ramonortiz55 4runner build: La Venenosa - For Sale!
Discussion in '4Runner Builds' started by ramonortiz55, Apr 9, 2015.
  1. Feb 1, 2016 at 3:43 PM
    #381
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    Glad to hear you liked it!!
  2. Feb 1, 2016 at 3:44 PM
    #382
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Thanks! I loved how it turned out.
    I left the winch power unplugged at the battery. I have heard to many horror stories of solonoids shorting out. Figured I only use the winch when I am stuck or helping someone out, it wouldnt hurt to take some time and connect one wire at each post of the battery.
  3. Feb 1, 2016 at 3:44 PM
    #383
    ramonortiz55
    Ramon
    Texas
    stock
    I love it!
  4. Feb 1, 2016 at 3:53 PM
    #384
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Have you seen these?
    http://www.ebay.com/itm/Authentic-A...52c7d32&pid=100005&rk=2&rkt=6&sd=270508866500
  5. Feb 1, 2016 at 5:56 PM
    #385
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Looks good Ramon! You still coming in March? We could be Tepui Twins
  6. Feb 9, 2016 at 8:54 AM
    #386
    ramonortiz55
    Ramon
    Texas
    stock
    my wife didnt get the day off. I doubt ill be able to make it :(
  7. Feb 9, 2016 at 8:54 AM
    #387
    ramonortiz55
    Ramon
    Texas
    stock
  8. Feb 9, 2016 at 8:56 AM
    #388
    ramonortiz55
    Ramon
    Texas
    stock
    In this write up I have decided to provide pictures and brief instructions on how to change the differential and trasnfercase oil for an automatic 3rd gen 4runner.
    My case is a 2001 4runner limited, all 3rd gen 4runners are similar therefore, these instructions will be the same for other years within the same generation.
    I am using Amsoil gear oil, the gear oil you choose will be left at your discretion.
    I picked up a pump for the Amsoil gear oil bottle at my local O'reillys. Here is what I picked up, works perfectly for the Amsoil bottle:
    I also picked up new drain and fill plugs. The drain and fill plugs are soft metals, meaning they could strip easily. I figured if these were the original drain plugs, I put in new ones with "fresh" metal, per se.
    Also, some of the plugs appeared slightly stripped due to a previous gear oil change from the original owner.
    If you do not replace the drain and fill plugs, I do recommend replacing the crush washers.
    A 24MM socket is used to remove the differential and transfercase drain and fill plugs.
    A 12MM socket is used to remove the bolt holding the hand brake cable bracket that is running right across the fill plug on the rear differential:
    Rear differential:
    Remove the bolt holding the brake cable that blocks the fill plug (not pictured), but its location is highly obvious.
    Once the brake cable is out of the way, remove the fill and drain plug.
    Make sure to have a pan handy to catch the oil:
    Once the oil has been drained, inspect the drain and fill plug:
    The drain plug has a magnet that catches shavings from the gears. Anything out of the ordinary would be noted here.
    No gear teeth or large chunks of metal, just small shavings, which is normal.
    Thread the new drain plug, ensuring that the crush washer is installed.
    Using your handy hand pump, stick the end of the tubing into the differential and start pumping away:
    Pump fluid into the differential until you see a steady stream of gear oil flow out of the fill hole:
    Plug it up and you are done with the rear differential. Make sure the crush washer is on the fill plug.
    Now we go to the transfercase:
    Locate the drain and fill plugs, drain plug:
    Fill plug:
    Remove the fill plug first, then the drain plug:
    Once the fluid has been drained, install the new drain plug and start filling the transfercase with new gear oil.
    Again, you will know when the transfercase is full when you see a nice steady stream pour out of the fill plug.
    Set the fill plug, and you are now complete with the transfercase:
    Now, we will move on to the front differential. In order to access the drain and fill plugs, the skid plate will have to be removed.
    Once the skid plate has been removed, you will notice the fill plug on the front of the differential:
    The drain plug is below:
    These plugs require a 10MM or a 12MM hex to remove. Please confirm sizing, I needed to use a 10MM hex for both drain and fill plugs. Some have used a 10MM for the fill and 12MM for the drain.
    Remove the fill plug first (not pictured), then remove the drain plug.
    Removing the drain plug:
    Comparing the drill and fill plugs with the new set. Again, check for any abnormal shavings on the magnet of the drain plug.
    Once the front differential is fully drained plug the drain and proceed with filling:
    Again, the differential is full when you see a steady stream of differential oil flow out of the fill hole.
    Once the differential is full, set the fill plug:
    Axion, BYJOSHCOOK and Shmellmopwho like this.
  9. Feb 9, 2016 at 9:06 AM
    #389
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    I like that pump!! As we all know it's a pain to do it by the bottle haha
  10. Feb 9, 2016 at 9:12 AM
    #390
    ramonortiz55
    Ramon
    Texas
    stock
    Drove out to the Citrus meet this past weekend.
    Photo dump:
    Took us over 2000 miles round trip:
    Averaged about 250 miles per tank. I had an RTT, a loaded vehicle with gear and was driving against the wind:
    I seriously need to learn how to manage my cargo:
    BYJOSHCOOK likes this.
  11. Feb 9, 2016 at 9:13 AM
    #391
    ramonortiz55
    Ramon
    Texas
    stock
    pump was awesome! lol..I cant imagine how it would be done with just a bottle..
    Shmellmopwho[QUOTED] likes this.
  12. Feb 9, 2016 at 9:16 AM
    #392
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    I have a tube and funnel and poor the bottle into the funnel. Works but is hard to control both lol
  13. Feb 9, 2016 at 8:39 PM
    #393
    Digiratus
    Roaming the PNW
    The RedHead
    The specs on them say 175 amps. I presume that is a continuous number, not peak. :notsure:
    To me, what you measure by is that wire size specs. If your winch is like mine, it came with 4 gauge wire. a 5-6' run of 4 ga is rated at ~200 amps.
  14. Feb 15, 2016 at 1:15 PM
    #394
    ramonortiz55
    Ramon
    Texas
    stock
    moar lights!
    get on it @Rattletrap66
    Thanks to Bailey @Baja Designs for putting up with my endless questions in regard of the lights. Finally purchased a third one to install in the middle.
    Rattletrap66 likes this.
  15. Feb 15, 2016 at 1:17 PM
    #395
    ramonortiz55
    Ramon
    Texas
    stock
    ARB awning came in:
    @mr optimist and I jumped on a good deal on autoanything:
  16. Feb 15, 2016 at 1:24 PM
    #396
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Ok I'll order tonight :D
  17. Feb 15, 2016 at 1:27 PM
    #397
    ramonortiz55
    Ramon
    Texas
    stock
    you saw that output ;)
    Rattletrap66[QUOTED] likes this.
  18. Feb 15, 2016 at 1:28 PM
    #398
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Yes man, freaking insane compared to my cheapos. And I just so happen to have a gift card to All Pro :woot:
  19. Feb 15, 2016 at 2:08 PM
    #399
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    damn, add some links to this thing o_O
    Which Baja Designs Lights do you have? I am looking at getting these
  20. Feb 15, 2016 at 2:12 PM
    #400
    ramonortiz55
    Ramon
    Texas
    stock
    i have been meaning to add links .. lol
