Raleigh North Carolina and surrounding areas
Discussion in 'South East' started by Sandman614, Aug 22, 2013.
  1. Jan 11, 2016 at 6:07 AM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
  2. Jan 11, 2016 at 6:08 AM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Whatever they call it on a 4runner?
  3. Jan 11, 2016 at 6:16 AM
    Blkvoodoo
    Kevin
    Near Clayton NC
    Joint is used on front of rear shaft on 3rd gen 4Runner and front driveshaft on 79-95 trucks an 4Runners, IFS trucks didn't have the range of motion the ealier ones did, but they can be clearanced to work
    Mothman[QUOTED] likes this.
  4. Jan 11, 2016 at 6:52 AM
    Mothman
    Mothman Well-Known Member
    Advance
    single cab
    Low and slow.. chopped up on 35s
    Yeah I know what it is, just figured it was the ball squeaking...
    1 piece shaft for me
  5. Jan 11, 2016 at 6:54 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    If it is the ball I guess we can always add more grease, if we missed it that will cover it, if not grease until the ball falls out? lol
  6. Jan 11, 2016 at 6:56 AM
    Mothman
    Advance
    single cab
    Exactly. Just sounds like my jeep buddies did when he didn't grease the ball.. it required a needle type end and it still ended up clunking because bad pinion angle
  7. Jan 11, 2016 at 7:02 AM
    Blkvoodoo
    Kevin
    Near Clayton NC
    I'd be surprised if greasing anything at this point will "fix" anything, quiet it maybe.
    If you look at the driveshaft and it is original, you will notice ALL the fittings are in line down one side of the shaft ( slip yoke fitting is easiest to see) turn shaft to one position and all fittings are accessible with out having to wrestle around
    Mothman likes this.
  8. Jan 11, 2016 at 7:05 AM
    Blkvoodoo
    Kevin
    Near Clayton NC
    If slip yoke seems dry, pull driveshaft end and separate then grease the splines, just pumping it full of grease can blow the end cap out of the yoke, then it won't hold grease at all, 4-5 pumps is all you should ever push into slip yoke
    Mothman likes this.
  9. Jan 11, 2016 at 7:18 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Just looking for it to quiet the noise so we can pinpoint the cause.
    Mothman likes this.
  10. Jan 11, 2016 at 8:48 AM
    S13chris
    S13chris Well-Known Member
    Jacksonville nc
    07 dbl cab 4x4
    Tail gate mod, debadged, and weather techs, satoshi grill, diff breather mod, Duratracs 265/70/17, snugtop shell w/ rack, sleeping platform for bed, LED's for interior lights/Reverse lights/license plate, BHLM & DTRL Mod.
    Awesome. Thanks
  11. Jan 11, 2016 at 12:01 PM
    David Loflin
    David Loflin 2012 Conversion
    David
    Raleigh/Mooresville NC
    2007/12 BSP AC High Country TRD Off Road
    2012 Front End Conversion RuggedT Decals Phillips 921 Led Reverse Lights and 43mm Dome Led Sylvania ZEVO LED Map, and License Plate Lights Silverstar ZXE Headlights and Fog Lights K&N Air and Oil Filter Panavise dash mount and Proclip phone holder Mobil 1 Synthetic 5w-30 Mobil 1 Synthetic 75w-90 diff oil Fumoto Oil Drain Valve Painted Engine Cover Shorty Antenna Partial Debadge and Rebadge High Country Badges from Silverado Secondary Air Filter Removed FJ 6 spoke OEM wheels Mastercraft Courser MXT Tires UWS Toolbox TRD Bislteins-4600s Recall Leafs Realtree Seat Covers Walmart All Weather Mats Rain X Wipers Belkin Multi Charger ran through Console Firestik NGP 3 foot Antenna Black exhaust tip
    Toyota Eco Diesel. Seems legit
  12. Jan 11, 2016 at 2:26 PM
    gman424
    gman424 Well-Known Member
    Gary
    southport, NC
    96 tacoma
    3" lift, trail gear bumper, winch, 20" light bar, budbuilt skid, SOS concept sliders, retrofit E-locker, bedrack
    Really? Mine does but not enough to starve the motor, I saw a write up somewhere where a guy did some bracing on the inside with some type of wire fence
  13. Jan 11, 2016 at 2:44 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Yea about 4000 rpm it sucks closed and makes a screeching/sucking noise.
    S13chris and Mothman like this.
  14. Jan 11, 2016 at 2:51 PM
    nastyneight
    nastyneight Well-Known Member
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    Sure rigging stuff again
  15. Jan 11, 2016 at 3:16 PM
    Smiley52
    Smiley52 Insta: @Sm1ley52
    Danny
    Melbourne, FL
    2012 SR5 4x4
    Bannerman likes this.
  16. Jan 11, 2016 at 3:20 PM
    RaleighTaco
    RaleighTaco Well-Known Member
    Jonathon
    Raleigh NC
    '97 Toyota 4runner
    Looking thru t4r is pretty common issue with these chinese snorkels....now to find a cure.
  17. Jan 11, 2016 at 3:23 PM
    voz
    voz Nothing Witty To Say
    VOZ
    VOZLAND
    The Clean One
    In Progress, Progressively
    @nastyneight i found a 4in 3/8 socket extension in my engine bay today. I believe it's yours....
  18. Jan 11, 2016 at 3:46 PM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    I shun you!
  19. Jan 11, 2016 at 3:47 PM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    You bring my tools back, than steal others. Wait its just because you want to see me more
  20. Jan 11, 2016 at 4:17 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    That must be why @EddyRRT keeps ending up with mine.
