Raleigh North Carolina and surrounding areas
Discussion in 'South East' started by Sandman614, Aug 22, 2013.
  1. Dec 16, 2017 at 3:35 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    No worries!
  2. Dec 16, 2017 at 3:59 PM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    so are starters on 2nd gen 4wd as horrid to swap as I've read ?
  3. Dec 16, 2017 at 4:26 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    No there is a trick called don't pay any attention to the manual or the shadetrees that take the exhaust and/or f driveshafts off we did it in abt an hr incl. a bunch of BSing
    nastyneight and Red Baron like this.
  4. Dec 16, 2017 at 4:44 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    I should probably do a write up but we didn't take any pictures.
    Red Baron and diverdale like this.
  5. Dec 16, 2017 at 4:47 PM
    diverdale
    diverdale #sosconceptscrew
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Fox 2.5 Coilovers, Fox 2.0 Rear Resi, Icon 3 Leaf AAL
    Just do it again and take pics :p
    nastyneight likes this.
  6. Dec 16, 2017 at 4:49 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    How about if another one fails I'll walk that person through it or help them and we take pictures! :D
  7. Dec 16, 2017 at 5:55 PM
    Blkvoodoo
    Kevin
    Near Clayton NC
    i only ask as my POS isn't 4wd and i haven't actually looked at the starter. it starts, it runs, it drives, when (if) it stops doing any one of those, i'll look at it.
    I happened across a thread about someone disassembling a starter in place because it quit, didn't make sense to me then, still doesn't, i just never checked my own junk to see whats involved.
    THOUGH, on first gen 5spd/3rd gen 4Runner V6 a 1.8kw starter from an automatic with fit (tightly) in place of the 1.4kw starter the manual trans setup uses
  8. Dec 16, 2017 at 6:12 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    I am not sure if you still can but it use to be Toyota would sell brush kits. I use to replace many of those brush kits on Corolla and Camrys. I will say the 2wd and 4wd Tacomas are probably the same difficulty not sure of the manuals but I would say not that bad. I would never try and disassemble this starter in the vehicle to replace the brushes.
    I read several threads where guys tool the driveshaft out, disassembled the starter to pull it out in pieces, @Red Baron said he read a thread where they took the exhaust out.
    We just took the break line mount @ the frame loose moved it out of the way and pulled it out the wheel well. Easy peezy! Also could pretty much get to all the bolts right there as well!
  9. Dec 16, 2017 at 6:30 PM
    Blkvoodoo
    Kevin
    Near Clayton NC
    IF you get a parts counter person that is helpful, yes, you can get the contacts and brushes ( for alternator as well) they may or may not have them in stock, which sucks when you need shit NOW, its usually the contacts that erode in the solenoid that cause the issue.
    Back when i had my '85, i kept several starters on hand and carried one when off road as i would routinely use the starter to climb with out disengaging the clutch (this is why they have the clutch cancel button on the dash) never burned one up. Oddly, i now have new in the box starters on my service van most of the time, exact same one i carried spares for. and its still the contacts and plunger that burn/wear out.
  10. Dec 16, 2017 at 6:50 PM
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    Troof right there, only things that we had to move was the tire, rear splash guard, and coiled brake line to get to it. From the threads that I was reading I thought that we would have to take out much more than that to have the space to get it out but just wasn't the case thanks to stubborn thought and experience lol
  11. Dec 16, 2017 at 9:22 PM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Cool looked like it wouldn't be bad to get it out the side, glad you got a hand to do it. You just replaced it? When I need to do mine I will open it up and replace the contacts if that's what fails. I've already pulled my Alternator apart and replaced the Diodes, inexpensive and not bad to replace.
    https://www.youtube.com/watch?v=qwokxzjlYcQ
    https://www.amazon.com/Starter-Rebuild-Reduction-Starters-Contacts/dp/B007FR1FT6
    https://www.amazon.com/Victory-Lap-ND-36SOL-Solenoid-Repair/dp/B0031HL09E
    Blkvoodoo and Red Baron[QUOTED] like this.
  12. Dec 17, 2017 at 5:12 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    There are other failures but this is what fails if 99% of all starters. With the alternator though it could be several things that fail, diodes being one.
  13. Dec 17, 2017 at 7:17 AM
    Sandman614
    Tim
    '06 SR5 Off Road
  14. Dec 17, 2017 at 7:49 AM
    Red Baron
    Aaron
    07 Radiant Red DCSB
    How appropriate that he is working on a yota as well lol
  15. Dec 17, 2017 at 8:24 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Yet that does no look like the starter off of those corollas IIRC. It get's a little complicated with the gear reduction starters like for racing applications and the lovely Chrysler corp liked to use or the old fords where they liked to put the solenoid remotely from the starter motor. There are many contacts that could fail in the starter but the brushes and contacts are the normal failure mode, at least in Toyotas. Also I have bench tested starters like that and they work but are "weak "and they can't start an engine due to to much resistance in the contacts.
    Here is a good break down of a starter assembly
  16. Dec 17, 2017 at 9:18 AM
    Dangerdave
    Dangerdave Official TW jeep representative
    David
    Wilmington, NC
    20 F150
    @nastyneight when are you starting the tear down of the new trucks?
  17. Dec 17, 2017 at 10:18 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Neighbor just pulled up with some company in this 61 Chevy, looks nice!
  18. Dec 17, 2017 at 11:41 AM
    nastyneight
    nastyneight Well-Known Member
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    Not sure maybe Tuesday (may be getting my new toy, I'm getting myself a toy for my birthday) I may start fri-sat
  19. Dec 17, 2017 at 11:42 AM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Love that truck!
  20. Dec 17, 2017 at 11:49 AM
    voz
    voz Nothing Witty To Say
    VOZ
    VOZLAND
    The Clean One
    In Progress, Progressively
    Sweet
