Ran out of gas and now no start 17 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jwmz74, Jul 5, 2021.
  1. Jul 7, 2021 at 6:37 AM
    #61
    Sasquatchian
    Sasquatchian Well-Known Member
    Considering that it's inside the freaking gas tank, I agree with you. Aren't there two fuel pumps on these - a low pressure and a high pressure? I know that when I had the fuel pump recall service they dropped the gas tank in order to get it out. Maybe the OP replaced the other one.
    Roberto123 likes this.
  2. Jul 7, 2021 at 6:40 AM
    #62
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Diesel air compressor =/= modern car gasoline engine
    eurowner, GarlicFarts and Kev250R like this.
  3. Jul 7, 2021 at 6:41 AM
    #63
    RedWings44
    Michigan
    Has anyone considered that maybe the fuel pump cutoff switch was tripped as a result?
    Hooper89 and FLYH2O like this.
  4. Jul 7, 2021 at 6:42 AM
    #64
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    I use premium too. I remember seeing in the owner’s manual some verbiage about “as tested on 91 octane” well dammit I want as much performance as I can get. She eats well.
    Junkhead, Bedawson and Roberto123 like this.
  5. Jul 7, 2021 at 6:47 AM
    #65
    Roberto123
    Roberto123 Well-Known Member
    robert
    2018 Tarcoma SR 4X4 Dbl Cab
    Same. BP or Mobil if Shell is not available. Some gas companies must have higher standards on underground tanks, etc. than others.
    I carry my dog around too! Not judgy like yours. I can tell he isn't happy when I pass by a Citgo. Always gives me his righteous Socialist revolutionary glare.
    Scott B. and MalinoisDad[QUOTED] like this.
  6. Jul 7, 2021 at 6:52 AM
    #66
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    This was suggested once before in this thread and is a pretty plausible explanation. It also might explain why we have not heard anything back from the OP on this.
    RedWings44[QUOTED] and SR-71A like this.
  7. Jul 7, 2021 at 6:55 AM
    #67
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    These threads are hilarious
    Chew, VirusCage, shakerhood and 4 others like this.
  8. Jul 7, 2021 at 6:57 AM
    #68
    Heyyo_Friday
    Heyyo_Friday Circle driving enthusiast
    Derek
    Dfw, texas
    2020 tundra 1794
    Rays valve stem caps
    :popcorn: in for some tomfoolery. Or a result of the half a gallon down the intake.
    Bedawson, Lawfarin and Skydvrr like this.
  9. Jul 7, 2021 at 7:01 AM
    #69
    Strostkovy
    Strostkovy Well-Known Member
    Alex
    White 98 Tacoma
    Of course not. But I've heard all my life never to run a diesel engine dry or it won't start without repriming it.
    The takeaway is that people often just don't know what actually happens or why.
  10. Jul 7, 2021 at 7:01 AM
    #70
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    To avoid hydro lock caused by the 1/2 gallon gas......try using LP from your BBQ grill.
    Just aim the hose into the air filter, open the valve, crank the engine..........
  11. Jul 7, 2021 at 7:06 AM
    #71
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    I have never noticed any difference in gasses. The issue is the volume - a low volume station will have more sedentary shenanigans, sludge, etc. A high volume station, no matter what brand, will be a-okay. I hit stop and shop, exxon, mobil, whatever makes sense that day :notsure: never had an issue.
    Because there's a long fuel line to the car engine from the car gas tank that is not there on a diesel generator.
  12. Jul 7, 2021 at 7:08 AM
    #72
    Skydvrr
    Nick
    YMH
    Black '17 OR
    That's some good insight. Thanks garlic farts.
  13. Jul 7, 2021 at 7:09 AM
    #73
    Roberto123
    robert
    Did he mention if he was a smoker? I am starting to think this thread might have a bleak conclusion. Worse yet, I may never know if my bad gas/ water in the tank was the correct diagnosis.
  14. Jul 7, 2021 at 7:11 AM
    #74
    Knute
    I get bad gas after finishing off leftover chili for 5 days.....follow with a serving of day old broccoli.
    Stadium clearing level.................
    I blame the dog.
  15. Jul 7, 2021 at 7:17 AM
    #75
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    This. Might just be pressure locked.
    After pouring a half gallon of fuel into the throttle body, there may be no more problems, ever.
    SR-71A and Roberto123 like this.
  16. Jul 7, 2021 at 7:23 AM
    #76
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Yeap,sometimes it will cost them $1000 for a new fuel pump and repair just because they didnt gas up.
  17. Jul 7, 2021 at 7:30 AM
    #77
    lynlan1819
    Tacoma
    Lifted
    BOOM!
  18. Jul 7, 2021 at 7:32 AM
    #78
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    I start looking to fill up when I get to 1/4 tank for two reasons. One to avoid ever running out of gas, and two because I'm a cheapskate and HATE seeing what the cost is when I run the tank close to empty.
  19. Jul 7, 2021 at 7:36 AM
    #79
    Knute
    If I need to drive 376 miles, then I need 18.7 gallons of fuel. Doesn't matter if the fuel is in the tank or at the pump. Cost will be the same about $0.14/mile.
    Old Marine Cal likes this.
  20. Jul 7, 2021 at 7:44 AM
    #80
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    Yea I realize the cost per mile is the same no matter what, but the other issue is the wife factor. She drives a 19 Prius that gets 57 MPG and puts gas in the thing with an eye dropper. Every time she's in the truck and I get gas with her, I get the " so, how much did THAT cost you?" routine. If I run the truck close to E the chit factor gets exponentially worse. I realize the obvious solution is to get gas when I'm by myself, but it's not always possible. Poor planning on my part.
