Raleigh North Carolina and surrounding areas
Discussion in 'South East' started by Sandman614, Aug 22, 2013.
  1. Jun 6, 2017 at 3:55 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    yup
  2. Jun 6, 2017 at 4:14 AM
    Dangerdave
    Dangerdave Official TW jeep representative
    David
    Wilmington, NC
    20 F150
    Headed back to Asheville tomorrow. Anyone need anything from the western part of the state? Keeping in mind I'll be in a Mini Cooper.
    Dragons Taco likes this.
  3. Jun 6, 2017 at 6:05 AM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    Does there have to be more? Sheesh look at my pic. I don't have much brown in my beard left.
  4. Jun 6, 2017 at 6:10 AM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    TW Mini Express.
  5. Jun 6, 2017 at 6:12 AM
    Dangerdave
    David
    Wilmington, NC
    20 F150
    TW Express Lite haha
  6. Jun 6, 2017 at 6:13 AM
    VA SOFTACO
    VA SOFTACO ...because who buys hard tacos
    Beauregard
    Virginia Beach, VA
    2015 Tacoma MGM OR DCSB
    You should be able to fit a swing gate high clearance rear bumper on the roof
    voz likes this.
  7. Jun 6, 2017 at 6:14 AM
    Dangerdave
    David
    Wilmington, NC
    20 F150
    I can ratchet strap it through the sunroof opening.
    Don't underestimate the power and ingenuity of a determined redneck hahaha
    Smiley52, VA SOFTACO[QUOTED] and voz like this.
  8. Jun 6, 2017 at 6:18 AM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  9. Jun 6, 2017 at 8:18 AM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    Yow! someone has one for sale?
  10. Jun 6, 2017 at 8:19 AM
    andrewb
    andrewb Well-Known Member
    NC
    2015 Tacoma
    General mechanics question: my boat has a mercruiser 4.3 v6, which is just the marine version of the chevy 4.3 v6 they've used for years. About three or four times now since April we've gone to start the boat and nothing happens, still have power because I can operate anything else electrical, up until the other day it's only done it after you shut it down and try to restart within a short time period(1-3min).
    After you let it rest a few minutes it would start right up, just like normal. Went down the other day to take it out and it didn't do anything on the first start of the day. Didn't have any tools with me, so I would just try cranking it every little bit hoping it it was the starter that I'd eventually find a good spot, I wasn't able to get it to crank the other day. Went out this morning with tools, turned the key, just to make sure I wasn't trying to troubleshoot something that was working, and it cranked first turn.
    So, I'm keeping tools on the boat and going back out this afternoon to see if it'll not crank and allow me to troubleshoot. But, before it cranked for me this morning I had it narrowed down to starter solenoid, starter slave solenoid, of the starter itself. With this problem being so inconsistent, I'm thinking that it is the starter. Just wanted to hear some opinions before I take it off the boat and to the parts store to test it.
  11. Jun 6, 2017 at 8:24 AM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    In my opinion, it could be any of those three. Temperature, amount of gook in the solenoid(s), starter brushes at the end of their life, starter brushes housing could have gook in them and are preventing the brush to have a good contact.
    My alternator stopped working after one too many mud baths. I took it apart and found the brushes stuck in the housings and arc'd material away until the alternator stopped working. Cleaned out the brush housings and brushes and stuffed it all together again. Atleast 15k miles ago.
    andrewb[QUOTED] likes this.
  12. Jun 6, 2017 at 8:27 AM
    VA SOFTACO
    Beauregard
    Virginia Beach, VA
    No I just wanted to see how TW express the Mini would be. Was expecting to only fit maybe a pair of shocks or box of Snickers. :rofl:
  13. Jun 6, 2017 at 11:16 AM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    Starter is a good possibility especially if it is a permenant magnet type, they don't like wet environments (been thru several on ice resurfacing machines )
    Boats are also known for ground issues, make good sealed cables from battery to engine block, and battery to main ground source in boat.
    Dunno how many times ive seen where you bump the negative cable on battery or block and the machine will start right up
  14. Jun 6, 2017 at 12:30 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    It's Tuesday and I need some Tacos. Who's down for a Taco :taco: Taco meet up tonight?
    Dragons Taco and voz like this.
  15. Jun 6, 2017 at 1:37 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    voz and Dragons Taco like this.
  16. Jun 6, 2017 at 2:23 PM
    cbannister83
    cbannister83 I'm a d**che
    43S GT 59500 92000 ish
    DCSB
    Loading...
    I'm not a mechanic, but I'd agree with @Blkvoodoo and say it sounds like the connection is loose or the ground needs to be played with.
  17. Jun 6, 2017 at 2:35 PM
    Blkvoodoo
    Kevin
    Near Clayton NC
    To look at the ends of either of those cables you would say there isn't anything wrong with them.
    Closer inspection and you see the tarnished copper leading into the crimped ends.
    BIG TIME resistance, took me awhile to figure it out. New starter didn't fix the problem, new relay didn't fix the problem,
    the cable with eyelets is what was the problem, even the dirty ground terminal was working well once I replaced the other cable. Was from chassis to starter lug on trans mission. The other is from battery to chassis.
    The environment the machine is in wouldn't lend me to think that oxidation or corrosion would be an issue.
    Machine is 11years old
    cbannister83 likes this.
  18. Jun 6, 2017 at 3:51 PM
    andrewb
    NC
    2015 Tacoma
    Starting to think you're right with this one. We went out tonight, started up perfectly everytime. Loaded up to head home and as soon as the bow came up engine died. Started right back up and scooted us home just fine. Back on the lift I pulled the battery cover and the nut holding everything on the post was half to three quarters a turn loose. Going back Friday or Saturday to check and clean the rest of my grounds. But it wouldn't surprise me if that was it. Hopefully that was it anyways.
  19. Jun 6, 2017 at 4:55 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    T4RH33L, Taco_life, JimboAnz and 3 others like this.
  20. Jun 6, 2017 at 6:50 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
