Raleigh North Carolina and surrounding areas
Discussion in 'South East' started by Sandman614, Aug 22, 2013.
  1. Jan 23, 2018 at 9:49 AM
    nastyneight
    nastyneight Well-Known Member
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    yes ill be here all day
    Smiley52 likes this.
  2. Jan 23, 2018 at 10:52 AM
    Taco_life
    Taco_life Dooo yooou know the taco man?
    Johnny
    Clayton NC
    2003 Tacoma TRD
    42 inch light bar, ARB bumper, snorkel,rear trail gear bumper, Frankenstein’s rear leafs,
    O4 wheel parts on glen wood ave
  3. Jan 23, 2018 at 10:54 AM
    Taco_life
    Johnny
    Clayton NC
    2003 Tacoma TRD
    Before the put it on the rack they jack the truck up and with a bar they pull the wheel up and down to see if any parts are wore out
  4. Jan 23, 2018 at 10:54 AM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Yes, I'd take what they say with a grain of salt.
    ToyRyd04 likes this.
  5. Jan 23, 2018 at 10:55 AM
    Taco_life
    Johnny
    Clayton NC
    2003 Tacoma TRD
    Really who can I take it to that can do my truck
  6. Jan 23, 2018 at 10:58 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    I feel like any shop will give you a laundry list because the age/miles on your truck, and because that's business for them if you decide to let them do it.. You're better off diagnosing things yourself and gaging the timeline in which you want things done.
  7. Jan 23, 2018 at 11:00 AM
    Taco_life
    Johnny
    Clayton NC
    2003 Tacoma TRD
    I know for a rack my rack and pinion bushing are bad I’ll can start there do you think Firestone can do my truck
  8. Jan 23, 2018 at 11:01 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Mebbe, I don't know anything about shops since I don't use them. @diverdale has a place he likes. I'll be doing my own steering rack bushings at some point.
  9. Jan 23, 2018 at 11:02 AM
    mrbedgood
    mrbedgood Isaiah 6:8
    North Carolina
    '11 MGM DCSB TRD Off Road 4x4
    Total Chaos +2" Long Travel Kit; King/TC 2.5 LT C/O w/ 16"x600; TC/CVJ Extended Axles; TC Spindle Gussets; King 2.5 RR shocks; All-Pro Expendition Leaf Pack; Pelfreybilt Sliders; Anti-Dark LED Hood Light mod; LED map and dome light mod; Bed lights; TRD Cold Air Intake; KB Voodoo Tailgate cap system; HomerTaco Thin Lip "Raptor" grille; sPod SE System w/ LCD Touchscreen; Baja Design OnX6 40"; Baja Design S2; Rigid Industries LED Rock Lights; Front Runner Slimline II Roof Rack; A.R.E. Z Series Camper Shell Projector BHLM Headlights (with custom wiring); Method Racing NVs 17"x 8.5; and Nitto Terra Grappers 265/60/17
    You are a chicken butt
  10. Jan 23, 2018 at 11:12 AM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    Lower ball joints are a known issue on 1st gen Tacoma,3rd gen 4Runners, easy to change, 4bolts, tie rod and stud into spindle
    Uppers are a bit tougher but doable, I’d actually recommend Light Racing upper control arms with adjustable ball joints
    Steering rack bushing kit can be had on Amazon for $20 Urethane bushings.
    I’d also carefully inspect the hub bearings, high miles its time to replace, its a hateful job but doable with the right tools (press and fixture) they are not the same as 2nd gen Tacoma
    Taco_life[QUOTED] and ovrlndkull like this.
  11. Jan 23, 2018 at 11:17 AM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    you think of that all by your self?
  12. Jan 23, 2018 at 12:11 PM
    mrbedgood
    North Carolina
    Nope you helped!
  13. Jan 23, 2018 at 2:45 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    I don't trust them I had to completely redo a gears they put in my buddies JK they screwed up the preload and the gear contact pattern. Any good shop can align your truck. I use firestone because they have that lifetime alignment so whenever it gets off from hitting the trails its back for a free readjust. Same goes with using discount tire for my tires so when I throw a weight re-balance for free.
    Do what Blkvoodoo said to check the balljoints jack up under the control arm and then put a prybar or something under the tire and lift up if you see any movement from the ball joints they are bad. The tie rods just have to move the tire like you would for turning if there is any play with just a little bit of force then the tie rods are bad. You'll need to look at the tie rods to see which one has the play either the inner or outer. The rack bushings just have the truck on the ground and have some one steer from side to side if you notice the rack moving before the wheels turn the bushings are worn.
    Taco_life[QUOTED] likes this.
  14. Jan 23, 2018 at 4:25 PM
    overlandozzy1
    overlandozzy1 Well-Known Member
    Jonathan
    2016 WHITE DCLB
    16 DCLB, ADS, 5.29s, 35s, RCI Skids, Baja Designs
    Started with Leith Toyota in Raleigh today
    Tacobot14, Red Baron and ovrlndkull like this.
  15. Jan 23, 2018 at 4:34 PM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    Before and after flock dash parts
  16. Jan 23, 2018 at 4:51 PM
    overlandozzy1
    Jonathan
    2016 WHITE DCLB
    Also discovered a sway bar endlink is blown to crap. Time to remove the sway bar all together..... Its like wearing a condom, its fun with it on but its more fun with it off.
  17. Jan 23, 2018 at 5:01 PM
    Smiley52
    Smiley52 Insta: @Sm1ley52
    Danny
    Melbourne, FL
    2012 SR5 4x4
    We don't have anything that cheap around here. Not even 4runners lol
    voz[QUOTED] likes this.
  18. Jan 23, 2018 at 5:13 PM
    diverdale
    diverdale #sosconceptscrew
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Fox 2.5 Coilovers, Fox 2.0 Rear Resi, Icon 3 Leaf AAL
    @Taco_life Garner Auto Specialists has done right by me for many years now. They just got a brand new fancy alignment rig. They don't do the lifetime thing like Firestone but they're a locally owned shop that stands behind their work.
    Taco_life likes this.
  19. Jan 23, 2018 at 5:18 PM
    diverdale
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    I also agree with @Sandman614 and the others...do it in stages. I wouldn't trust 4Wheel Parts as they're in it for the MONEY...recommend anything they can to maximize profits. Don't blame them but with your knowledge combined with the others here you/we can do pretty much anything on a budget. Tim and I both have well equipped garages.
  20. Jan 23, 2018 at 5:20 PM
    mrbedgood
    North Carolina
    Well then why don’t you ever invite me over?
    Tacobot14 likes this.
