RAN ENGINE DRY. NOW VALVE TICK
Discussion in '1st Gen. Tacomas (1995-2004)' started by Clown Baby, Apr 23, 2014.
  1. Apr 23, 2014 at 1:57 PM
    Clown Baby
    Clown Baby [OP] Well-Known Member
    Eric
    NorCal
    '00 prerunner
    Hey guys,
    I bought a 1997 4runner after selling my 2000 tacoma (tired of a singlecab). Posted here because i know you tacoma guys have the same 3.4L and might have experienced this:
    I had the timing belt done, and the mechanic changed the oil while he was at it. Fastforward ~2000 miles, I get a low oil pressure light in the morning. I go ahead and check the dipstick and the oil isnt even registering. I go to train the oil and there's barely a god damn liter that comes out.
    Anyways, I quickly dump about 6L in there and fire her up. All of the sudden i've got some kind of ticking noise.
    Noise is here:
    https://www.youtube.com/watch?v=-aVSHe2s1tk
    For reference, it's a 3.4L with about 195k miles on it. It ticks at idle and increased with RPMs. If I add a half liter of oil to the crank case it'll quiet down for just a bit before coming back again. From just looking under the oil cap, I'm going to assume that the PO wasn't too vigilant with his oil changes...
    So bummed. I JUST bought this thing. Anyways, before I start throwing money at it, I want to know what you guys think. Is this a lost cause? Should I drop the pan and replace the bearings? Is this something I can remedy under the valve covers?
    Suggestions and opinions welcomed.
    Thanks
  2. Apr 23, 2014 at 3:10 PM
    Tinmann
    Tinmann Well-Known Member
    NorCal
    No bueno amigo! It's difficult to figure out where the noise is coming from in a few second sound byte, but if this is as a result of what the mechanic did, I'd be paying him a visit. Was there a ticking noise prior to going to the mechanic?
    You may want to go down and let him listen to your sound clip but I wouldn't drive it. If he wants to see the truck you may have to tow or trailer it down.
    Alot of things can happen as a result of oil starvation and none of them are good. My 1st guess is valve train but may be the start of a rod bearing going south. :mad:
  3. Apr 23, 2014 at 3:14 PM
    Archer550
    Archer550 Well-Known Member
    Winnipeg
    04 xtracab TRD MT
    ARB for now
    Sounds alot like one of VR6 volkswagens right before it spun a bearing due to no oil :(
    sorry for the negative vibes!
  4. Apr 23, 2014 at 4:02 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I would definitely pay the mechanic a visit. If he's a decent and trusting guy, he just might fix the issue. Worth a try.
