ramonortiz55 4runner build: La Venenosa
Discussion in '4Runner Builds' started by ramonortiz55, Apr 9, 2015.
  1. Oct 24, 2016 at 8:59 AM
    #461
    JWaldz
    JWaldz It puts the Joe Dirt in the hole
    Waldo
    Colo Springs
    99 4Runner LTD
    This build is fruitier than a fruit cake
  2. Oct 24, 2016 at 9:01 AM
    #462
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Pineapple upside down fruit cake? :hungry:
  3. Oct 24, 2016 at 9:03 AM
    #463
    JWaldz
    Waldo
    Colo Springs
    99 4Runner LTD
    with two coconuts on the side and a banana down the middle
  4. Oct 24, 2016 at 9:04 AM
    #464
    ramonortiz55
    Ramon
    Texas
    stock
    don't forget shredded coconut around the banana and coconuts
    JWaldz likes this.
  5. Nov 3, 2016 at 12:13 PM
    #465
    ramonortiz55
    Ramon
    Texas
    stock
    Last weekend I decided to clean the throttle body on my 4runner.
    Decided to document the procedure In hopes it would benefit someone who likes do things on their own:
    For this task, I picked up some throttle body cleaner, a rag, and my wife's toothbrush:
    One of the most important steps in this procedure is to stare down the throttle for a good 2 or 3 minutes. This helps break down the carbon inside. The harder you stare, the more it breaks down and easier it is to clean. Sorta like WD-40 loosens up rusted nuts and bolts.
    First step is removing the airbox assembly, loosen airbox bolts and straps:
    unplug mass airflow sensor and any other connectors in the vicinity:
    There will be a smaller airbox towards the firewall with some airlines connecting into it, remove the airhoses and the small airbox:
    Don't forget the airhoses that run towards the front of the engine towards the piping of the airbox:
    Loosening these thinner clamps will help removing the piping to the airbox:
    Remove another plug, this one is right besides the accelerator cable:
    Three cooling lines will be feeding into the throttle body, these can be removed also:
    Another plug:
    Remove the accelerator cable off the throttle, this can be done by clocking the body of the spring and sliding it out carefully:
    Another picture of everything removed:
    Remove the two top nuts that are holding the throttle in position:
    Now remove the bottom bolts that are holding the throttle in position:
    Pull off the throttle gently:
    Take it to the operating table:
    Generously spray inside the throttle body with cleaner and brush the carbon off with your wife's toothbrush and rag:
    Carefully rotate the "door" to make sure all the carbon buildup has been cleaned out.
    If you aren't bleeding, you aren't done:
    Once you are satisfied with the removal of carbon, installation is reverse of removal.
    boostedka and BYJOSHCOOK like this.
  6. Nov 3, 2016 at 1:19 PM
    #466
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Build
    "my wifes toothbrush" and "if you aren't bleeding, you aren't done" :rofl:
    I love it ha
    ramonortiz55 [OP] likes this.
  7. Nov 15, 2016 at 11:35 AM
    #467
    ramonortiz55
    Ramon
    Texas
    stock
    Loose Shifter: Part number 90385-11003 x 4
    ARB Drawers interior dimensions:
  8. Nov 16, 2016 at 3:20 PM
    #468
    JWaldz
    Waldo
    Colo Springs
    99 4Runner LTD
    Making a note for yourself?
  9. Nov 16, 2016 at 3:20 PM
    #469
    ramonortiz55
    Ramon
    Texas
    stock
    Yes. lol
    JWaldz likes this.
  10. Nov 18, 2016 at 1:35 PM
    #470
    ramonortiz55
    Ramon
    Texas
    stock
    The illumination bulbs were out on my AC controls, ECT, rear window button, rear defroster, and power point.
    This is a write up on the step by step process I took to replace the bulbs.
    My research was done here: ***************************************************************************
    After reading thru those threads, I determined I needed the following part numbers. These are for a 2001 4runner, the bulbs for other 4runner generations might be different.
    2001 4runner limited climate control light bulbs:
    Part Number #81850-35050 - 2 Total
    Part Number #81850-35040 - 2 Total
    Hazard control light bulb:
    Part Number #84999-10860 - 1 Total
    ECT and Defroster light bulb:
    Part Number #90010-01041 - 1 Total
    Rear window roll down:
    Part Number #90010-01042 - 1 Total
    Cigarette lighter:
    Part Number #84999-10250 - 1 Total
    Ordered all my bulbs from Camelback Toyota:
    Removing the center console cup holder, this is done by tugging it off:
    Then removing the shifter surround:
    Next, the radio surround is removed, gently pry it away from the dash:
    Pull it out slowly to reveal the plugs by the ac vents:
    Unplug the power point plugs:
    Once the power point plug connector has been removed, locate the bulb - it is the gray end of the power point:
    Twist to remove:
    Next, I removed the hazard switch:
    This is done by releasing the side tabs:
    Next, I removed this portion:
    This is done by releasing tabs at the ends AND at the top center:
    Next I removed the AC controls faceplate, tabs are on top. This is very flimsy, so careful:
    I then removed the screws that hold in the AC control unit, disconnected the rear plugs and pulled it out:
    At this moment, I went ahead and installed the power point bulb:
    Time for some surgery. Hazard switch:
    Twist and pull out the bulb, replace with new one:
    Now the strip, this has two bulbs. One for defroster and ECT, another bulb for the rear window switch:
    A needle nose pliers will allow the removal of one of the bulbs.
    To remove the other, the backing must be removed, a small flat head screwdriver helps here. I then removed the other bulb and replaced it.
    Next step of the surgery was to open the front of the AC control unit. I removed two screws. FOUR tabs need to be released on the top and bottom. Forks or toothpicks help keeping tabs open while I worked on other tabs.
    Carefully opened the AC control unit..
    Bulbs removed and replaced:
    I then assembled the AC control unit together.
    Reinstalled everything back together.
    Finally have all my illumination working properly!
  11. Dec 19, 2016 at 8:16 AM
    #471
    ramonortiz55
    Ramon
    Texas
    stock
  12. Dec 19, 2016 at 8:50 AM
    #472
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
  13. Jan 12, 2017 at 8:44 AM
    #473
    ramonortiz55
    Ramon
    Texas
    stock
    Decided to do a detailed writeup for swapping the valve cover gaskets on my 2001 4runner.
    This job took me nearly two days - It was my first time doing this and I do like to take my time while working on cars. I've been known to start working on a car, leave it alone and come back and finish it a few days later. LOL.
    I know some of you are not as patient as me, I just am never in a rush when working on cars.
    So this it the list of items needed with Toyota Part numbers:
    1. Valve cover gaskets - Part #11213-62020 - 2 Total
    2. Spark Plug Tube gaskets - Part #11193-16010 - 6 Total
    3. Intake Plenum Gaskets - Part #17176-62040 - 2 Total
    4. Washer Seals - Part #90210-05007 - 16 Total
    5. Camshaft Plugs - Part #11188-62010 - 2 Total
    6. Halfmoon Plugs - Part #11183-62010 - 4 Total
    7. PCV Valve Grommet - Part #90480-18001 - 1 Total
    8. Toyota FIPG seal packing - Part #00295-00103 - 1 Tube
    **Throw the PCV Valve Grommet and Spark Plug Tube Gaskets in the Freezer a night before. I will explain why later**
    Mandatory parts picture:
    My research links: http://www.yotatech.com/f2/5vzfe-leaky-valve-covers-fixed-56k-beware-149594/
    Now let's tackle this job!
    Another plug:
    Pull off the throttle gently, pay real close attention how the metal gasket is oriented. It needs to go back the same way or your truck will explode:
    Next, we will remove the upper intake manifold. Make sure to give it a good stare before you start. Nice, hard, evil stare. You're going to own that intake manifold. It's yours. Touch it. Feel it. Be the Manifold:
    To remove it loosen these brackets that hold the speedometer cable:
    and these other brackets that are on the driver's side of the manifold. (the bracket with the blue paint might need to be removed from the other end if you cant fit a ratchet at the upper bolt):
    disconnect this hose at the far end of the manifold, on top:
    Next, remove all the other bolts that hold down the intake manifold - Not pictured. Manifold should then come off.
    Now time to remove the lower intake manifold -
    If for some reason you couldn't take the speedometer bracket off due to it being too congested, you can take it off now:
    This stainless tubing has hose attached to the ends, take off the hose. I didn't have to remove the tubing itself, just the hose.
    Remove the computer diagnostics port that is attached on the driver's side of the manifold:
    At the back of the lower intake manifold, there is a bolt holding the wiring harness, remove it.
    At this time, the bolts holding the lower intake manifold can now be removed.
    Remove the remaining bolts holding the lower intake manifold down:
    Once the lower intake manifold is removed, cover up the exposed intake chambers with a rag, tape, etc to prevent stuff from falling in there. You do NOT want a bolt falling in there. Might as well jump off a bridge:
    Moving onto the passenger side valve covers, remove the spark plug wires and coil packs:
    disconnect the injectors:
    Remove the bolts holding down a wire bracket - This will not be able to be removed completely, but taking the bolts off will make the job easier. It will give you room to work with.
    At this time, the valve cover can be removed:
    So beautiful, so clean. Thanks to frequent oil changes :)
    At the end of the engine heads there will be a wiring harness attached to a bracket, close to where my hand is at. If you feel around, you will find it. This will need to be removed:
    Looks like this:
    There are two halfmoon plugs per side:
    one in the front:
    one in the back:
    one camshaft plug in the back that is being held down by two bolts:
    The halfmoon plugs can be removed with some channel locks. Gently pry upward. UPWARD. You may wiggle a little. Just not much. Don't want to crack the head. :anonymous:
    Removed:
    Remove the camshaft plug:
    At this time, make sure your supervisor approves your work:
  14. Jan 12, 2017 at 8:44 AM
    #474
    ramonortiz55
    Ramon
    Texas
    stock
    After you have received supervisor approval, clean off the old gasket material using any scraping tool. Make sure to scrape well in the areas where the halfmoon and camshaft plugs go:
    After that is done get your valve cover and flip it over. The spark plug tube gaskets will now be replaced:
    Grab a small screwdriver and tap the gasket from the other side:
    Pull out the PCV grommet:
    Now remove the old washers seals:
    I did this by tapping it from the other end with a small flat head screwdriver:
    At this point, go back to the freezer and grab the THREE replacement gaskets and the PCV grommet:
    Pop the new PCV grommet in:
    Pop the new replacement gaskets in. Some people use a large socket to get them to sit right. Since I froze them, they were able to shrink. Making my job easier:
    Sit the new valve cover gasket carefully:
    Notice the areas that will need seal packing, this is where the FIPG goes. Be generous. Don't skimp out, you want a nice noticeable ooze when you sit it on the head:
    Install with new camshaft plug:
    Now goes the halfmoon plugs:
    Same procedure, a nice noticeable ooze:
    The Toyota manual indicated to add extra FIPG to the indicated locations:
    I made sure it was on there :D
    Set the cover on carefully:
    Torque the valve cover bolts down to
    The procedure for the driver's side is the same as the left, with the exception of a wiring harness section going above the valve covers:
    I didn't chase down the harness to see what it was for, I just worked around it.
    Once the driver's side is done, install everything as it was removed. Replace the plenum gaskets between the manifolds.
    Done!
    boostedka and omaguz like this.
  15. Jan 31, 2017 at 7:04 AM
    #475
    MattJakobs
    MattJakobs Well-Known Member
    Matthew
    Walnut Creek, CA
    2001 Stellar Blue 4Runner
    Why'd you do that?
  16. Jan 31, 2017 at 7:07 AM
    #476
    ramonortiz55
    Ramon
    Texas
    stock
    I did it so you could ask me why I did it..
  17. Jan 31, 2017 at 7:07 AM
    #477
    ramonortiz55
    Ramon
    Texas
    stock
    lol in all seriousness, what you talking about?
  18. Jan 31, 2017 at 7:13 AM
    #478
    MattJakobs
    Matthew
    Walnut Creek, CA
    :spy::spy:
  19. Feb 7, 2017 at 10:57 AM
    #479
    ramonortiz55
    Ramon
    Texas
    stock
    picked up some accessories for finishing a simple OBA
    ChandlerDOOM and MattJakobs like this.
  20. Feb 7, 2017 at 2:35 PM
    #480
    ramonortiz55
    Ramon
    Texas
    stock
    @JimBeam :spy: :anonymous:
    TacoTRD78 and JimBeam like this.
