Raleigh North Carolina and surrounding areas
Discussion in 'South East' started by Sandman614, Aug 22, 2013.
  1. Jan 29, 2016 at 4:13 PM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    Amateur....
    Smiley52 likes this.
  2. Jan 29, 2016 at 4:16 PM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I took a second look and.... it..... was ..... gone
    Blkvoodoo[QUOTED] likes this.
  3. Jan 29, 2016 at 4:17 PM
    Blkvoodoo
    Kevin
    Near Clayton NC
    shocker is broken
  4. Jan 29, 2016 at 4:19 PM
    voz
    voz Nothing Witty To Say
    VOZ
    VOZLAND
    The Clean One
    In Progress, Progressively
    I didn't need to see that...
    ThunderCookies likes this.
  5. Jan 29, 2016 at 4:21 PM
    Blkvoodoo
    Kevin
    Near Clayton NC
    Power tools are bad, M'kay.....
  6. Jan 29, 2016 at 5:50 PM
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    Anybody around have some bolt on sides for an extended cab first gen they need to get rid of?
  7. Jan 29, 2016 at 9:28 PM
    Sandman614
    Tim
    '06 SR5 Off Road
  8. Jan 30, 2016 at 6:36 AM
    voz
    VOZ
    VOZLAND
    The Clean One
  9. Jan 30, 2016 at 6:37 AM
    voz
    VOZ
    VOZLAND
    The Clean One
  10. Jan 30, 2016 at 6:38 AM
    voz
    VOZ
    VOZLAND
    The Clean One
    My fake yeti
    E9D86DA1-63E8-422E-A4B8-68AF55153EE9_zps_65530fe4bfc8cf01dc26e05f56aa2a0c597ab481.jpg
  11. Jan 30, 2016 at 8:08 AM
    tacopaulo
    tacopaulo Tanned
    Paulo
    Raleigh, NC
    red truck
    It's pretty like you
  12. Jan 30, 2016 at 12:28 PM
    Smiley52
    Smiley52 Insta: @Sm1ley52
    Danny
    Melbourne, FL
    2012 SR5 4x4
    Lookin mighty sexy.
    When you gonna do the blue headlight mod?
  13. Jan 30, 2016 at 12:30 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    @Smiley52 what's your buddy say about these tires?
  14. Jan 30, 2016 at 12:39 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    How much oil in the blue arb locker line is normal? This is how much that came out while hung up after I blew it out with the air compressor. Hung up for a week.
  15. Jan 30, 2016 at 12:58 PM
    Blkvoodoo
    Kevin
    Near Clayton NC
    From what I understand oil isn't unusual, BUT you do need to see if will hold pressure. get it set up and engage the locker and see if can sit for 15min or longer before the compressor cycles again. if not then this could be an issue.
    Keep in mind, the diff breathers on the Toyotas are designed to keep a certain amount of POSITIVE pressure on the axle housing, this keeps the axle and pinion seals tight so they don't suck in water. Even the non locked axles will relieve a certain amount of pressure when removed or the diff plug is pulled (listen close, you may hear some air movement.
    this pressure can push oil into the air lines on the ARB, the seals on the ARB are Orings, not lip seals, Orings can/will allow oil to pass over time
  16. Jan 30, 2016 at 1:35 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    It will be a lot longer than 15 mins with my setup, tank to adjustable regulator. The system holds pressure for a loooong time. I think I remember 5 lbs drop in like an hour or more..
  17. Jan 30, 2016 at 1:51 PM
    Blkvoodoo
    Kevin
    Near Clayton NC
    pull the breather and install a gauge for a short time ( non driving ) see if any pressure builds up in the axle, that will tell you if you have enough of a leak to worry about. the heating/cooling cycle is what builds pressure with just the breather vent, any real pressure while just sitting there unused would maybe indicate you have a seal issue
  18. Jan 30, 2016 at 1:54 PM
    nastyneight
    nastyneight Well-Known Member
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    Drift trikes the next hotness
  19. Jan 30, 2016 at 2:07 PM
    voz
    VOZ
    VOZLAND
    The Clean One
    Why thank you
    SB= Stay Broke
    Smiley52[QUOTED] likes this.
  20. Jan 30, 2016 at 2:08 PM
    voz
    VOZ
    VOZLAND
    The Clean One
    I want one
