Ram Mount Feeler
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lostsheep, Feb 21, 2017.
  1. Mar 13, 2017 at 2:03 AM
    #201
    DrFunker
    DrFunker Well-Known Member
    I have one too and was wondering the same thing. :confused:
  2. Mar 13, 2017 at 8:50 AM
    #202
    romafern
    romafern Hug diz nuts
    Rob
    80918 Let's meet!
    Paid for and saving a shit ton of $$$$$
    Thinking of adding a second battery...
    Ive looked up that kit and by the looks of it, it looks like it won't but I could be wrong...
  3. Mar 13, 2017 at 11:49 AM
    #203
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Yea looks like depends on how far the backing plate can be moved down. Also if he makes the backing plate threaded maybe might not have to remove whole piece ? Maybe can drill the 2 holes and stick say like 2 pieces wire hanger up dash but through 2holes in backing plate and drop it down then remove bottom wire and install bottom bolt then top . :notsure: I got extra center piece at home and was looking like could work that way.
    DrFunker likes this.
  4. Mar 13, 2017 at 2:09 PM
    #204
    mlowber
    mlowber Well-Known Member
    Lyons, CO
    2007 TRD Sport
    I've got a radio that I'm waiting to install until I get an ETA on this. Looking great. Happy to give you some feedback too if you'd ship one out to CO for this install.
  5. Mar 13, 2017 at 3:35 PM
    #205
    Lostsheep
    Lostsheep [OP] Well-Known Member
    NorCal
    2015 6spd 4x4 OR
    6112s and 5160 , Dakars , Superbumps x4 , u-bolt flip , All Pro Skids (hacked and raised) , 265/70R17 KO2s, SEMA wheels, couple of machined things here and there
    I'm really trying to do these 2 at a time to make it worth my while. They are countersunk on both sides so they can be mounted on either side. Maybe have a spare? Give one to a buddy? 2 person group buy lol. I'm not trying to be flippant just trying to keep things simple on my end. FWIW, I have both sides mounted and I find the drivers side to be more useful.
    I guess but not by much, I think I paid $1 per set to have them anodized. I think anodizing is money well spent for long term corrosion resistance.
    Thank you for the kind words.
    For hardware, Mcmaster has almost anything you can imagine but what you are describing is mcmaster part number 93791A523. I went with stainless socket head screws for corrosion resistance even though I suspect it's overkill. The part I just mentioned is a black stainless screw. I suppose pending enough requests I can / will supply those instead of the normal stainless. I am trying not to create a bunch of different configurations as I will undoubtedly screw things up (pun intended.)
    For the backing plate, right now it is in a state of flux, original design cooperated with me but Eddo has requested threaded plates. The set I have here right now that are going out shortly should provide me with some feedback. I am not super stoked on having to use locktite but the threaded plates really need it in my opinion. Might see if I can find a screw with the locking patch already applied to eliminate having to use lock tite.
    I'm using double sided tape but if you can assemble them with your method that sounds great. All will have threaded plates from here on out. I am on the fence about material, aluminum is cheaper and faster for me to cut but the threads are not as strong. Are they strong enough? I think they are but I want to stand by my design and keep everyone happy.
    Drtgrl, Bentrodder and Jorgy1 like this.
  6. Mar 13, 2017 at 3:45 PM
    #206
    Jorgy1
    Jorgy1 Well-Known Member
    2019 MGM Tundra CrewMax 4x4
    @Lostsheep i sure appreciate the care you are putting into this product and thread, getting this product 'just right' before making available for mass purchase. You look to be developing a fine product and I look forward to purchasing from you.....hopefully soon!
    mountainmonkey and Lostsheep[OP] like this.
  7. Mar 13, 2017 at 3:49 PM
    #207
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I'd like one these. Where do I sign up?
  8. Mar 13, 2017 at 3:58 PM
    #208
    Lostsheep
    NorCal
    2015 6spd 4x4 OR
    Updated the first post and I am going to try and keep the list updated. If you don't see your name and it's supposed to be there, yell at me and I'll fix it. At this point though, no one should worry as I can run enough for the list relatively quickly and I will get to everyone.
    bennyb123 and DriverSound like this.
  9. Mar 13, 2017 at 4:07 PM
    #209
    mountainmonkey
    mountainmonkey Well-Known Member
    Colorado
    '13 Double Cab TRDOR DCSB
    Never enough
    Please add me to the list kind sir.
  10. Mar 13, 2017 at 4:08 PM
    #210
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    I'm using double sided tape but if you can assemble them with your method that sounds great. All will have threaded plates from here on out. I am on the fence about material, aluminum is cheaper and faster for me to cut but the threads are not as strong. Are they strong enough? I think they are but I want to stand by my design and keep everyone happy.[/QUOTE
    Im sure threads should be strong enough.Dont need to make super tight since all its doing is sandwiching the panel
    As far as installing my way just was curious if posible. If I did ofder I would try it that way
    Your design looks solid as it is nice work
  11. Mar 13, 2017 at 4:41 PM
    #211
    override
    override Well-Known Member
    Robert
    2015 DC Tacoma Sport 4x4
    Since you are doing them as a set you could totally do one black and one clear anodized! Though that might be more than your willing to deal with. Anyone who wants to maintain the silver can deanodize them easily with some greased lightening. I used to deanodize all my RC parts with that stuff.
  12. Mar 13, 2017 at 6:56 PM
    #212
    JeffB
    JeffB Well-Known Member
    Jeff
    N.E. CT
    2017 TRD Sport
    OK. you got me thinking about left or right sides, thinking more about it, left may be right!
    I understand about selling both to make it easier for you to get it out the door, No problems.
    I like the bar screw backing you made for the first post but like I said, your machined beauty and me picking out up couple of split and fender washers and maybe some SS/nylon nuts and I'd be fine!
    But, yes there is a BUT, if you could include the black finished screws that would help. There is no way I'd find those at my local Hardware.
    I'm sure you can buy a box of 100 and mark them up 200% and we'd still think it'e a good deal at $.50 a piece!
    Lostsheep[OP] likes this.
  13. Mar 13, 2017 at 7:04 PM
    #213
    Lostsheep
    NorCal
    2015 6spd 4x4 OR
    Let me see what I can do.
    That being said, Mcmaster is your friend. They are not the cheapest but their selection is RIDICULOUS and you can have it next day Admittedly, I am in California and their West Coast distribution hub is in LA so I might just be lucky. I see that you are in Connecticut so I would not be surprised if the Chicago warehouse can provide you with similar service. I routinely get kicked off of their website because I spend too much time perusing what is available and downloading their free CAD files for almost everything they have; apparently they like you to spend money every once in a while in order to use their catalogue and CAD data lol.
  14. Mar 13, 2017 at 7:08 PM
    #214
    Lostsheep
    NorCal
    2015 6spd 4x4 OR
    Would everyone prefer the black finished screws? My biggest concern is providing hardware that is not going to oxidize and look bad. Maintenance-free is a good thing.
    Cost difference is insignificant and it's no big deal for me to take the 200 I have here and add them to my hardware rack, they will get used around here. I'd rather make everyone happy than to worry about $20 in hardware that won't be going to waste no matter what I end up doing with them.
  15. Mar 13, 2017 at 7:16 PM
    #215
    JeffB
    Jeff
    N.E. CT
    2017 TRD Sport
    Yeah, but what are they going to charge me to ship 4 screws compared to what they charge you for a box?
    I haven't looked at their site but I know of them.
    I don't know how they price items.
    My experiencing these places don't like ones, twos, but I could be behind the times.
  16. Mar 13, 2017 at 7:18 PM
    #216
    Bentrodder
    Bentrodder PeeRunner Fanboy
    Peter
    Cotati, CA.
    2015 DCLBFTMFW TRD Sport
    Kings and a TW DECAL!!!
    I got missed! Can you please add me to the list.
  17. Mar 13, 2017 at 7:21 PM
    #217
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    @Lostsheep
    It makes no difference to me what color the screws are. I'm sure once they're installed I'll pay little to no attention to them.
  18. Mar 13, 2017 at 7:22 PM
    #218
    Lostsheep
    NorCal
    2015 6spd 4x4 OR
    Touche', my quasi-educated guess is that you'd be on the hook for the $9 for qty 50 (and you'd be stuck with an extra 46) plus tax and $15 worth of shipping lol. I'll take care of ya...
    I knew I'd miss something...added.
    Bentrodder[QUOTED] likes this.
  19. Mar 13, 2017 at 7:41 PM
    #219
    Drtgrl
    Drtgrl Minus member
    Alana
    Foothills
    2015 MGM Tacoma DCLB
    BAMF sliders with kick up. BAMF all skids. Icons w/ CDC up front. Icon UCA's. All pro expos with 12” kings in rear. Wheelers superbumps. 285 stt pros on black 16" fj wheels. 1" Bora wheel spacers. Relentless tailgate reinforcement. Ditch lights front and rear. Aironboard switches. Aux. bussman box.Center console vault. Esp locking storage. Tuffy bed box. Rear seat molle system. Color matched grill.Rear diff breather mod. ABS switch. PrInSu cab rack. Gusseted spindles.
    I'd prefer black but it's not a make or break. Whatever's easiest on you really. These look great and at an awesome price point! Can't wait to get my hands on them
  20. Mar 13, 2017 at 9:50 PM
    #220
    the dashing ham
    the dashing ham Taco n00b
    Scotty
    Los Angeles
    '12 DCLB rattle can
    yes, I have done the mods
    Not a peep out of me no matter what color comes in the mail, but if you have a choice and it's all the same cost, might as well go black to match the anodizing and the a/c panel.
