ramonortiz55 4runner build: La Venenosa
Discussion in '4Runner Builds' started by ramonortiz55, Apr 9, 2015.
  1. Nov 18, 2015 at 5:39 AM
    #181
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    :facepalm:
    geekhouse23 likes this.
  2. Nov 18, 2015 at 5:40 AM
    #182
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Come down, lets do it up
  3. Nov 22, 2015 at 11:57 AM
    #183
    4x4runner2002
    4x4runner2002 Well-Known Member
    Zach
    2002 4x4 limited
    suspension and armor
    nice build you have going. what rear bumper are you planning on?
  4. Nov 22, 2015 at 12:33 PM
    #184
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    im still debating it. Idk if to go to shrockworks or CBI.
    Shrockworks is local to me and it would save on shipping. Plus I can leave the runner there to install.
    I am waiting on savage offroad to release their new swingout also.
  5. Nov 22, 2015 at 12:35 PM
    #185
    ramonortiz55
    Ramon
    Texas
    stock
    4x4runner2002 likes this.
  6. Nov 22, 2015 at 12:36 PM
    #186
    4x4runner2002
    Zach
    2002 4x4 limited
    ya i love all the savage stuff. i really like the updated front bumper you have. I'm very interested in his new rear as well, might make the switch and he's local to me.
  7. Nov 22, 2015 at 12:37 PM
    #187
    ramonortiz55
    Ramon
    Texas
    stock
    what do you have as rear bumper right now?
    i really hope his rear bumper is adjustable for body lifts just like the front is.. if it is, I am sold...
  8. Nov 22, 2015 at 12:40 PM
    #188
    4x4runner2002
    Zach
    2002 4x4 limited
    i have the cbi hybrid swing out.
    you have a body lift? I'm just running a 1/2" on mine and my rear bumper still has hit the body. the frame flexes a lot with all that weight back there.
  9. Nov 22, 2015 at 12:45 PM
    #189
    ramonortiz55
    Ramon
    Texas
    stock
    no body lift.. i want the option tho
    have you tried repacing your rear body mounts with sonoran steel mounts? the prevent the body from flexing too much
  10. Nov 22, 2015 at 12:49 PM
    #190
    4x4runner2002
    Zach
    2002 4x4 limited
    no ill check them out, but i really need frame plates because you can see the actual frame flex. if the swing out is open it flexes that side.
  11. Nov 22, 2015 at 1:20 PM
    #191
    ramonortiz55
    Ramon
    Texas
    stock
  12. Nov 27, 2015 at 4:32 PM
    #192
    ramonortiz55
    Ramon
    Texas
    stock
    Installed lights from Baja Designs:
    Haven't been able to get some night shots..but I loooove them!
  13. Nov 27, 2015 at 4:33 PM
    #193
    ramonortiz55
    Ramon
    Texas
    stock
    Also, I was able to pick up a spare cv axle from @Digiratus as a trail spare
    Digiratus likes this.
  14. Nov 27, 2015 at 4:34 PM
    #194
    ramonortiz55
    Ramon
    Texas
    stock
    showing off that leg..
    parked next to grampa today at CVS:
    Detailed her today: Clayed, polished and waxed:
  15. Nov 27, 2015 at 4:37 PM
    #195
    ramonortiz55
    Ramon
    Texas
    stock
    adanfon and Rattletrap66 like this.
  16. Nov 27, 2015 at 4:45 PM
    #196
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Nice, glad to see it got there safe and sound.
  17. Nov 27, 2015 at 4:56 PM
    #197
    ramonortiz55
    Ramon
    Texas
    stock
    It's hard to find spares down here on CL and I really don't have time to rummage around at a junk yard. So I thank you for taking the time in boxing it up and sending it down here.
    I might grab the other two where you tagged me on.
  18. Nov 27, 2015 at 4:59 PM
    #198
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    :woot: same one I have!
  19. Nov 27, 2015 at 5:03 PM
    #199
    ramonortiz55
    Ramon
    Texas
    stock
    also did the rear differential breather relocate..just in case we cross any deep rapids
    :spy:
    Rattletrap66 likes this.
  20. Nov 27, 2015 at 5:31 PM
    #200
    ramonortiz55
    Ramon
    Texas
    stock
    Today I relocated the rear differential breather. These parts were courtesy of @Unchained 5150 . Rick, you will always be a part of my 4runner build buddy.
    The parts needed were:
    Toyota parts:
    Union part: 90404-51319
    Breather: 90930-03136
    One hose clamp
    Teflon tape
    about 6 feet of transmission hose. I went to autozone and asked them to provide some hose that fit the Toyota breather fittings. Took the fittings with me so they could give me their best fitting hose.
    Here are the parts pictured:
    Made sure to Teflon the threads on the union part. I fitted the parts into the hose to stretch it out and allow ease of installation once I was under the 4runner.
    On the driver's side rear wheel well, I located the fuel filler neck dust cover. I removed the lower clip that holds the fuel filler neck dust cover:
    Next I popped open the fuel gas door.
    This allowed me to grab a knife and cut a small hole small enough in the rubber surround to hold the breather fitting but large enough to allow me to fish the hose thru.
    I reached behind the fuel filler neck dust cover and pulled the hose thru
    The hole I made in the rubber surround of the fueling port is tight enough to hold the hose in. I didn't clamp this end since the hose was a very tight fit. I had to dab the fitting with some light oil to get it in the hose.
    I then fished the hose to follow the fuel lines and what not..
    I then located the existing breather:
    Removed it and installed the new union part. Make sure to Teflon!
    I went ahead and attached the hose and clamped this end.
    I allowed enough slack to make sure there is enough hose to reach during articulation by matching the length of my extended brake lines.
