Raleigh North Carolina and surrounding areas
Discussion in 'South East' started by Sandman614, Aug 22, 2013.
  1. May 31, 2017 at 10:12 AM
    cbannister83
    cbannister83 I'm a d**che
    43S GT 59500 92000 ish
    DCSB
    Loading...
    None, rides good so far. Loud though, might see if some lithium grease on the front bushings will fix it.
    Sure did, no issues.
    nastyneight[QUOTED] likes this.
  2. May 31, 2017 at 10:14 AM
    cbannister83
    DCSB
    Loading...
    Good the truck rides smooth. Haven't hooked up the boat or anything and they are pretty "squeeky" otherwise they ride nice. Thanks
  3. May 31, 2017 at 10:21 AM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    no grease, wipe em off, and retorque
  4. May 31, 2017 at 10:23 AM
    cbannister83
    DCSB
    Loading...
    I didn't put grease on them and they are torqued to spec.
  5. May 31, 2017 at 10:25 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    What are we talking about :sandwich::burp:
  6. May 31, 2017 at 10:29 AM
    tacopaulo
    tacopaulo Tanned
    Paulo
    Raleigh, NC
    red truck
    Anybody got an extra one I could use for ure
    uh_salt_rifle, voz, JimboAnz and 2 others like this.
  7. May 31, 2017 at 10:32 AM
    cbannister83
    DCSB
    Loading...
    leaf springs
  8. May 31, 2017 at 10:33 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Thought so, which ones, which eye bushings, where's the squeak coming from?
  9. May 31, 2017 at 10:36 AM
    cbannister83
    DCSB
    Loading...
    I think its the front bushings on both of the springs.
  10. May 31, 2017 at 10:40 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Those factory style front bushings suck.. You want some more? I'm gonna bet you also torqued them while in the air, at navins shop? Loosen them both, cycle suspension (jump up/down on bumper), does it squeak?, retorque on ground.
    Blkvoodoo likes this.
  11. May 31, 2017 at 10:42 AM
    nastyneight
    nastyneight Well-Known Member
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    Man that @mrbedgood selling some shady stuff
    Dragons Taco, voz and Sandman614[OP] like this.
  12. May 31, 2017 at 10:45 AM
    cbannister83
    DCSB
    Loading...
    No, not those. They are all pro leafs. I also had new bushings. As I understand it, it sorta comes with the Leafs.
    Torqued them after it was off the lift. So what was the bet?
  13. May 31, 2017 at 10:45 AM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    explain why you say this, most all high end bushings need grease when installing (or is it a difference from rubber to poly, delrin)
  14. May 31, 2017 at 10:47 AM
    mrbedgood
    mrbedgood Isaiah 6:8
    North Carolina
    '11 MGM DCSB TRD Off Road 4x4
    Total Chaos +2" Long Travel Kit; King/TC 2.5 LT C/O w/ 16"x600; TC/CVJ Extended Axles; TC Spindle Gussets; King 2.5 RR shocks; All-Pro Expendition Leaf Pack; Pelfreybilt Sliders; Anti-Dark LED Hood Light mod; LED map and dome light mod; Bed lights; TRD Cold Air Intake; KB Voodoo Tailgate cap system; HomerTaco Thin Lip "Raptor" grille; sPod SE System w/ LCD Touchscreen; Baja Design OnX6 40"; Baja Design S2; Rigid Industries LED Rock Lights; Front Runner Slimline II Roof Rack; A.R.E. Z Series Camper Shell Projector BHLM Headlights (with custom wiring); Method Racing NVs 17"x 8.5; and Nitto Terra Grappers 265/60/17
    They don't have friction pads that's why. They were squeaky with me, but I can't hear either.
    Shut up. You got a good kit too there bro
    cbannister83[QUOTED] likes this.
  15. May 31, 2017 at 10:47 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    You won them old crusty factory bushings.
    Probing for info, stock bushing(rubber) no grease, Certain areas poly bushings also no grease. If the bushings come with grease use it.
  16. May 31, 2017 at 10:47 AM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    Ah that squeak, piece of bike tire tube will fix that
  17. May 31, 2017 at 10:48 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    see that's different, not coming from bushing. I just need more info to provide correct info.
  18. May 31, 2017 at 10:49 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    My gently used set of Allpro Expos (advertised as "wheeled hard" :rofl: ) squeak like a pack of baby pigs. have since I got them. I should update the bushings some day
  19. May 31, 2017 at 10:49 AM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    More just wondering question, when i replaced every single rubber bushing with poly on the Miata i had to drill every suspension piece and install zerk fittings, to regease every year
  20. May 31, 2017 at 10:51 AM
    cbannister83
    DCSB
    Loading...
