rancho quick lift loaded
Discussion in '1st Gen. Tacomas (1995-2004)' started by had2020, Jul 3, 2012.
  1. Jul 3, 2012 at 6:08 AM
    had2020
    had2020 [OP] Member
    Heath
    az
    2001 sr5 reg cab 4x2
    nice and stock
    has any one tried these? i have a 2001 reg cab 2wd. it says 1.75 inch of lift but i was curious if any one has em and did they get 1.75 inch, and if they liked em.
    thanks
  2. Feb 18, 2019 at 11:33 AM
    ontario1998tacoma
    ontario1998tacoma Member
    1998 Tacoma xtracab
    Did you end up going with these? I was recommended these for an affordable option from my offroad shop.
  3. Feb 18, 2019 at 4:47 PM
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. Deck Plate Mod., and Marlin Crawler Short Throw Shifter.
    I have these on my Taco, 1.75 in is correct. Look at my profile picture and that is how it looks. I like them so far...
  4. Feb 18, 2019 at 5:03 PM
    ontario1998tacoma
    1998 Tacoma xtracab
    Oh nice! Your truck looks great! I'm thinking I might get them. I'm in Canada. It seems like all other options are basically double the cost of a set of these. How are your CV angles after the install?
  5. Feb 18, 2019 at 5:59 PM
    homegrown_xt
    Sonoma County
    Thanks, the cv angles are good, as long as you don't go over 2 inches you shouldn't have to use the front diff spacers .
  6. Feb 18, 2019 at 6:23 PM
    homegrown_xt
    Sonoma County
    I like the Rancho's, I have run them before in the past and have had no issues with them. I'm not rock crawling, just an occasional off road excursion and trips to Tahoe. I eventually want to go to 32 11.5 15.
  7. Feb 18, 2019 at 6:39 PM
    ontario1998tacoma
    1998 Tacoma xtracab
    That's good to know. Not to rough of a ride? My current stock shocks are old and very stiff on the road. Yeah I won't be doing any rock crawling either. Just want to be able to ride on some messy roads and not feel like I'm going to hit my head on the roof Haha. Also to even me out. I'm high 3 inches in the rear now with and AAL
  8. Feb 19, 2019 at 12:44 AM
    homegrown_xt
    Sonoma County
    The Quick Lifts are adjustable, I have mine set at 4 and that is perfect for me and my old bones.
    They handle pretty decent to which is a plus!
    I think you will be happy with them if you decide to go with them.
    I have the Wheelers 3 leaf progressive in the back with the longer Rancho shocks and their steel braided extended brake line kit also.
  9. Feb 19, 2019 at 2:30 AM
    ontario1998tacoma
    1998 Tacoma xtracab
    Did you need that steel braided extension brake line kit for the front and the rear? Or just the front?
  10. Feb 19, 2019 at 7:22 AM
    homegrown_xt
    Sonoma County
    I did the front and rear to be on the safe side.
