Ran hot, repurcussions?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2toys, May 3, 2009.
  1. May 3, 2009 at 3:12 PM
    2toys
    2toys [OP] Well-Known Member
    Los Angeles
    01 Red Hot Double Taco
    I'm getting on freeway today, with AC on. After merging into traffic (uphill) and achieving about 70 MPH, I glance at my instruments and see the water temp at redline, my SG2 shows 270degF as the peak temp. I turn off ac, throw it into heat, windows down and exit. Just then the temp drops like a rock and stabilizes.
    So now I'm changing my T-stat, but should I expect and repercussions from this event? The truck hadn't been on more then 5 minutes and maybe 1 minute that I saw the temp in the red. Anything that I should be looking for?
    TIA
  2. May 3, 2009 at 5:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You should be ok.
  3. May 3, 2009 at 5:36 PM
    98tacoma27
    Ben
    Not Beech Creek
    I would only worry if you drove for a prolonged period. You did the right thing.
  4. May 3, 2009 at 5:40 PM
    2toys
    Los Angeles
    Thanks for the peace of mind. It looks alright, here.
  5. May 3, 2009 at 7:09 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    Like state above. You should be good. The worst would be a warped head, but that in itself isnt even that bad.
  6. May 3, 2009 at 7:17 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Should be fine, wasn't it pinging like crazy? My money is on the T-stat. I wish they would put an alarm on the temp, oil and gas gauge.
  7. May 3, 2009 at 7:18 PM
    fletch aka
    Gary
    Left Coast
    Are these a cast block with aluminum heads?
  8. May 3, 2009 at 7:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The 3.4, Yes. The 4.0 is all aluminum.
  9. May 3, 2009 at 7:22 PM
    98tacoma27
    Ben
    Not Beech Creek
    OP has a 2.7
  10. May 3, 2009 at 7:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok...Cast iron block, Aluminum heads.
  11. May 3, 2009 at 9:12 PM
    2toys
    Los Angeles
    Didn't notice any pinging or engine struggle at all. Like I said, I was merging into fast traffic from an onramp, uphill, going about 70 with the AC running. Truck was running fine actually, didn't throw a code or idiot light. An alarm would be nice... At first I thought I tossed a belt, but their all alive and well. Looked like original T-stat.
  12. May 4, 2009 at 4:27 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You'll be fine....
    As long as the system is functioning properly, you have plenty of fluids in the system & no leaks...... the system should be able to keep the temp at a consistant temperature even though it could be 'higher' than normal (and even in the red).
    When you're driving consistantly and that needle keeps creeping upwards and doesn't stay consistant.....that's when you might want to inspect your cooling system for problems.
