Raleigh North Carolina and surrounding areas
Discussion in 'South East' started by Sandman614, Aug 22, 2013.
  1. Jul 25, 2019 at 6:30 AM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Better than my last experience with OOPS.. Package arrives in Raleigh, then is sent to Charlottesville VA, then back to Richmond and back to Raleigh.
    Bannerman[QUOTED] likes this.
  2. Jul 25, 2019 at 6:35 AM
    Dangerdave
    Dangerdave Official TW jeep representative
    David
    Wilmington, NC
    20 F150
    I believe Richmond is one of the big hubs, so something must have been flagged on the package as an error or suspicious and had to be reprocessed.
  3. Jul 25, 2019 at 6:36 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    lol I think it was just someone not wanting to be at their job and not paying attention.
    07/24/2019 9:53 A.M. We've incorrectly sorted this package which may cause a delay.
    voz likes this.
  4. Jul 25, 2019 at 7:05 AM
    Dangerdave
    David
    Wilmington, NC
    20 F150
    :rofl::rofl::rofl:
  5. Jul 25, 2019 at 8:05 AM
    BeasleyNC
    BeasleyNC Well-Known Member
    Brad
    06 Tacoma Access Cab 4x4
    5100's on 884's , Wheelers Progressive AAL, GTA Carkit Bluetooth Adapter, WeatherTechs, Extang Solid Fold 2.0
    Anybody ever done U-joints? I'm on this maintenance kick and have 2 projects left. Did the ECGS bushing swap last weekend. My needle bearing was definitely worn when you spun it sounded like sandpaper. Fixed the grinding noise I was hearing turning at slow speeds and lessened some minor vibrations I've been feeling. I think remaining vibes have to be driveshaft all the symptoms are pointing me in that direction. I was gonna replace all the U-joints and Carrier Bearing. Not worried about the rear brakes I watched Tim do his a while back didn't seem too bad. But messing with the driveshaft I'm worried about balancing issues.
  6. Jul 25, 2019 at 8:19 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Not a hard job. replace them with Spicer, not Moog or another auto parts store brand. Make sure to mark your shaft to keep in aligned correctly and put all your grease zerks facing the same direction. I have several posts around with the Spicer part numbers.
    https://www.tacomaworld.com/threads/carrier-bearing-and-u-joints-suggestions.457387/#post-18215232
    https://www.tacomaworld.com/threads/carrier-bearing-and-u-joints-suggestions.457387/#post-13509242
    BeasleyNC[QUOTED] likes this.
  7. Jul 25, 2019 at 9:42 AM
    BeasleyNC
    Brad
    Thanks @Sandman614 ordering them now
  8. Jul 26, 2019 at 8:47 AM
    Sandman614
    Tim
    '06 SR5 Off Road
  9. Jul 26, 2019 at 10:44 AM
    HIghlande2
    HIghlande2 Well-Known Member
    Wilmington, NC
    15 DCSB Sport
    Little of this and a little of that
    :drool::drool::drool::pout:
  10. Jul 26, 2019 at 11:54 AM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    Some times you gotta bring the big toys out
    0BCEC054-18C9-47B5-A96A-33671DA37B31.jpg BCA8069F-C138-40D9-B0D6-914C6D0CC66D.jpg 68C79F33-B8E0-4166-98D3-ED6CFAC1D495.jpg image.jpg
    366in lift height
    Bain of my month
  11. Jul 27, 2019 at 12:01 AM
    mrbedgood
    mrbedgood Isaiah 6:8
    North Carolina
    '11 MGM DCSB TRD Off Road 4x4
    Total Chaos +2" Long Travel Kit; King/TC 2.5 LT C/O w/ 16"x600; TC/CVJ Extended Axles; TC Spindle Gussets; King 2.5 RR shocks; All-Pro Expendition Leaf Pack; Pelfreybilt Sliders; Anti-Dark LED Hood Light mod; LED map and dome light mod; Bed lights; TRD Cold Air Intake; KB Voodoo Tailgate cap system; HomerTaco Thin Lip "Raptor" grille; sPod SE System w/ LCD Touchscreen; Baja Design OnX6 40"; Baja Design S2; Rigid Industries LED Rock Lights; Front Runner Slimline II Roof Rack; A.R.E. Z Series Camper Shell Projector BHLM Headlights (with custom wiring); Method Racing NVs 17"x 8.5; and Nitto Terra Grappers 265/60/17
    From what I read you figured it out?
    Yes I pistol AR can be shouldered. If you found something different from the ATF please direct me, but I have seen nothing going against that ruling recently. The only recent thing that has come out is more rulings on forward grips and measuring 26”. @HIghlande2, have you seen anything new on the shouldering of AR pistols?
    Really? Go pick the lint out of your belly button.
  12. Jul 27, 2019 at 3:54 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Send it to them they'll fix it for you
  13. Jul 27, 2019 at 6:34 AM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    Got it all set up with a new 300 BLK PSA upper, ordered Wednesday, at my door Friday. Shot it this morning and it’s awesome. But while it cycles fine it will not lock BCG back with an empty mag. Thinking maybe the buffer spring is too heavy? Open to ideas.
    As far as shouldering a brace, I thought I’d read somewhere that the ATF changed their stance on it right before Shot Show this year and now you can’t shoulder a brace. I’ll try to find it.
    jaseb likes this.
  14. Jul 27, 2019 at 7:11 AM
    Dangerdave
    David
    Wilmington, NC
    20 F150
    Trust me, the won’t.
    Bannerman likes this.
  15. Jul 27, 2019 at 9:27 AM
    mrbedgood
    North Carolina
    I think I know what you are referring to, which is the redesign letter. SB tactical website is a good place to ensure you are good to go and staying legal.
    Trying heavier buffer lighter spring.
  16. Jul 27, 2019 at 9:42 AM
    Bannerman
    Johnson
    Charlotte, NC
    Will do thx
  17. Jul 27, 2019 at 9:47 AM
    mrbedgood
    North Carolina
    Anytime. I run H2 buffer in pretty much everything. While in my 300 blackouts I have always ran a geissele 42 buffer spring and their H2 buffers. Will be trying something new with the 8” 300 blackout.
  18. Jul 27, 2019 at 2:05 PM
    nastyneight
    nastyneight Well-Known Member
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    Another Miata motor pulled
    whitebread, voz and HIghlande2 like this.
  19. Jul 27, 2019 at 5:56 PM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    Me Mr. Sunshine and buddy Eric had it done in less than 2 hours
  20. Jul 27, 2019 at 5:59 PM
    HIghlande2
    Wilmington, NC
    15 DCSB Sport
    You could probably do it blind folded by now. Lol
    nastyneight[QUOTED] likes this.
