RAM question
Discussion in 'Technology' started by 07TacoRidah, Apr 20, 2013.
  1. Apr 20, 2013 at 8:48 AM
    07TacoRidah
    07TacoRidah [OP] SHHHH, this is interesting
    Pasadena CA
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit Xscorpion dual 0g wire ring terminal (3) Big 3 upgrade (0g wiring) HID kit (headlights, H1 - 8k) HID kit (fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails Front grille swap (to chrome, painted w/bedliner paint) XR front bumper valance (dipped red) Aftermarket fog light kit w/OEM switch Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: DJM 3/4" drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Neochrome lock nuts Pepboys valve stem caps Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" JBL GTO 1014 (2) 4 ohm svc in dual ported box JDM Fuchsia shift knob (Crown Royal shift boot)
    just noticed this when I was searching my comp. (attached)
    why this is? I upgraded to a 64 bit OS already, shouldn't it be reading the 4? what happened to the rest of the 1g?
    System -
    MB - Foxconn G33M02
    RAM - 1(2g) ddr2 pc2 6400 stick, 2(1g) ddr2 pc2 6400 sticks
    *NOTE: BOTH 1g sticks are next to each other, the 2g stick is by itself,
    plz to refer to mb config.
  2. Apr 20, 2013 at 9:00 AM
    DevL
    DevL Well-Known Member
    I don't understand... it looks normal to me. Graphics card not used right?
  3. Apr 20, 2013 at 9:03 AM
    07TacoRidah
    Pasadena CA
    that's normal? :confused: what happens to the rest of that 1g? If I upgrade to all 2g RAM sticks, will it only leave out 75% or take out more? I plan on getting it up to 8g.
    not sure what you mean by the graphics card? at the moment I only have my internet browser open.
  4. Apr 20, 2013 at 9:09 AM
    vtrguy
    vtrguy Well-Known Member
    Jarrod
    Chico
    '01 Taco TRD xCab SR5
    Deckplate, Full OME kit, Snugtop Camper, Camry ignition ring, TRD Catback
    If you don't have a dedicated GPU your available ram will always be less.
    The embedded graphics on your motherboard require physical RAM to operate as compared to a standalone GPU that will have it's own onboard ram.
  5. Apr 20, 2013 at 9:09 AM
    DevL
    You use memory for graphics processing if you don't offload it to a discrete graphics card.
  6. Apr 20, 2013 at 9:10 AM
    vtrguy
    Jarrod
    Chico
  7. Apr 20, 2013 at 9:33 AM
    07TacoRidah
    Pasadena CA
    read the link. makes sense now. another question (so I don't start a new thread),
    As of now I have a nVidia GeForce 6200TC (BFG version)
    http://www.xgcdb.com/cards/bfg/nvidia-geforce-6200-tc-32mb-pcie.html
    I do a lot of design work (Adobe programs, some 3d modeling, but to an extent, very minimal video editing, but it is due to my video card). I am using a AOC (vga) 22" lcd monitor, want to upgrade my video card. Nothing fancy, but enough so that when I am rendering or waiting for an effect to settle in (Adobe), I don't have to come back in a couple years.
  8. Apr 20, 2013 at 10:11 AM
    vtrguy
    Jarrod
    Chico
    Are you planning on upgrading your whole system or just parts of it? Personally, I'd get something with somewhere between 512 and 1gb to start from there.
    I've got a 300m series in my laptop with 1gb and I can run more stuff than I'd ever need, granted it also has a few other mods to it but you can pick up a decent card for under $100 for what you are using it for.
  9. Apr 20, 2013 at 7:45 PM
    khx73
    khx73 Well-Known Member
    Saint John NB, CAN
    11 MGM DCLB TRD Sport +leather
    Rear camera anytime switch, 4x4 Illuminated Switch (from rcbs204) , rear view mirror lift bracket (from ImMrYo), 75 cent tailgate anti-theft. Technically not mods but give me a break I'm trying to fill space here... OEM Leather pkg, keyless unlock & ACC chime silence, BakFlip G2, Ultra Gauge EM, WeatherTech floor mats, OEM roof rack
    07Taco .. was it on-board video that was using that ram? If so, now that you've got a dedicated video card, is it reporting the full 4 GB?
  10. Apr 21, 2013 at 7:07 AM
    replica9000
    replica9000 mildly retarded...
    Blackstone Valley
    2008 AC Sport 6spd
    Just remember to disable your onboard GPU if you have a dedicated GPU.
  11. Apr 21, 2013 at 12:32 PM
    07TacoRidah
    Pasadena CA
    just parts here and there. found me a nice SSD on CL but not sure how long that will last :( This rig will be mainly for design and a little video here and there (nothing large scale - at most 30 seconds). Searching for PCI Express x16 vc's - this got me confused
    2G 64 - bit
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814150659
    512mb 128-bit
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814129091
    besides the name brands, which would be better to get?
    no, I have the vga connected to the nVidia vc. Not sure how to do the dedicated vc setting.
    NEVER even tried doing this one. going to see if that helps. I mainly "assumed" that things would go by default or what have you. :(
  12. Apr 21, 2013 at 12:38 PM
    07TacoRidah
    Pasadena CA
    WOW checked and the on board gpu isn't even listed (attached).
  13. Apr 21, 2013 at 5:23 PM
    khx73
    Saint John NB, CAN
    That is what I would expect. When you add a dedicated video card, the integrated ones should automatically disappear. This frees up their resources and avoids causing any conflicts or confusion.
  14. Apr 21, 2013 at 5:28 PM
    replica9000
    Blackstone Valley
    2008 AC Sport 6spd
    That might depend on the bios. Almost any board I've used allows you to use both at the same time if desired, whether it be for hybrid CrossFire/SLI, or just for multi-monitor use, so the onboard GPU might not be disabled automatically.
  15. Apr 21, 2013 at 5:39 PM
    khx73
    Saint John NB, CAN
    True.
    I'm guessing in his case, it just silently shut itself off. Perhaps it is a bios setting where you have the choice of Auto/Enabled/Disabled
  16. Apr 28, 2013 at 9:04 PM
    07TacoRidah
    Pasadena CA
    :eek::annoyed: going to have to see about getting my older brother to handle that part. I'm not too familiar with messing with the bios. I have seen YT vids, but ... this is my only rig right now (a little worried about not having a back up).
