Raleigh North Carolina and surrounding areas
Discussion in 'South East' started by Sandman614, Aug 22, 2013.
  1. Apr 29, 2017 at 4:59 PM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    You in? Bring the miata ?
  2. Apr 29, 2017 at 5:36 PM
    nastyneight
    nastyneight Well-Known Member
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    My goal will to be drop off at the alignment shop Tuesday, have my new Cam bolts installed and alignment installed, and then after that install test pipe and new exhaust
  3. Apr 29, 2017 at 5:37 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Don't need alignment or exhaust at URE.
  4. Apr 29, 2017 at 5:50 PM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    Do to drive it there
  5. Apr 29, 2017 at 6:44 PM
    RaleighTaco
    RaleighTaco Well-Known Member
    Jonathon
    Raleigh NC
    '97 Toyota 4runner
    Motorswap and fermental? Does that go in the same sentence for a weekend down there? :anonymous:
    nastyneight[QUOTED] likes this.
  6. Apr 29, 2017 at 6:49 PM
    RaleighTaco
    Jonathon
    Raleigh NC
    '97 Toyota 4runner
    Changed that.....
    Fixed all problems!! Appreciate it! Haha
    nastyneight likes this.
  7. Apr 29, 2017 at 6:51 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    URE tomorrow then.
  8. Apr 29, 2017 at 6:59 PM
    RaleighTaco
    Jonathon
    Raleigh NC
    '97 Toyota 4runner
    Haha no.
    Just left the wedding....slightly intoxicated. Luckily the wedding was right across the street so we just drove the golf cart home!
    In other news....I'm obviously not getting notifications of being taged or replied to
  9. Apr 29, 2017 at 7:00 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    check yo settings
  10. Apr 29, 2017 at 7:01 PM
    RaleighTaco
    Jonathon
    Raleigh NC
    '97 Toyota 4runner
    To drunk...reminds me tomorrow haha
    I've got these two alerts but not any from replies yesterday....of tapatalk how I miss you
    Dragons Taco likes this.
  11. Apr 29, 2017 at 7:02 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    The only reason I miss it
  12. Apr 29, 2017 at 7:07 PM
    RaleighTaco
    Jonathon
    Raleigh NC
    '97 Toyota 4runner
    In other other news looks like we found a few other t4r owners with the same issue I have going on that points to fuel pressure/faulty fuel pump issue. First codes I got on my previous 4runner were fuel sytem lean codes after a few months of dealing with the same issue. Then head gasket went.
    History says running lean can cause head gasket failure so maybe we have caught it early enough? @Blkvoodoo thoughts?
  13. Apr 29, 2017 at 7:47 PM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    that was discussed on the first 4Runner event, i said it sounded like it was running lean ( by description of codes and events) My thoughts on the final after seeing the plug that was pulled, it leaned out one cylinder enough to burn a valve (which caused the plug to coke) The resulting dead cylinder pushed an already aged and weak head gasket.
    check fuel pressure, replace fuel filter, check/repair the corroded wiring to fuel pump, at this point, it wouldn't be a bad idea to replace the fuel pump as you know its probably original ( Denso fuel pump @ Adavnce $116, less with online coupon) FYI, you can get a whole fuel tank, sending unit and pump in one assembly for $300 from RockAuto, this may be an option if rust is enough of an issue to get yours apart. My only thing is it is not a Denso fuel pump.
    compression check isn't a bad idea, it will give you and idea of where it might be. But actually pulling the heads and just doing the job may be your best bet. Sure, you can get any number if replacement engines, but you're still gambling on old worn gaskets and unknown service history (where you're at now) its a 20year old truck that at best you might find a low mileage engine that comes out of an '04 Tacoma IF the newest version is a direct swap. still gonna be a 14yo engine. Reman engines are a gamble as well.
    Yours runs but you have no idea what condition its in as you know it isn't the original to the truck, so actual miles and history are unknown
    Also, other head gasket failure causes are plugged catalytic converters and collapsed mufflers (one of the problems i had)
    i've been looking into doing fuel pump on my own junk as a preventive measure, mine has 225k on it, and my sending unit is FUBAR too, may as well do both while i'm in there.
  14. Apr 30, 2017 at 7:38 AM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    I had a set of General's on the company truck. I found that they really performed well but they seemed to wear quickly. I got about 45k on them before swapping out.
    For the right price I'd buy them again. Sounds like you are reading a lot, and that's a good thing. Most of our wisdom has come from forums like these or school of hard knocks.
    Except for @Blkvoodoo who was blessed with wisdom from the oracle on top of Mount Okuhutaka.
    voz likes this.
  15. Apr 30, 2017 at 7:45 AM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    WE started to take apart Mel's suspension since her brakes were failing. Turns out nearly every piece of rubber needs to be replaced. Calipers seized, bellows vulcanized, boots crumbling. As a result of red-neck tow on a rope and a scared teenager riding the brakes for 15 miles.
    Had to go to Raleigh for rebuild kits, that turned out to be totally wrong.
    We are going to Greensboro today to catch Bec's concert (she sings for a gossip group) Autozone in Greensboro claims to have the right parts, otherwise we are back to 2 vehicles next week.
    Always something... you keep pitching mod days, and I swear some day I will swing and not miss.
  16. Apr 30, 2017 at 7:46 AM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    Thank You Sir!!!
  17. Apr 30, 2017 at 7:48 AM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    Sheesh, that's the second time. Maybe we need to try to harden that sucka, get it red hot and throw it in the lake?
  18. Apr 30, 2017 at 7:56 AM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    logo_94bfd34cdc2ccf8813d067cc1b9e798e8ef00656.png I know!!!!!!!!!!! so sad. Web site works great on the PC, but my old eyes have trouble even clicking on things on the phone.
    Tapatalk going away set me into a TW downward depression spiral where I was lost for nearly a year. Slowly gaining traction once again.
  19. Apr 30, 2017 at 1:38 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Haha I just need to stop taking @Acerwin lines lol.
  20. Apr 30, 2017 at 1:40 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Nice day at URE for a shakedown run and Pik-n-Pig in Carthage on the way home!
    JimboAnz, voz, mrbedgood and 2 others like this.
