Ramp - Which one ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by george3, Sep 12, 2010.
  1. Sep 12, 2010 at 2:22 PM
    george3
    george3 [OP] Well-Known Member
    new jersey
    tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I'd like to get some ramps to change the oil, grease the zerks etc. What ones do you guys like, use, don't like - mistake to buy. Thanks for any help - don't want to buy them and find I wasted my $. I did read some reviews of the plastic ones on Amazon and it said they move forward when you try to drive up on them and the rubber on the bottom that is supposed to keep them from moving rips off. Thanks for any help. Curious George.
  2. Sep 12, 2010 at 2:27 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Eh the rhino ramps I got at autozone long ago work just fine for me. I've used them on both of my tacomas, 280z, and dodge stealth..
  3. Sep 12, 2010 at 2:56 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    I got mine from Walmart and they work great.
  4. Sep 12, 2010 at 3:09 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    X2 on the rhino ramps. We have a set that we use for the vette.
  5. Sep 12, 2010 at 4:04 PM
    george3
    new jersey
    tacoma
    So not to worry about the reviews on the rhino ramps that said they move forward when you try to drive up on them and the rubber on the bottom that is supposed to keep them from moving rips off ? Thanks Curious George
  6. Sep 12, 2010 at 4:05 PM
    george3
    new jersey
    tacoma
    Janster, do you use them on the Tacoma ?
  7. Sep 12, 2010 at 4:06 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    depending on the surface you have the ramps set on.....quite a few of them will move sometimes. my old ramps from wal-mart have worked fine for me for years, but on my garage floor(concrete)....they have a tendency to move some. you can actually cut some small pieces of fuel line ....split them in half on one side and put on the ramp lips to keep them from sliding much. works pretty good.
  8. Sep 12, 2010 at 4:13 PM
    george3
    new jersey
    tacoma
    Thanks for the hint. Would be a PITA trying to get up and merely pushing them. Curious George
  9. Sep 12, 2010 at 4:22 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no prob.
  10. Sep 12, 2010 at 4:48 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    I've had mine push forward a tad with a seabring (bumper actually was pushing it because of height). Never was really an issue though, if you go slow and steady they work just fine. Also with a taco (trd at least, probably sr5, of course not an x) you could drive completely over it and it wouldn't hurt anything due to the height.
  11. Sep 12, 2010 at 4:53 PM
    george3
    new jersey
    tacoma
    Man, I don't want to drive over it but good 2 no. Thanks. Curious George
  12. Sep 12, 2010 at 4:59 PM
    JasonJump
    JasonJump Well-Known Member
    Yukon Oklahoma
    '05 Tacoma TRD Sport 4X4 D Cab Debadged
    Billy 5100's set at 2.5, iPhone innerface, TRD Sport wheels powdercoated Anthracite grey wrapped in 265/70/17 Duratracs, Custom Sliders
    Sorry this is a dumb question, but are you guys using one set of ramps and just proping up the front? Or two sets and driving up both at once? Obviously because I thought you were suppose to be on an even surface...
  13. Sep 12, 2010 at 5:03 PM
    george3
    new jersey
    tacoma
    Wow ! That sounds exciting but I don't think I've got the testicular fortitude to try it. Has anyone else ? Curious George
  14. Sep 12, 2010 at 5:07 PM
    Larry
    Larry CARL
    CARL
    I don't need ramps to change the oil on my Tacoma. The truck is stock and I can slide under with ease to drain the pan.
  15. Sep 12, 2010 at 5:10 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    On most vehicles the drain bolt is on the back angle of the engine.... so if you have a slight incline of the front propped up it's a non-issue. However on a vehicle like my stealth with the transverse engine, I back into my driveway, then drive forward onto the ramps and due to the incline of my driveway, it's actually almost dead nutz even.
    Also, even if you don't get 100% of the oil out, in fact you never will and you shouldn't anyway... it doesn't hurt. Changing 95% of it will dillute the other 5% through the new stuff barely causing any cross contamination anyway. If you were able to get every single last drop out, you wouldn't have any lubrication on the crank when you first start it up.... and that would be bad.
  16. Sep 12, 2010 at 5:12 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Also this :p
    Though not with ease for me, I do like having the additional little height... so quick with a ramp it's no big deal.
  17. Sep 12, 2010 at 5:18 PM
    george3
    new jersey
    tacoma
    Man you must be slim and trim. I'm 5'10'' and weigh 185. I changed my oil and did the zerks last week and it was a struggle to get in position to remove the filter on my 2.7.
  18. Sep 12, 2010 at 5:19 PM
    Larry
    Larry CARL
    CARL
    Story of my life
    I'm growing older but not up. lol
  19. Sep 12, 2010 at 5:21 PM
    Larry
    Larry CARL
    CARL
    5-8 and 165
    And I'm a little overweight. I need to loose 10 or 15
    And the 4.0 filter is topside. :D
  20. Sep 12, 2010 at 5:23 PM
    george3
    new jersey
    tacoma
    "you wouldn't have any lubrication on the crank when you first start it up"
    I fill up the filter on the bench B 4 I install it to help with this.
