Raleigh North Carolina and surrounding areas
Discussion in 'South East' started by Sandman614, Aug 22, 2013.
  1. Aug 10, 2021 at 2:23 PM
    DiscoYaker
    DiscoYaker Well-Known Member
    SE USA and Alaska
    2015 Tacoma 4WD SR5 AC MT, 1995 Tacoma 2wd ext. cab auto
    Stock for now.. maybe
    So I'm going to just post/ask this again.
    GF needs some FOA coilover shocks rebuilt and charged. Vehicle is located in Burlington. We were hoping a friend could help with the rebuild and find someone to finish the job... no luck because they are busy...
    I have been looking/calling shops that could help us with this work with not much luck even if that means trailering the vehicle 4 hours round trip. Rebuild kit has finally arrived and would like to get this done so we can enjoy URE once it starts cooling off.
    Any suggestions for a shop? At this point we are willing to make a drive if needed
    I know, I know its a jeep on a tacoma forum.
    Posted on Raleigh and URE theads
  2. Aug 10, 2021 at 5:22 PM
    Dangerdave
    Dangerdave Official TW jeep representative
    David
    Wilmington, NC
    20 F150
    They let me hang around and I’ve got a Jeep and a F150 :rofl:
  3. Aug 11, 2021 at 3:43 AM
    HIghlande2
    HIghlande2 Well-Known Member
    Wilmington, NC
    15 DCSB Sport
    Little of this and a little of that
    Who are you again?
    :rofl:
  4. Aug 11, 2021 at 3:56 AM
    Dangerdave
    David
    Wilmington, NC
    20 F150
    I ask myself that every day :anonymous:
  5. Aug 11, 2021 at 12:36 PM
    overlandozzy1
    overlandozzy1 Well-Known Member
    Jonathan
    2016 WHITE DCLB
    16 DCLB, ADS, 5.29s, 35s, RCI Skids, Baja Designs
    Went to my local alignment shop today after installing my SPC UCAs to discover with my LCAs maxxed out, I was only able to achieve 1.7 degrees of caster. I believe stock specs are 0.6-0.8. Not to mention, in the process, my right front camber is out of spec, with the UCAs adjusted in to the max. And they sheered off one of my cam tab retainers. Anybody have some advice to lend? I was not charged for the alignment, but just seems to be more issues to fix going forward. Not to mention, possible tire wear issues down the road. I don't have a printout to provide
  6. Aug 11, 2021 at 1:55 PM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Find a better alignment tech.. Firestone had no clue how to do my alignment until I got a good tech and literally helped him do the alignment.
    The instructions say to 0 the LCA cams, set the UCA adjustment, then use the LCA for fine tune.
    Install this
    https://www.chaosfab.com/accessories/2016-2020-Tacoma-Lower-Control-Arm-Cam-Tab-Gussets-59860-10FJ
    BeefedTacos likes this.
  7. Aug 11, 2021 at 1:59 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Are the SPCs set at 4* caster? If your tabs are just bent then we can weld some flat bar in behind them or you could get all sexy with tab gussets. Or as stated above, try another tech, but you can look and see if the tab are bent flat.
  8. Aug 11, 2021 at 2:06 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    I had bent my factory tabs back up and put a weld bead behind them, it worked well enough but the whole tab bent and let the cam move (with offroad use). I imagine using some bar behind them would do similar while the gussets add reinforcement. No bad solution but I recommend the full gusset. I guess most techs don't loosen the bolts before cranking on them or something..
    zippsub9[QUOTED] likes this.
  9. Aug 11, 2021 at 3:45 PM
    overlandozzy1
    Jonathan
    2016 WHITE DCLB
    I set the UCA's at 4* but when they put it on the rack, it read 0.8* @zippsub9
  10. Aug 11, 2021 at 4:28 PM
    HIghlande2
    Wilmington, NC
    15 DCSB Sport
    This reminds me I need to get some TC gussets.
  11. Aug 11, 2021 at 4:44 PM
    HIghlande2
    Wilmington, NC
    15 DCSB Sport
    voz likes this.
  12. Aug 11, 2021 at 4:52 PM
    Dangerdave
    David
    Wilmington, NC
    20 F150
    :drunk:
  13. Aug 11, 2021 at 5:12 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    If your tabs aren’t bent flat then I would try a different shop. The camber is no excuse since a 36mm socket can provide an extra almost 10-15* of camber they just don’t check the top of the UCA. The toe and caster may just need another shop to set them up. Perhaps pre-soaking them may help with prevention of bending tabs. The Firestone off 55 in Apex knows how to mess with mine but I centered them prior to drop off. You may just check to see if the ball joint is centered up top first prior to heading to the shop. Take all the weight off the wheel first then loosen the ball joint, center it and retighten.
  14. Aug 11, 2021 at 6:38 PM
    FourOneThree
    FourOneThree Member
    Josh
    2001 Flatbed TRD Tacoma
    :itllbuffout: Any interests in a meet in the Jacksonville or surrounding areas sometime ?
  15. Aug 11, 2021 at 7:25 PM
    Dangerdave
    David
    Wilmington, NC
    20 F150
    Wilmington thread is fairly active. Might get a crew together in there
  16. Aug 12, 2021 at 5:24 AM
    voz
    voz Nothing Witty To Say
    VOZ
    VOZLAND
    The Clean One
    In Progress, Progressively
    nice YJ
    DiscoYaker[QUOTED] likes this.
  17. Aug 12, 2021 at 6:47 AM
    Dangerdave
    David
    Wilmington, NC
    20 F150
    something tells me thats not your every day Yuppie Jeep
  18. Aug 12, 2021 at 6:53 AM
    BeefedTacos
    BeefedTacos Well-Known Member
    Brian
    North Carolina
    2015 tacoma dcsb SR5 4x4
    None so far
    This is good to know cause I’m installing my lift and SPC next weekend.
  19. Aug 12, 2021 at 7:13 AM
    voz
    VOZ
    VOZLAND
    The Clean One
    OOO i bet
  20. Aug 12, 2021 at 7:29 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    I once knew a jeep guy
    Daria likes this.
