Rampage off-road LED lighting ON SALE!! Ends 4/5/14
Discussion in 'Closed Group Buys' started by RelentlessFab, Mar 15, 2014.
Thread Status:
Not open for further replies.
  1. Mar 17, 2014 at 5:38 PM
    RelentlessFab
    RelentlessFab [OP] Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Yes, through the rubber trim in the gutter and uses the factory inserts on the Double Cab's. Hardware included, just need to drill 2 small holes through the rubber for the bolts to go down through and thats all the mods necessary
  2. Mar 17, 2014 at 7:15 PM
    Traction120
    Traction120 "Not all those who wander are lost"
    Nathan
    Reno, NV
    2013 DCSB BLK
    SEE BUILD.
  3. Mar 18, 2014 at 5:45 AM
    kwelklin
    kwelklin Well-Known Member
    Northeast Michigan
    15 TRD OFF-ROAD DC
    Got it thanks!
  4. Mar 18, 2014 at 9:25 AM
    mmarino
    mmarino Well-Known Member
    Northwest
    13 TRD OR
    OME Suspension with Dakars, NWTI bumpers, BAMF Sliders, Color matched grill, Centruy cap, Relentless Hi-Lift Bracket, HID headlights & foglights, PIAA fogs, 42" Rampage radius LED bar, Wet okole seat covers, Console & glove box organizers, AFE pro dry filter
    Just ordered the 42" radius bar, roof mounts and a high lift bed rail mount. I've been wanting to pull the trigger on these items for a long time and this GB was the motivation. Thanks for the help over the phone and thanks again for the GB!
  5. Mar 18, 2014 at 9:38 AM
    RelentlessFab
    Eric
    Sparks, NV
    No problem and thanks for the order Matthew!
  6. Mar 18, 2014 at 10:39 AM
    Traction120
    Nathan
    Reno, NV
    2013 DCSB BLK
    SEE BUILD.
    BUMP!
    Light up!
  7. Mar 19, 2014 at 8:42 AM
    RelentlessFab
    Eric
    Sparks, NV
    Morning bump. :)
  8. Mar 19, 2014 at 10:50 AM
    jwilly
    jwilly Well-Known Member
    Jeremy
    Charlotte, NC
    iPhone mount in cupholder, aFe Pro-Dry S Air Filters, Truxedo cover
    Will the regular 32" fit in the lower grill on a '13? If so I am ready to pull the trigger
  9. Mar 19, 2014 at 11:33 AM
    RelentlessFab
    Eric
    Sparks, NV
    Pulled some measurements, based on what I can see, it looks like it should be tight but just fit in there. What mount were you going to use?
  10. Mar 19, 2014 at 11:51 AM
    Traction120
    Nathan
    Reno, NV
    2013 DCSB BLK
    SEE BUILD.
    It'll fit :cool:
  11. Mar 19, 2014 at 12:14 PM
    jwilly
    Jeremy
    Charlotte, NC
  12. Mar 19, 2014 at 12:24 PM
    RelentlessFab
    Eric
    Sparks, NV
  13. Mar 19, 2014 at 5:07 PM
    4x4Taco09
    4x4Taco09 Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    Im interested in a radius bar. Im trying to make a roof bar work with my roof rack, so more than likely ill have to fab my own brackets. I wonder if I could trim my roof rack to accommodate your brackets? I know that it has to be possible
    is 447 the total for a 50" radius shipped? or plus shipping?
  14. Mar 19, 2014 at 9:48 PM
    paquu
    paquu Well-Known Member
    RI
    02 doublecab fj trm rims, roof led bar
    42" LED bar
    Lets say I'm interested in a 42" radius for a 02 double cab. Double cabs have roof gutters. Would the mounting brackets be fastened via the roof gutter or behind the weatherstrip within the body door frame? I'd rather not drill directly into the roof.
    also, when will the GB run until?
    finally, how are we to order the lights with the 1st gen mounts if they aren't available on the site?
    Thanks!
  15. Mar 19, 2014 at 9:56 PM
    #35
    Traction120
    Nathan
    Reno, NV
    2013 DCSB BLK
    SEE BUILD.
    It's definitely possible to make a radius work with the rack, I've seen a few.. As for the brackets we make, no way to be sure.. They mount using M6 bolts to the four OEM holes in the front, on top of the rubber seal (rubber requires two holes drilled into both sides.) if that is where your rack mounts in the front, it may be possible to mount the bar directly to the front of the rack.
  16. Mar 19, 2014 at 10:01 PM
    #36
    Traction120
    Nathan
    Reno, NV
    2013 DCSB BLK
    SEE BUILD.
    I'm sure Eric will clarify how the mounting will work for your truck. I know there are OEM holes in the DC 1st gen tacos, and for the same reason. We are still in the process of developing the 1st gen mounts, but will be available. Just note your interest in the mounting brackets in the notes area of the cart, and we will get ahold of you. The brackets would most likely be very similar to the 2nd gen mounts. Sale ends on April 5th 2014.
    Nathan
  17. Mar 19, 2014 at 10:16 PM
    #37
    mac424205
    mac424205 Well-Known Member
    Mathew
    Chelsea
    2005 4Runner Limited V8 4X4
    Billies on all four corners with daystar spacer lift. Bought it like this. Replacing done with toytec ultimate 3" lift
    Will the mounts work on a 4th gen or did I read y'all were working on those? I'm stuck between an actual lift, I have a spacer lift now, or an LED bar. The wife have me $500 to spend. Lol. I already have the billies on all four corners so I can swing new coils for the front and rear with extended break lines. :D or I can get a 42" bar and some spot and flood lights.
  18. Mar 19, 2014 at 10:40 PM
    #38
    Traction120
    Nathan
    Reno, NV
    2013 DCSB BLK
    SEE BUILD.
    We are definitely working on mounting on anything we can get our hands on. Eric has a 3rd & 4th gen. We have access to 4 generations of t4rs (1st-4th,) and I'm sure we will have mounts for the 4th gen first, as this is his GFs DD. If I'm not mistaken, I believe the 4th gen t4r has very similar OEM holes as the taco. Check out the first page of the thread as well, there is a pic of a 3rd gen, but with what looks like door-jam style mounting brackets.
    Rampage light bars also come with standard mounting brackets free of charge, but will require drilling in most situations.
  19. Mar 19, 2014 at 11:03 PM
    #39
    paquu
    RI
    42" LED bar
    Gotcha on the note and the end of sale. Where are the OEM holes? I've looked for these holes in the past when I thought of fabricating and mounting a roofrack. They'd be within the gutter right? Maybe I'm just blind?
  20. Mar 20, 2014 at 8:37 AM
    #40
    Traction120
    Nathan
    Reno, NV
    2013 DCSB BLK
    SEE BUILD.
    So to clarify, this morning we realized that Eric's 2005 also does not have the holes. So you are not blind. But we are still going to develop mounting! Stay tuned and get your orders in!
Thread Status:
