Raleigh North Carolina and surrounding areas
Discussion in 'South East' started by Sandman614, Aug 22, 2013.
  1. Oct 24, 2015 at 4:00 PM
    #6401
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    image.jpg Time for s'mores
  2. Oct 24, 2015 at 4:21 PM
    #6402
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Lol working by candle light
    David Loflin likes this.
  3. Oct 24, 2015 at 4:40 PM
    #6403
    Blkvoodoo
    Kevin
    Near Clayton NC
    Only thing different since I left @4 is now you're in the dark
  4. Oct 24, 2015 at 4:42 PM
    #6404
    Sandman614
    Tim
    '06 SR5 Off Road
    I got the spindle off, oil seal out, and new ones painted LOL.
    nastyneight likes this.
  5. Oct 24, 2015 at 5:25 PM
    #6405
    nastyneight
    nastyneight Well-Known Member
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    You guys are crazy, took me about a week to do the work your trying to do in a day!
  6. Oct 24, 2015 at 5:28 PM
    #6406
    voz
    voz Nothing Witty To Say
    VOZ
    VOZLAND
    The Clean One
    In Progress, Progressively
    Tim does put in some work, just wish I could have been there to get on everyone's nerves...
    Smiley52 and Dragonslady like this.
  7. Oct 24, 2015 at 5:32 PM
    #6407
    Sandman614
    Tim
    '06 SR5 Off Road
    Its how I do. Now to find an oring. I think I got the wrong size last time. @nj636 do you know what size and where I can get one? Mine does not fit tight to the outside of the bearing housing, it almost sits in the groove on the bolt face.
  8. Oct 24, 2015 at 5:43 PM
    #6408
    Blkvoodoo
    Kevin
    Near Clayton NC
    The reality is he should be done with both sides and doing an alignment by now
  9. Oct 24, 2015 at 5:59 PM
    #6409
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    I was lucky, Basically I put a new bearings in at same time that were ready to bolt in, made my life alot easier
  10. Oct 24, 2015 at 6:00 PM
    #6410
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    Lift helped too:anonymous:
  11. Oct 24, 2015 at 6:57 PM
    #6411
    Sandman614
    Tim
    '06 SR5 Off Road
    I keep saying I wish I had the money to do exactly that while it's all apart.
    Can someone tell me how to activate atrac on this thing. Lol 7 wheel drive.
  12. Oct 24, 2015 at 9:00 PM
    #6412
    David Loflin
    David Loflin 2012 Conversion
    David
    Raleigh/Mooresville NC
    2007/12 BSP AC High Country TRD Off Road
    2012 Front End Conversion RuggedT Decals Phillips 921 Led Reverse Lights and 43mm Dome Led Sylvania ZEVO LED Map, and License Plate Lights Silverstar ZXE Headlights and Fog Lights K&N Air and Oil Filter Panavise dash mount and Proclip phone holder Mobil 1 Synthetic 5w-30 Mobil 1 Synthetic 75w-90 diff oil Fumoto Oil Drain Valve Painted Engine Cover Shorty Antenna Partial Debadge and Rebadge High Country Badges from Silverado Secondary Air Filter Removed FJ 6 spoke OEM wheels Mastercraft Courser MXT Tires UWS Toolbox TRD Bislteins-4600s Recall Leafs Realtree Seat Covers Walmart All Weather Mats Rain X Wipers Belkin Multi Charger ran through Console Firestik NGP 3 foot Antenna Black exhaust tip
    so i noticed tonight that you can really hear my belts and fan at idle, now my coolant isnt at full but its not at low, its kind of in the middle-ish??? is this something i should worry about? i need to do some preventive maintenance anyway its just funds are limited.
  13. Oct 24, 2015 at 9:14 PM
    #6413
    Blkvoodoo
    Kevin
    Near Clayton NC
    If the overflow tank is in between the lines on the tank you're ok, just make sure when it's cold the radiator is full to the top at the cap. If it's not full there you may have other issues
  14. Oct 24, 2015 at 9:21 PM
    #6414
    Blkvoodoo
    Kevin
    Near Clayton NC
    Accessory drive belt, belt tensioner (1) and idlers (2) are all maintainance items. Belt might look ok but is aged and worn, belt tensioner spring can get weak over time, look like its holding belt tight but not really doing the job ( usual cause if belt chirp and squeal along with worn belt )
  15. Oct 25, 2015 at 5:45 AM
    #6415
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    So is it done?
  16. Oct 25, 2015 at 7:21 AM
    #6416
    Sandman614
    Tim
    '06 SR5 Off Road
    I ordered all new Idler pulleys for mine. Once USPS stops being dicks I'll get them on and let you know which ones work.
    I just gotta go get an oring today.
    David Loflin[QUOTED] likes this.
  17. Oct 25, 2015 at 9:32 AM
    #6417
    Sandman614
    Tim
    '06 SR5 Off Road
    Last 2 lol
    voz likes this.
  18. Oct 25, 2015 at 11:29 AM
    #6418
    voz
    VOZ
    VOZLAND
    The Clean One
    At least you got them...
  19. Oct 25, 2015 at 11:35 AM
    #6419
    Sandman614
    Tim
    '06 SR5 Off Road
    Now if Erin would stop making plans for me I could have it done.
  20. Oct 25, 2015 at 12:10 PM
    #6420
    voz
    VOZ
    VOZLAND
    The Clean One
    That won't happen, she has papers now...
