Raleigh North Carolina and surrounding areas
Discussion in 'South East' started by Sandman614, Aug 22, 2013.
  1. Jun 25, 2017 at 9:19 AM
    mlevinson
    mlevinson Well-Known Member
    Raleigh, NC
    2017 TRD Off-Road
    Maybe I'll just go to TSA and kill some paper. :)
  2. Jun 25, 2017 at 12:07 PM
    T4RH33L
    T4RH33L Helping to find Jimmy since 2017
    Al
    Raleigh, NC
    2013 MGM DCSB TRD OR
    5100s with Eibach coils and zombie Dakars.
    Damn, I wish I saw this earlier. I've been reorganizing my garage. Really could have used some help.
    Dragons Taco likes this.
  3. Jun 25, 2017 at 1:22 PM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    shoulda said something, drove by Sauls twice this morning to and from Fuquay, emergency service call ($$$)
  4. Jun 25, 2017 at 3:20 PM
    diverdale
    diverdale #sosconceptscrew
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Fox 2.5 Coilovers, Fox 2.0 Rear Resi, Icon 3 Leaf AAL
    I was towing my camper down the mountain from Boone today. All was fine ( I thought ) I have a break booster for the camper and whatnot. Thought I had it adjusted adequately. After a bit the steering wheel started shimmying like an epileptic. Pulled over and the front brakes were smoking and smelled. Sat for a bit and upped the brake booster voltage and all was fine the rest of the way home. No more shimmy. Is that normal? I didn't feel anything in the pedal just the steering wheel. I thought a front wheel was gonna fly off. First time I've had the new camper in the highlands. It weighs around 3500lbs so I'm well under the weight limit ( including all the gear and people )
  5. Jun 25, 2017 at 3:31 PM
    Blkvoodoo
    Kevin
    Near Clayton NC
    maybe use trans to help with braking as well, down shift to lower gear. might also adjust rears on truck ( use parking brake a few times occasionally as well) and adjust camper brakes as well
    The "Boost" function on the controller essentially bumps the voltage to the magnet to get it to grab harder, effectively its pushing the shoes harder, but if they're out of adjustment, they act "normal"
    I've got same setup on my camper and controller, you should be on the verge of lock up when you actuate the brakes manually from the controller, you should feel the brakes grab the truck and slow it down on coast no throttle. i've adjusted brakes on my camper once, i need to do it again soon.
  6. Jun 25, 2017 at 3:35 PM
    diverdale
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Yeah... that's what I thought. After bumped up from around 9v to 10 it made a difference. I meant to bump it up before leaving for home but forgot. I was more interested in the steering wheel wobble. Thanks for the speedy responce Kevin.
  7. Jun 25, 2017 at 3:49 PM
    Blkvoodoo
    Kevin
    Near Clayton NC
    pretty certain the rotors where overheated, may wanna check them for bluing and or cracking, they'll expand enough to warp a bit and cause shimmy add to the the gas build up between pad and rotor, you probably weren't far from a really bad time. all that heat and minimal lube in the hub bearings probably didn't make them happy either.
    If you never have, now might be a good time to also bleed the brakes with fresh fluid, it may not look bad, brake fluid absorbs moisture from the air over time, and will lower the boiling point of the brake fluid as a result. I'm just as guilty of not doing this service on my junk on a regular basis.
    My '85 Runner boiled fluid and faded the brakes once, it had solid unvented rotors, i was on a road up near Crabtree Falls, it got to the point i was really considering rubbing the guardrail to scrub speed, it probably would have got ugly from there, road leveled out enough i could slow down with gearing. Was loaded with camping gear and tools, would have been quite the yard sale !
  8. Jun 25, 2017 at 4:52 PM
    nastyneight
    nastyneight Well-Known Member
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    My buddy just sent me this pic, he is visiting his wife's relatives those trucks look oddly fimiliar
  9. Jun 25, 2017 at 5:11 PM
    Dangerdave
    Dangerdave Official TW jeep representative
    David
    Wilmington, NC
    20 F150
  10. Jun 25, 2017 at 6:10 PM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    @SGTCap and @ahspurlock
    JimboAnz and ahspurlock like this.
  11. Jun 25, 2017 at 6:26 PM
    Dangerdave
    David
    Wilmington, NC
    20 F150
    I seent the cap in the Asheville one time. Hims got a purdy truck
  12. Jun 26, 2017 at 12:21 AM
    bdbrown528
    bdbrown528 Well-Known Member
    Ben
    Anchorage, AK
    2023 TRD OR LR 6MT
    Pretty productive day before heading up the mountain to Boone.
  13. Jun 26, 2017 at 3:24 AM
    ahspurlock
    ahspurlock The TW Mechanic
    Adam
    summerville.south Carolina
    08 T4R V8 Limited AWD on 37s
    Rear full long travel including upper and lower rear control arms. 37s Mickey Thompson Baja boss MT,
    Hey I know that house and those trucks
    nastyneight[QUOTED] likes this.
  14. Jun 26, 2017 at 3:25 AM
    ahspurlock
    Adam
    nastyneight likes this.
  15. Jun 26, 2017 at 3:49 AM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    all right everyone need opinions, going to order some 315/70/17's this week, what tires are peeps liking. Im looking at Nitto Trail grapplers, goodyear duratrac, and cooper stt pro anyone have and other good options
    ahspurlock and JimboAnz like this.
  16. Jun 26, 2017 at 3:59 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    I liked my duratracs I had in 265/75/16. great wear. very balance happy though. (every 5 K or more) cooper STT pro look mean, I like those. @RadTaco914 has STT pros on his ride
  17. Jun 26, 2017 at 4:11 AM
    ahspurlock
    Adam
  18. Jun 26, 2017 at 4:12 AM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    I've got the STT Pro's. They look bad ass, and performed pretty well on the trail. Plenty of claims that they are quieter than other MT's but I wouldn't purchase them again with that as a reason.
    The 285 STTPros are plenty louder than my 255 KM's. Apples and oranges I know, but it's what I have to compare.
    Was stuck in some pretty good rain storms this weekend on my way to SC through Columbia and never felt insecure. If going for an MT I'd get them again.
    JimboAnz[QUOTED] and ahspurlock like this.
  19. Jun 26, 2017 at 4:13 AM
    ahspurlock
    Adam
    these are what I'm running . Handle very nicely and are quiet on the street. 35-1250-17
  20. Jun 26, 2017 at 4:14 AM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    Huh. you associate with those guys now? Huh.
    :crapstorm:
    ahspurlock likes this.
