Rampage off-road LED lighting ON SALE!! Ends 4/5/14
Discussion in 'Closed Group Buys' started by RelentlessFab, Mar 15, 2014.
Thread Status:
Not open for further replies.
  1. Mar 30, 2014 at 6:21 PM
    #121
    Traction120
    Traction120 "Not all those who wander are lost"
    Nathan
    Reno, NV
    2013 DCSB BLK
    SEE BUILD.
    If you would like the flush mounted Qs in the front, you will order the Fcube pair, and when it comes time to order your front bumper, call, or make a note that with your square wing cut-outs, you would like no recessed mounting and that you would like the holes cut to fit the flush mounted cubes :cool:
    Hope this helps
  2. Mar 30, 2014 at 6:35 PM
    #122
    suttonkb
    suttonkb GO TIGERS!
    Kevin
    Clemson, SC
    2003 Tacoma SAS incoming
    wondering if the curved 42" or regular 42" will work with the oem roof rack. is there a pic of the curved 42" mounted on a 2nd gen? once i figure out which i want(curved or straight), i'll order it.
  3. Mar 30, 2014 at 6:46 PM
    #123
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Thanks for the pic. It doesn't look bad I just meant that the pic in the OP was hard to tell the angles and actual size so I just wanted a different perspective. This helps alot thanks
  4. Mar 30, 2014 at 6:50 PM
    #124
    Traction120
    Nathan
    Reno, NV
    2013 DCSB BLK
    SEE BUILD.
    All good, the radius is mounted exactly as pictured. Crappy weather here today, but I'll take more pics, and at different angles this week.
  5. Mar 30, 2014 at 6:53 PM
    #125
    Traction120
    Nathan
    Reno, NV
    2013 DCSB BLK
    SEE BUILD.
    We haven't developed mounts for the OEM rack yet, but.. In MY personal opinion, the straight combo 42 would look best in front of the rack.
  6. Mar 30, 2014 at 7:11 PM
    #126
    suttonkb
    suttonkb GO TIGERS!
    Kevin
    Clemson, SC
    do you have any pics of the curved in action? i think you might be right, the straight would look good mounted in between the oem rack
  7. Mar 30, 2014 at 7:27 PM
    #127
    RelentlessFab
    RelentlessFab [OP] Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I'll have some in the next few days.
  8. Mar 30, 2014 at 7:32 PM
    #128
    suttonkb
    suttonkb GO TIGERS!
    Kevin
    Clemson, SC
    Thanks Eric. I'm thinking one of your bars would make my pics on Instagram much better lol
  9. Mar 30, 2014 at 7:34 PM
    #129
    suttonkb
    suttonkb GO TIGERS!
    Kevin
    Clemson, SC
    Let me know before Thursday. I leave for Malaysia for 3 weeks and I'd love to have it waiting in me when I get back :)
  10. Mar 30, 2014 at 7:39 PM
    #130
    PnoyBOS5
    PnoyBOS5 Well-Known Member
    kevin
    CA
    2013 PRERUNNER
    Maxtrac 4'' Spindes -Bilsteins 5100 @ 1.75" - All Pro Expo Leaf Pack - Extended Rear Shocks - PC 5001 wheels - 285/70/17 Goodyear Duratracs - Debadged -Red emblem - AFE Pro Dry-S Filter
    So for the DR42 we have to drill deeper in the pre-existing holes or is it plug and play?
  11. Mar 30, 2014 at 8:02 PM
    #131
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    I most likely will be ordering the curved 42 inch with the brackets, but my only concern is hiding the wire along the side of the windshield. Have you been able to hide it well or does it stick out? I looked at mine today and its a tight fit.
  12. Mar 30, 2014 at 8:07 PM
    #132
    Traction120
    Nathan
    Reno, NV
    2013 DCSB BLK
    SEE BUILD.
    No need to drill the holes deeper. Only through the rubber weather stripping. The supplied bolts thread right into the pre-existing holes.
  13. Mar 30, 2014 at 8:10 PM
    #133
    PnoyBOS5
    kevin
    CA
    2013 PRERUNNER
    Oooohhh hellz ya!
  14. Mar 30, 2014 at 8:10 PM
    #134
    Traction120
    Nathan
    Reno, NV
    2013 DCSB BLK
    SEE BUILD.
    Using a flat head screwdriver, I was able to run the cable down the side. Will be even easier to remove the wire conduit and just run the power/negative wires down.
  15. Mar 30, 2014 at 8:10 PM
    #135
    PnoyBOS5
    kevin
    CA
    2013 PRERUNNER
    I'd like DR42 w/ mounting brackets.
  16. Mar 30, 2014 at 8:10 PM
    #136
    RelentlessFab
    Eric
    Sparks, NV
    Ha it certainly grabs attention having a bar all the way across the roof!
    Will do
    On the double cab it's no mods aside from popping a small hole in the rubber for the hardware to pass through. Included hardware will secure the brackets from there
    On 2nd gens it takes a bit of effort to cram into the trim, it's a bit easier on 1st gen's from what I saw messing with my truck on Saturday
  17. Mar 30, 2014 at 10:29 PM
    #137
    paquu
    paquu Well-Known Member
    RI
    02 doublecab fj trm rims, roof led bar
    42" LED bar
    It does help. Ill have to think about the cubes a little more. Just bought a radius 42" with mounts. Under the name "paquette". Thanks for answering all my questions!
  18. Mar 30, 2014 at 10:45 PM
    #138
    Patchiman
    Patchiman Active Member
    Hi, I place my order for 42" radius with mounting bracket with the name " Lowell B." Thanks for doing the GB discount.
  19. Mar 30, 2014 at 10:49 PM
    #139
    RelentlessFab
    Eric
    Sparks, NV
    Thanks for the orders guys! I'll update the orders list in the OP in the morning. :)
  20. Mar 30, 2014 at 11:18 PM
    #140
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Any pics of the Qube3 in use?
Thread Status:
