ram air trd cai
Discussion in 'Performance and Tuning' started by outlaw7, Aug 22, 2010.
  1. Aug 22, 2010 at 12:46 PM
    outlaw7
    outlaw7 [OP] Well-Known Member
    Brandon
    PacNorWest
    2010 trd sport
    i have been wanting to do some kind of ram air for my trd cai for some time after monitoring my temps while driving in the city. my iat would normally be around 10-12 deg higher than the outside temp until i really got on it then the temp would drop slowly. so after checking out all the possibilities and after reading coupes writeup on his ram air this is what i came up with. first i purchased the volant ram air duct from auto anything. then i had to find how i was going to mount it to the existing trd box. this is what i found at home depot in the pvc isle.
    the silicone couple fit around the outside perfect but as you can see it had some crap in the center i would have to get rid of. so after finding the right size hole saw 3.25 for the center of my adapter and 3.5 for the hole in the box i went to town.
    the two didnt line up perfectly because of the round edges of the trd box so they are offset prob 3/8 of an inch max and i had to trim some of the top of my gray insert to fin under the top lip of the box. then i used some 5min epoxy to adhere the new insert onto the box you can only apply epoxy to the lower half because the box is two different depths where i mounted it so after the bottom was cured i applied some around the top on the outside just for peace of mind.
    then put everything back together and i was pretty pleased with how it came out.
    excuse the dirty engine truck has been neglected due to work schedule but over the last two days of driving around town i am very pleased with the results. the intake temps are at max 3-5 deg above outside when just cruising but drop very close to outside temp with a little throttle very quick. no real performance increase but maybe just a slight bit of response from the cooler air temps which is what i was going for. at highway speeds the intake temps is right at outside temp always.
  2. Aug 22, 2010 at 12:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Have you tiried to use some washers to space the opening, so its more open?
  3. Aug 22, 2010 at 12:50 PM
    outlaw7
    Brandon
    PacNorWest
    2010 trd sport
    which opening do you mean chris?
  4. Aug 22, 2010 at 12:54 PM
    LuckeyTRD
    LuckeyTRD rIDIN wHEELIEz!!
    Cole
    Evans, GA
    2010 PreRunner ALL TERRAIN
    BHLM, Blacked out tails, window tint 5%, tinted windshield , 8000k hids hi/lo and fogs. Black side badges, debadged tailgate, camburg 1.25" uniball UCA's, Camburg 4" spindles, ext. brake lines, Fox remote resi coilovers. Fox 2.0 Pro series rear piggybacks, 3" Allpro Leaf pack, OEM roof rack, Brush guard. Custom TRD allterrain decals. UWS low profile black toolbox
    i think hes talking about the intake box plexiglass cover. putting washers under and between the plexiglass and plastic.
  5. Aug 22, 2010 at 12:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The "Ram air" opening. It looks pinched closed.
  6. Aug 22, 2010 at 12:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    In this pic, the opening looks rather small:
  7. Aug 22, 2010 at 12:57 PM
    outlaw7
    Brandon
    PacNorWest
    2010 trd sport
    the opening in on the bottom it has a lip that hangs prob 3-4 inches below and rests right on top in the radiator so the air comes in from right below the top of the grill and between the top of the radiator.
  8. Aug 22, 2010 at 12:57 PM
    LuckeyTRD
    Cole
    Evans, GA
    the ram air sits behind the radiator/intercooler and inducts the air behind it... correct me if im wrong, im reinventing this in my head,
  9. Aug 22, 2010 at 12:58 PM
    LuckeyTRD
    Cole
    Evans, GA
    did u see an increase in power and temp?
  10. Aug 22, 2010 at 12:59 PM
    outlaw7
    Brandon
    PacNorWest
    2010 trd sport
    ill get pics of the opening give me 5
  11. Aug 22, 2010 at 12:59 PM
    LuckeyTRD
    Cole
    Evans, GA
    and how well do u think this would work on the regualr cai if i dont have a s/c
  12. Aug 22, 2010 at 12:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Gotcha!
  13. Aug 22, 2010 at 1:00 PM
    outlaw7
    Brandon
    PacNorWest
    2010 trd sport
    decrease in temps which might have led to a slight increase in performance
  14. Aug 22, 2010 at 1:09 PM
    outlaw7
    Brandon
    PacNorWest
    2010 trd sport
    i honestly cant say if it will have any performance gains or not all i have is my own data i have been monitoring with my gauge on the intake temps and so far they have been lower than before i did this and thats all i was really looking for was lowering the temp as quick as possible
  15. Aug 22, 2010 at 1:13 PM
    outlaw7
    Brandon
    PacNorWest
    2010 trd sport
    heres kind of a side shot chris so you can see how its designed and you can kind of see the openings right on top of the radiator from through the grill.
    you can see theres about a 4 inch opening on either side of the center brace where the hood latch is and if you look just to the right above the horns you can see the glare on the outer edge of that one side.
  16. Sep 14, 2010 at 12:21 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    hmm going to try this
  17. Sep 14, 2010 at 2:20 PM
    SagWagon
    SagWagon Well-Known Member
    Geoff
    Portland, OR
    2022 TRD OR
  18. Apr 16, 2011 at 6:47 AM
    bcroach78
    bcroach78 Well-Known Member
    TN
    2010 Crew cab TRD L/B S/C
    Any mpg increase?
  19. Apr 16, 2011 at 7:08 AM
    outlaw7
    Brandon
    PacNorWest
    2010 trd sport
    Im not sure if there was any gain, my truck is not my dd so when i drive it it gets driven pretty rough so my mileage is terrible. the big gain is how much quicker the intake air temps drop and how low they stay. I have seen lower temps in the intake than the readout on my outside temp gauge in the roof at times.
  20. May 4, 2011 at 8:18 AM
    H2Otx
    H2Otx The Tinkerer
    Austin
    Houston, Texas
    10 DC 4x2 SR5 TRD Off-Road
    SilverStar Ultra Headlights; Nokya Ion Yellow Fogs; SuperBright LED Bulbs; 8" Shorty Antenna; WeatherTech Mats / Bug Shield / Vent Visors; TRD CAI with aFe Pro Dry S Filter; aFe Pre-Filter; Custom CAI Cover and Fuse Box Cover; TRD AT Shift Knob (Japan); TRD Oil Filler Cap (Japan); n-Fab Step Rails; Monster Hook
    Not to be an ass, but between the conversations Outlaw and I have had, you don't really do this for MPG increase...
    The purpose of this is to get cooler air temps to the air box to give the motor cooler air. Outlaw has a S/C and you typically want the temps as cool as possible. Prolongs the life of components (NOT FREEZING COLD).
