22, 2013.
  1. Sep 14, 2016 at 3:49 PM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  2. Sep 14, 2016 at 4:01 PM
    voz
    voz Nothing Witty To Say
    VOZ
    VOZLAND
    The Clean One
    In Progress, Progressively
  3. Sep 14, 2016 at 7:51 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Blkvoodoo likes this.
  4. Sep 14, 2016 at 8:21 PM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    Would need a potentiometer with dual, possibly triple sweep, one increasing resistance the other decreasing resistance in the sweep at equal rates in the OHM range the ECM is looking for.
    Possibly adding a second pedal assembly that can be locked in certain position but is hand operable could be piggy backed into the system.
    I like how GM did it with the cruise control functions. That feature is (or was) actually in most GM truck ECMs just need to find the pins to energize it in the ECM connector ( they're empty locations in most trucks)
    only downfall is it has to see parking brake signal to be able to activate ( this is idle up for PTO operation, which generally doesn't get used with vehicle in motion. )
  5. Sep 14, 2016 at 8:34 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Heck even a set pair of resistors and a switch to bump it up 500-1000 rpm. Would work across all pedal positions.
  6. Sep 15, 2016 at 4:52 AM
    nastyneight
    nastyneight Well-Known Member
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    Go old school and do hand throttle
  7. Sep 15, 2016 at 6:02 AM
    Scenekyd
    Scenekyd Not much of a member
    Jay
    Hendersonville, NC
    2015 Ford F-250, 2016 4runner Trail
    Going to pick up a load to drove off in Apex :spy:
  8. Sep 15, 2016 at 6:05 AM
    mrbedgood
    mrbedgood Isaiah 6:8
    North Carolina
    '11 MGM DCSB TRD Off Road 4x4
    Total Chaos +2" Long Travel Kit; King/TC 2.5 LT C/O w/ 16"x600; TC/CVJ Extended Axles; TC Spindle Gussets; King 2.5 RR shocks; All-Pro Expendition Leaf Pack; Pelfreybilt Sliders; Anti-Dark LED Hood Light mod; LED map and dome light mod; Bed lights; TRD Cold Air Intake; KB Voodoo Tailgate cap system; HomerTaco Thin Lip "Raptor" grille; sPod SE System w/ LCD Touchscreen; Baja Design OnX6 40"; Baja Design S2; Rigid Industries LED Rock Lights; Front Runner Slimline II Roof Rack; A.R.E. Z Series Camper Shell Projector BHLM Headlights (with custom wiring); Method Racing NVs 17"x 8.5; and Nitto Terra Grappers 265/60/17
    Chillin at Toyota of Apex
  9. Sep 15, 2016 at 6:56 AM
    voz
    VOZ
    VOZLAND
    The Clean One
    Why
  10. Sep 15, 2016 at 7:04 AM
    mrbedgood
    North Carolina
    Oil change. Didn't feel like doing it. Haha
    voz[QUOTED] likes this.
  11. Sep 15, 2016 at 7:07 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Gonna have time to hang around?
  12. Sep 15, 2016 at 7:08 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    showroom truck :D They just borrow it and park it inside to make people want to buy Tacomas.
    Scenekyd and voz[QUOTED] like this.
  13. Sep 15, 2016 at 7:09 AM
    Sandman614
    Tim
    '06 SR5 Off Road
  14. Sep 15, 2016 at 7:12 AM
    mrbedgood
    North Carolina
    lol I wish
    scottalot likes this.
  15. Sep 15, 2016 at 7:17 AM
    mrbedgood
    North Carolina
    lol I'm a Carolinian stays with both
    scottalot[QUOTED] likes this.
  16. Sep 15, 2016 at 7:18 AM
    voz
    VOZ
    VOZLAND
    The Clean One
  17. Sep 15, 2016 at 7:20 AM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
  18. Sep 15, 2016 at 7:30 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    But if you do use it it'll be worth it. Do it, may get a t-shirt too.
  19. Sep 15, 2016 at 8:23 AM
    Blkvoodoo
    Kevin
    Near Clayton NC
    That's the problem, how do you connect the hand throttle to an electronic throttle ? And not cause other issues ?
    That might work, but you would need to lock out foot feed when you do this or it sends errant signals that would confuse ECM and cause it to code. Need some parts to experiment with. I've got a couple throttle pots from fork lifts, if the ohm range is similar to foot pedal on truck it would be easy enough to make a friction adjustable remote box. Would probably still need to be a one or the other thing
    voz likes this.
  20. Sep 15, 2016 at 8:23 AM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    Thats what i say about my stash of vampire spikes
