Ran Hot Today
Discussion in '1st Gen. Tacomas (1995-2004)' started by LSUdude, Jul 28, 2023.
  1. Jul 28, 2023 at 5:54 PM
    LSUdude
    LSUdude [OP] Active Member
    1999 Tacoma trd
    Never had it move above normal and today it went pretty high but still out of the danger zone. Stopped and shut it down and fan wa spinning while coolant went into the overflow. Let it sit for about 20 minutes and fires it up again.
    Stayed normal for the rode home. Faulty thermostat that got stuck?
    What's everyone think?
  2. Jul 28, 2023 at 5:55 PM
    soggyBottom
    soggyBottom Well-Known Member
    What was the temperature outside?
  3. Jul 28, 2023 at 6:13 PM
    LSUdude
    1999 Tacoma trd
    101 or so
  4. Jul 28, 2023 at 6:15 PM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    I think you shut it down for nothing if you said it wasn't in the danger zone. If it's hot out sometimes it works harder
  5. Jul 28, 2023 at 6:20 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Probably just the weather but now's a good time to ask when you last changed or checked the coolant?
  6. Jul 28, 2023 at 6:30 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Did you check the coolant level after it cooled down?
  7. Jul 28, 2023 at 6:33 PM
    Angel707
    Angel707 Well-Known Member
    Angel
    Next time it happens try showing a picture, i know mine runs a little above the half way mark and apparently its normal from what ive heard.
  8. Jul 28, 2023 at 7:25 PM
    LSUdude
    1999 Tacoma trd
    No ot was boiling into the overflow. Much hotter than right above normal. It was under right by a smidge.
