Raleigh North Carolina and surrounding areas
Discussion in 'South East' started by Sandman614, Aug 22, 2013.
  1. Mar 5, 2021 at 5:15 AM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    Clutch is a wear item, much like brakes . This would likely considered abuse ( improper inexperienced operation is still abuse) and unless there were previous instance related to clutch you’d have a hard time proving otherwise.
  2. Mar 5, 2021 at 5:24 AM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I would have tried. It should wear evenly, or at least a little more evenly than that..
  3. Mar 5, 2021 at 5:29 AM
    Blkvoodoo
    Kevin
    Near Clayton NC
    I agree, but car also has 36k which is warranty on most everything without extended, and clutch and brake issues are some of the most denied claims due you abuse and or improper operation
    We have all been behind that “new”car with the brake lights that either flicker constantly or never seem to go off because the “driver” is riding the brake or resting foot on pedal (which applies pressure to wheels as well....)
  4. Mar 5, 2021 at 7:31 AM
    Dangerdave
    Dangerdave Official TW jeep representative
    David
    Wilmington, NC
    20 F150
    They basically told me to kick rocks when I asked
    Blkvoodoo likes this.
  5. Mar 5, 2021 at 7:33 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    That just seems really shitty. From the looks of it I would say it was a bad install, because that disc shouldn't get cocked sideways that badly
    w.adventures likes this.
  6. Mar 5, 2021 at 7:40 AM
    Blkvoodoo
    Kevin
    Near Clayton NC
    Cocked sideways or clutch chatter so bad the friction material came apart ? If the flywheel and pressure plate had any bluing it got HOT, that’s why I asked about it earlier.
    The ability of an inexperienced operator to tear things up in grand fashion while being completely oblivious they are doing so is pretty common.
    You should come work in my world, I stopped asking “How the fuck....?” Several years ago, yet am still impressed in some things they manage to do.
    slander and zippsub9 like this.
  7. Mar 5, 2021 at 8:42 AM
    Dangerdave
    David
    Wilmington, NC
    20 F150
    I didn’t put eyes on the flywheel or pressure plate so I don’t know. Based on the idiots that drive for me, it was likely operator error.
  8. Mar 5, 2021 at 8:43 AM
    overlandozzy1
    overlandozzy1 Well-Known Member
    Jonathan
    2016 WHITE DCLB
    16 DCLB, ADS, 5.29s, 35s, RCI Skids, Baja Designs
    Anybody willing to help tackle replacing the clutch in my 01 civic? Trying to get the beater up and running again
  9. Mar 5, 2021 at 9:57 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Speaking as a former dumbass who drove underpowered vehicles that weren't mine, that seemed to only egg on the neutral drops and clutch dumps. I used to think my boss at the time was a raging lunatic for always being in our ass about stuff, but now that I'm older I would have fired 19yr old me like a month into the job lol!!!
    ovrlndkull and Blkvoodoo like this.
  10. Mar 5, 2021 at 3:03 PM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    This doesn’t look like operator error. I would go to the higher ups at Toyota with pictures and ask what’s up. There is a roasted clutch and then there is a clutch like yours where half of the disk didn’t even make contact with the flywheel.
    slander likes this.
  11. Mar 5, 2021 at 3:49 PM
    Dangerdave
    David
    Wilmington, NC
    20 F150
    Yea I’m gonna send it to corporate and see what happens. Shop said they’d vouche if needed
    w.adventures[QUOTED] likes this.
  12. Mar 5, 2021 at 4:03 PM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    I'm trying to find a solution to a similar problem and searching the threads to see if anyone came up with a fix. Have you resolved your issue? What did you do? My traction control switch and ABS light is on. Any help appreciated.
  13. Mar 5, 2021 at 6:10 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    where are you located? There was no continuity on driver front sensor wire. Replaced. Then we reset the VSC system manually at the OBD II.
    ovrlndkull likes this.
  14. Mar 5, 2021 at 6:45 PM
    Travlr
    Middle'a Utah
    Utah... wanna come out to Moab?
    Sorry, but VSC and OBD II is Greek to me. Is the VSC the traction control? (and why called VSC?) And I'm supposing the OBD is some kind of computer?
    How do you reset the system at the OBD?
  15. Mar 5, 2021 at 7:01 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Vehicle stability control, on board diagnostic
  16. Mar 5, 2021 at 7:13 PM
    Travlr
    Middle'a Utah
    Thanks for the definitions.
    How do you manually reset once you find the bad wire?
  17. Mar 5, 2021 at 7:32 PM
    Sandman614
    Tim
    '06 SR5 Off Road
  18. Mar 5, 2021 at 7:32 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    you need to find out what your problem is first. His was a broken wire. It could be any number of the nine steps in the factory service manual on almost any of the four wheels. I highly recommend you find a someone with access to a computer that can pull your error codes. This was his problem. I will provide a link to manually reset the yaw and VSC settings but if it doesn’t work then most likely you have a fault in the system preventing it from accepting the new values for a reason. You really need the codes without just shooting in the dark.
  19. Mar 5, 2021 at 7:36 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
  20. Mar 5, 2021 at 7:46 PM
    Travlr
    Middle'a Utah
