Raleigh North Carolina and surrounding areas
Discussion in 'South East' started by Sandman614, Aug 22, 2013.
  1. Dec 11, 2017 at 7:07 PM
    tacopaulo
    tacopaulo Tanned
    Paulo
    Raleigh, NC
    red truck
    Voz you crazy old man
    voz likes this.
  2. Dec 11, 2017 at 7:40 PM
    ThunderCookies
    ThunderCookies This is the Wait
    Jon
    North Carolina
    06 Wolfpack Edition
    5100s at 2.5 setting up front 5100s with 2" AAL around back TC Uniball UCAs 285/70/17 Fierce Attitude M/T SCS Ray 10s 17” 14" Magnaflow w/3.5" Stainless Tip SOS aluminum armor front bumper SOS high clearance rear bumper Stealth grill light bar and pods 4" Westin Nerf Bars Weathertech in-channel visors Window tint Bed Mat Proven Ground Locking Roll-Up Tonneau Cover All-weather rubber floor mats Custom Wolfpack TRD Decal TOYOTA Vintage Tailgate Decal 4 Wheel Drive vintage decal Tailgate Anti-Theft Mod Bed Mat Anti-Theft Mod Sliding back glass Anti-Theft Mod Future Mods: Bedside bottle opener Bedside storage lock/key mod Bed pod lights
    :hattip: Hey strangers
    So my left rear blinker is out. Swapped the bulb and it still doesn’t work. Right blinker is fine. Checked my new bulbs on the right side and it worked. Even stuck the bulb that was on he right side into the left side and nothing :notsure:. All the other lights on the left side work (taillight and reverse light). I’m guessing bad female port on that blinker :notsure: is that a thing?
    What’s next?
  3. Dec 11, 2017 at 7:45 PM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Does the front work?
  4. Dec 11, 2017 at 7:46 PM
    ThunderCookies
    Jon
    North Carolina
    06 Wolfpack Edition
    Yes, it is fast though. The clicking noise inside the cab (with the dash signal) is fast too. Like it’s supposed to do when a bulb goes bad
  5. Dec 11, 2017 at 7:49 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Idk if the whole light plugs are the same buy try swapping the whole housing.
  6. Dec 11, 2017 at 7:51 PM
    ThunderCookies
    Jon
    North Carolina
    06 Wolfpack Edition
    o_O What
  7. Dec 11, 2017 at 7:56 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Swap the whole housing to the other side, not just the bulb. Just note the plugs might be different and might not plugin.
    Blkvoodoo likes this.
  8. Dec 11, 2017 at 7:57 PM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    you may need to test the socket and then the connector to the tail light with a meter or test light, then chase the wiring back up the frame. A bad socket or connector isn't unreasonable
  9. Dec 11, 2017 at 7:59 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    :rofl:I don't think he has a meter:bananadead:
    Blkvoodoo[QUOTED] likes this.
  10. Dec 11, 2017 at 8:04 PM
    ThunderCookies
    Jon
    North Carolina
    06 Wolfpack Edition
    When you say whole housing...you mean :confused:
    This sounds like it might be too advanced for my basic understanding of mechanics. The right pedal makes it go. The left pedal makes it stop
    He’s right :facepalm:
    voz and Blkvoodoo[QUOTED] like this.
  11. Dec 11, 2017 at 8:19 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    The entire Taillight
  12. Dec 11, 2017 at 8:24 PM
    ThunderCookies
    Jon
    North Carolina
    06 Wolfpack Edition
    :eek:
    They aren’t interchangeable are they? Aren’t they cut to fit one side or the other?
    Even if I swapped the housing, the sockets are wired to that side so the bad socket (assuming that’s the issue) would still be on the left :confused:
  13. Dec 11, 2017 at 8:35 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Don't try to install the tailight, just leave it sit on the tailgate and plug it into the other side. That will narrow it down to the wiring or the taillight housing being the problem.
  14. Dec 11, 2017 at 8:48 PM
    ThunderCookies
    Jon
    North Carolina
    06 Wolfpack Edition
    I’ll mess with it tomorrow. Maybe it will make more sense when I’m looking at it
  15. Dec 12, 2017 at 1:29 AM
    voz
    voz Nothing Witty To Say
    VOZ
    VOZLAND
    The Clean One
    In Progress, Progressively
    Que pasa Sir.
    Hope all is well in your world...
    When you taking that jeep out for a ride
  16. Dec 12, 2017 at 5:21 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    When you take your tail lights off there is the big plug down at the bottom that unplugs the whole thing. The wires attached to the taillight are removable off the taillight and swapable between taillights this is a sub-harness attached to the taillights. What @Sandman614 is trying to get you to do is to take the one good taillight and plug it into the bad side. This will test the sub harness of the taillight. If it still doesn't work then you know you'll have to go chasing wires throughout the circuit. If I were a betting man if you unplug the socket on the taillight to that turn signal and that big plug to the whole taillight as well as the socket to the plug there is probably some corrosion in those connectors causing the issue. If there is corrosion take some Coke-Cola and pour it in the connectors, rinse and repeat until you don't see any more nastyness. Also check the connector from the subharness to the bulb socket.
  17. Dec 12, 2017 at 8:54 AM
    Blkvoodoo
    Kevin
    Near Clayton NC
    The tow probably cost more than truck is worth
  18. Dec 12, 2017 at 8:57 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Must have been the only tow truck they had avail. at the time lost money on that one! :der:
  19. Dec 12, 2017 at 9:24 AM
    ThunderCookies
    Jon
    North Carolina
    06 Wolfpack Edition
    Haven't gotten back out to look at the light yet but while I'm thinking about it...
    My low air pressure light is flashing. I've already checked all the tires (and spare) and they are fine so looks like I have a bad sensor. How hard is it to replace those?
  20. Dec 12, 2017 at 9:32 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    You have to deflate the tire once you figure out which one is bad then break the bead of the tire off of the wheel. Then push the bead down far enough to sneak the sensor out. Then reinflate the tire making sure you have enough air pressure to seat the bead again. If you are asking take it to a shop. Breaking a tire bead without a tire machine cane be a big time PITA! Trust me on this one.
