Rancho 2.5" lift installed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4508js, Jan 25, 2014.
  1. Feb 28, 2014 at 6:12 AM
    Savis
    Savis Well-Known Member
    Virginia Beach
    09 PreRunner
    Toytec 3" lift, Black Rhino Sidewinder, 285/70/17, Leer 100 XL
    Nice write, thanks
    Do you know if you use a 2" rear block are you required to use a diff drop?
  2. Feb 28, 2014 at 8:45 AM
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    I'm not sure on whether you'll get vibes or not, but you should consider an add-a-leaf instead of a block. Blocks will wear out your leafs faster and they create more axle wrap
  3. Feb 28, 2014 at 9:31 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    That 2nd set is for your carrier bearing drop. Sorry miss read your post. Didn't see you said you had two set's. rectangle/1/2"+/- spacers, right?
  4. Feb 28, 2014 at 11:24 AM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Truck looks awesome. I was wondering did you get any vibration after installing this kit ?
  5. Feb 28, 2014 at 12:35 PM
    4508js
    4508js [OP] Well-Known Member
    Tennessee
    '13 TRD OR 4x4 DCSB, 4.0L V-6
    3" Rancho Suspension lift, Wet Okole seat covers, FJ TRD beadlock wheels
    Yes that's what I was referring to lol
  6. Feb 28, 2014 at 12:39 PM
    4508js
    Tennessee
    I did feel like I felt a very little vibration under my pedals at first but I no longer feel it. I thought it was because the rear is 1/4" lower because of the use of the top plate spacers but apparently everything has settled and I have zero vibration now. I ordered a wheelers 2" AAL last night so the rear should sit 1/4 to 1/2 inch higher after I swap out the block for the AAL, I'll report back and put up a new picture when I get them swapped out
  7. Feb 28, 2014 at 8:38 PM
    MTopp
    05 SR5 4x4
    Nice!
  8. Mar 1, 2014 at 5:24 AM
    tacoma guy
    Joe
    Phoenix Az.
    Awesome . Yeah keep us up dated .
  9. Mar 8, 2014 at 6:18 AM
    RTD
    RTD Well-Known Member
    Taxachusetts
    Why do folks use an AAL?
    Why not replace the stock springs with a better after market product?
    Other than the cost, which a couple hours of OT should do it.
  10. Mar 8, 2014 at 11:42 AM
    4508js
    Tennessee
    Well I'm replacing the 1.25" block with a 2" AAL because I only need a little more lift in the rear, it's only costing $100 shipped instead of $400 plus bushings U bolts and shipping, I don't off road so I'm not worried about flex and what not, and mostly I'm a simple police K-9 officer that works for a department with 42 certified officers so unlike the guys with the high paying jobs I can't afford to just buy anything and everything that all the cool kids have. Don't get me wrong I originally wanted the Toytec ULK with a new leaf packet and UCA's but it was going to cost $2k to have the setup I wanted so I found the Rancho lift as installed for under $1k and when I receive and install the AAL I will have $1,075 in a full 3" lift. Some of us are ok with having what we can afford instead of what everybody else tells us we should have.
    Hope I didn't sound like a prick, just answering the question honestly
  11. Apr 8, 2014 at 8:58 PM
    cajun11viking
    cajun11viking Member
    Look.... There's a tacoma!
    New Orleans, LA and Bossier, LA
    11 PreRunner DB TRD Sport 4x4... GREEN!
    researching 3" suspension lift combos (confused)
    I have all stock on my 2011 4x4 sport DB. This thread has proved very insightful (thanks all). The majority of my driving thus far has been city miles with the various bumps and potholes that make up Nola streets. I've been to the http://www.gorancho.com/shocks.php?shock=RS9000XL website and would like some help/discussion on interpreting the "tuning technology." For myself, I'm currently focused on a smooth ride capable of handling bumps without feeling the harshness in the bumps (current stock suspension can be improved).
    Any thoughts? Thanks guys
  12. Apr 8, 2014 at 11:15 PM
    4508js
    Tennessee
    My shocks have been set on 5 the entire time I have had my lift on and I personally think the ride is as good or maybe slightly better then the stock ride. I would say if you are looking for a softer then stock ride then the 3 setting would definitely give you that, I am totally happy with the Rancho setup I have. Hope this helps
  13. Apr 10, 2014 at 5:57 AM
    typeone
    typeone Well-Known Member
    central MA
    2013 TRD Off-Road 4x4 DCSB BLACK
    2.75" Rancho QuickLIFT Loaded coilovers, LR UCAs, Wheelers 1/4" poly top plate spacers, FBG diff drop, Toytec swaybar relocate, Wheelers 2" AAL, LRO 1" tapered blocks, RCD Bilstein 5100 rear shocks, OME carrier bearing drop, OEM roof rack, Access Literider tonneau, SCS Stealth 6 wheels, 285/70r17 Nitto Terra Grappler G2 tires
    i've been running the Rancho's up front since last Sept, still happy with my decision. setting 2 provides a nice smooth ride for daily use.
  14. Oct 25, 2014 at 9:00 PM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    Sub'd... thanks for the info!
    I was looking at Bilstein 5100's for the front, but I like this idea better since I can do the install myself safely.
    I have already installed Air Lifts in the rear for towing purposes (equipment float & compact tractor = 6000 lbs, or a tandem dump trailer full of fire wood), so the truck rides high in the back and nose dives in the front.
    I run Cooper Discoverer A/T 3's (265-70-17) and they rub the small front fender mud flaps in a reverse turn.
    My questions would be:
    Since I already have Air Bags and a Canadian issue TRD 4-leaf rear and Air Lift kit, would I need to install the blocks?
    Do I need a front end alignment after install, since Rancho claims the kit doesn't change the alignment?
    Thanks for advice in advance!
  15. Oct 26, 2014 at 6:49 AM
    #35
    Ma Deuce
    Ma Deuce Well-Known Member
    Joe
    Colorado
    You will still need to get it aligned. Do they say it doesn't change the alignment, or that it can still be aligned to factory specs?
  16. Oct 26, 2014 at 7:53 AM
    #36
    taczilla
    Marc
    2016 RAM Rebel
    Here's what I read in an add on eBay:
    Primary Suspension System w/Shock; RS9000XL Series Shocks; 2.5 in. Lift; Incl. Upr ControlArms/Ball Joints; RrBlks/U-Blts; Maintains OE Alignment; Won't Affect Electronic Stab Cntrl Sys;
    I agree that common sense and geometry would indicate an alignment may be in order. Perhaps the ad is somewhat enthusiastic in its wording. I just re-read the OP and he said the alignment guy had 0 issues re-aligning the truck after install. (Oops!)
    I would still like to know if the rear blocks would be compatible or even necessary with the Air Lift kit that I have already installed. ????
    #36
  17. Oct 26, 2014 at 8:13 AM
    #37
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    What air lift do you have? Do you mean air bags or air lift?
    #37
  18. Oct 26, 2014 at 9:06 AM
    #38
    taczilla
    Marc
    2016 RAM Rebel
  19. Oct 26, 2014 at 9:14 AM
    #39
    SabMotocross
    SabMotocross Well-Known Member
    Bobby
    Santa Fe, Texas
    2014 Tacoma PreRunner SR5 DCSB V6 TRD S/C
    TRD BAJA Suspension...Rims and tires, blackout badging, TRD oil filler cap, front skid plate, N-Fab step bars, GrillCraft custom upper and lower grills. K&N air filter, TRD Supercharger.
    Very true....I've had Rancho suspensions in both my Toyotas back in the Eighties...never a problem with them, trucks always sat true and level.
    The only problems I had with Rancho suspensions were their shocks. The paint would usually peel off of them within 6 or 7 months, and that is the only complaint I had.
  20. Oct 27, 2014 at 7:57 AM
    #40
    typeone
    central MA
    taczilla... yes, you will need to get an alignment after install. to retain a little rake, you will need about 3" lift in the rear.
    still happy with my Rancho QuickLIFT setup but to echo SabMotocross... the paint durability has been my only complaint with any Rancho product i've owned as well.
