Raleigh North Carolina and surrounding areas
Discussion in 'South East' started by Sandman614, Aug 22, 2013.
  1. Jan 10, 2016 at 3:43 PM
    nastyneight
    nastyneight Well-Known Member
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    Once the U joint starts chirping, replace quickly, will get worse quickly
    Blkvoodoo likes this.
  2. Jan 10, 2016 at 3:45 PM
    S13chris
    S13chris Well-Known Member
    Jacksonville nc
    07 dbl cab 4x4
    Tail gate mod, debadged, and weather techs, satoshi grill, diff breather mod, Duratracs 265/70/17, snugtop shell w/ rack, sleeping platform for bed, LED's for interior lights/Reverse lights/license plate, BHLM & DTRL Mod.
    Question I have a blue seas fuse block and want to wire 4 led pods for my front bumper, I have a question on what relay I need to wire up to it. Any help would be appreciated. I'll keep scrolling through the search bar till then
  3. Jan 10, 2016 at 5:04 PM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Center ball? I need a diagram or pics.
    Don't need a relay if all pods is less than about 10amps. If you want to use a relay a normal automotive 4 pin relay is all you need.
    Here's a calculator to convert watts to amps.
    http://www.rapidtables.com/calc/electric/Watt_to_Amp_Calculator.htm
  4. Jan 10, 2016 at 5:06 PM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    I rebuilt the CV on my 81 and doing the center ball SUCKED
  5. Jan 10, 2016 at 5:08 PM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    http://www.rockforddriveline.com/toyota.pdf
    there is a ball and pin in the center of the CV, it needs to be greased as well, if it isn't the CV will get off center and vibe bad, if you're going to rebuild CV, replace the ball ( there is a bearing in center of ball as well )
    view the pics in PDF above, parts are very similar if not that same
  6. Jan 10, 2016 at 5:08 PM
    Blkvoodoo
    Kevin
    Near Clayton NC
    yes it does
  7. Jan 10, 2016 at 5:09 PM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    It almost like you need more hands to do it.
  8. Jan 10, 2016 at 5:09 PM
    Blkvoodoo
    Kevin
    Near Clayton NC
    and thats if it actually starts coming out....
  9. Jan 10, 2016 at 5:11 PM
    Blkvoodoo
    Kevin
    Near Clayton NC
  10. Jan 10, 2016 at 5:32 PM
    Josh828
    Josh828 Well-Known Member
    Josh
    Avery NC
    14 White TRD Off road, Mid travel mountain truck
    FOX 2.5 extended travel, Fox 2.0 rears, LR UCA, XSPX rims, some light bars, and switches
    The rest of my switches came in, was trimming some plastic so they would fit when I found out how sharp my knife was and stabbed my self, nothing a few stitches couldn't fix.. I realized its going to take a while to finish wiring the switches... 5 wires per switch, 6 switches.. 30 wires :boom:
    Dragonslady likes this.
  11. Jan 10, 2016 at 8:44 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Mothman likes this.
  12. Jan 10, 2016 at 9:09 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    I lied..
  13. Jan 10, 2016 at 9:12 PM
    Blkvoodoo
    Kevin
    Near Clayton NC
    $1200 @ dealer ( mine was replaced before I bought it, dealer (Leath) refuses to change joints.
    Being that you have wheeled your truck, I'd look close at it to see if it's not bent, twisted or dented, that's a long span to not have anything intrude on when off-road.
    If you need joints, you may as well take it to a driveline shop, they'll likely replace them anyway if you just say balance it. Probably replace the center bearing as well.
  14. Jan 11, 2016 at 3:33 AM
    ahspurlock
    ahspurlock The TW Mechanic
    Adam
    summerville.south Carolina
    08 T4R V8 Limited AWD
    Front long travel and Rear long travel including upper and lower rear control arms. Running 456 gears with rear ARB locker . LFD full roof rack with clamshell RTT
  15. Jan 11, 2016 at 4:33 AM
    B. Blake
    B. Blake Heelin' Dawg!
    Pittsboro, NC
    2014 Tacoma TRD - Off Road DCSB
    I'm selling the Tacoma today.....
    I have a 4 month old UWS Tool Box and Black weather techs floor mats (Fronts Only) for sale. I would like to get $80 for the floor mats and around $300 for the tool box. Both are in great condition. There is a link to what the truck box looks like. I wanted to put it on here before putting it on the for sale page. Local Pickup Only
    http://www.amazon.com/UWS-TBS-63-A-LP-BLK-Profile-Aluminum-Insulated/dp/B0017HB3SS
  16. Jan 11, 2016 at 5:47 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    There isn't one :)
  17. Jan 11, 2016 at 5:50 AM
    ahspurlock
    Adam
    interresting
  18. Jan 11, 2016 at 5:54 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    @RaleighTaco, We may have missed No. 6
    ahspurlock likes this.
  19. Jan 11, 2016 at 6:00 AM
    Mothman
    Mothman Well-Known Member
    Advance
    single cab
    Low and slow.. chopped up on 35s
  20. Jan 11, 2016 at 6:02 AM
    Blkvoodoo
    Kevin
    Near Clayton NC
    Number 6 is for the centering ball between the yoke sections, easy to miss, and usually is.
    If shaft had been repIred before a lot of shops install a cone fitting in place of the zerk, makes it easier to get at with grease needle.
    Earlier Toyotas with this style double cardan joint on the front driveshaft actually had a special grease fitting included in the vehicle tool kit to allow easier access to this fitting.
