Raleigh North Carolina and surrounding areas
Discussion in 'South East' started by Sandman614, Aug 22, 2013.
  1. Jul 20, 2017 at 8:22 PM
    Zwjense
    Zwjense Well-Known Member
    Ok yeah, that makes sense. Thanks for the link.
  2. Jul 20, 2017 at 8:25 PM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    A slight increase in tire size CAN help mileage, in my case 245/75R16 and 4.10 gears suffer greatly as to maintain 65mph i'm turning 2900rpm if i go to a 285/75r16 i'll drop a couple hundred rpm which uses less gas, there is a crossover where things start going down
    Zwjense likes this.
  3. Jul 20, 2017 at 8:26 PM
    Blkvoodoo
    Kevin
    Near Clayton NC
    i picked those numbers as i didn't know what his were, it all works the same though
    Zwjense likes this.
  4. Jul 20, 2017 at 8:35 PM
    Zwjense
    Very helpful, thanks. Definitely making sense now. I wasn't thinking about it at that level before, I guess.
  5. Jul 21, 2017 at 2:51 AM
    nastyneight
    nastyneight Well-Known Member
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    Quite a bit. Funny how forgetting to put a space in Master Ace can make it sound so much worse
    Dragons Taco[QUOTED] likes this.
  6. Jul 21, 2017 at 2:54 AM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    My truck about six off with 4:88 of doing 70 on speedo my speed app says 76-77
    Zwjense likes this.
  7. Jul 21, 2017 at 5:33 AM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    I "know" this, but I still manage to get a wave of depression when I fill up and calc my MPG's.
    I was thinking about creating a speedometer compensation device with an Arduino. Do you think that it should be done at the Speedo, or would their be benefits to correcting it before the ECU?
  8. Jul 21, 2017 at 5:37 AM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    I have about the same difference with stock gears, but I've only got 285/70/17's. Tires are gear ratios too.
    If you are 8% off then you miss out on 8% more miles on the Odo.
    Zwjense[QUOTED] likes this.
  9. Jul 21, 2017 at 5:38 AM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    Great explanation, I didn't refresh my page and missed it the first time.
    :pccoffee:
  10. Jul 21, 2017 at 5:46 AM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    Daughter- Daddy, would you pick up a couch for me?
    DT - I only have a 5' bed.
    Daughter- It will fit, it's not that big and I have too much in my Focus.
    DT - Ok. must be a love seat.
    Daughter- yah.
    @Sandman614
    Loving using the SUMOS as bumpstops.
  11. Jul 21, 2017 at 6:00 AM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    Thats my wife 100%!!!!!
    Smiley52 and Zwjense like this.
  12. Jul 21, 2017 at 6:30 AM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Dragons Taco likes this.
  13. Jul 21, 2017 at 6:37 AM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    Have a blast! Come back in one piece!
  14. Jul 21, 2017 at 6:41 AM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    I understand! Had to cancel AOP, daughter is moving to an apartment in Greensboro next weekend but this weekend I have to collect her furniture deals.
    And I have that Mazda to finish...
    nastyneight[QUOTED] likes this.
  15. Jul 21, 2017 at 6:56 AM
    Blkvoodoo
    Kevin
    Near Clayton NC
    looks like a RockAuto yard sale !
  16. Jul 21, 2017 at 7:02 AM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    Between my wife, 3 daughters and the Taco I might as well as buy stock. Or at least start my own shop.
    Smiley52 and Blkvoodoo[QUOTED] like this.
  17. Jul 21, 2017 at 7:07 AM
    Blkvoodoo
    Kevin
    Near Clayton NC
    Ha, my Runner is severely confused, was spec'd for 225/75r15 with 3.90 gears ( V6 5spd 4wd ) about 6months after i bought it the speedo needle wouldn't go past 40mph, even @ 70mph, not a good thing to let the wife loose in. found a new cluster, installed it ( mileage is now 13k off, lower than what it was showing ) Running 245/75r16 rubber, the speedo is off by 5mph @ 65, still not right, but at least trackable, then pinion bearing in rear was making noise, open it up to find 4.10 gearing in the rear, the front was still 3.90.....sigh ( front has since been swapped to 4.10 YAY, i can use 4wd again ! )
    I figured out the cluster is programmed for a Runner with 4.30 gears now running 4.10 gearing with 245/75R16s it'll stay that way, don't care.
  18. Jul 21, 2017 at 7:09 AM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    Does that mean we are gonna see you back on the trail soon?
  19. Jul 21, 2017 at 7:14 AM
    Blkvoodoo
    Kevin
    Near Clayton NC
    once it cools off there is that possibility, I've still got some trail prep and i need to find all my off road stuff ( strap(s), shackles, etc ) and off road rubber would be a good thing too. It's been a DD beater for the 7 years we've owned it, its time to go out and play
    need to yank the running boards and build sliders and a rear bumper and a front skid/bash plate to protect the lower radiator as well.
  20. Jul 21, 2017 at 7:32 AM
    Zwjense
    Yup, looks like I'm sitting at a 7% difference. Good to know.
