Rancho Shocks
Discussion in 'Suspension' started by retvet, Dec 1, 2009.
  1. Dec 1, 2009 at 9:21 AM
    retvet
    retvet [OP] New Member
    Jim
    Jackson, CA USA
    05 4WD Toyota Tacoma
    air lifts
    I'm planning on replacing my rear shocks with the Rancho brand. I see that there are a number available. Which one would be the best compromise between cost and performance. I own a 4 WD 2005 Toyota Tacoma. Jim
  2. Dec 1, 2009 at 9:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW! The only Ranchos I like (or had decent results with) have been the RSXs'. Personally, I think the Bilstien 5100's are a better shock for the Tacoma.
  3. Dec 1, 2009 at 5:05 PM
    mixaro
    mixaro Well-Known Member
    maine
    02 tacoma ext cab, 2011 trail edition 4 runner, 2013 tx baja dcsb
    02 ext cab cat-back exhaust, k&n replacement filter, 5100 billy's, hellcreek 1.5" rear spring packs, 882 OME coils, Toytec 2" AAl, stainless brake lines, Light Racing UCA, 1" diff drop, BPV bracket, 4" deck plate mod, 886 fog light backup light mod, tom woods one piece drive shaft, spider trax 1.25 spacer.
    yeah what chris 4x4 said, go with the bilstein 5100 shocks, they are far better then the ranchos. every rancho i've run in any vehicle i've owned were POS.
  4. Dec 1, 2009 at 5:11 PM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    X3! to what chris said. If you go cheap now on your truck, you'll be replacing it later down the road and it'll be more expensive.
    Check out downsouth Motorsports for the cheapest bilstein shocks you can get.
  5. Dec 2, 2009 at 4:08 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Personally, I'm not a fan of Rancho. I've used them in the past (years ago) and I had atleast 2 shocks leak - luckily at the time, they had a lifetime warrantee. They don't last very long either - I was lucky to get 2 years out of them (piston leaked).
  6. Dec 2, 2009 at 6:00 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    I had the Rancho RS5000 on my 95 Tacoma 4X4 front and back. I think I installed them on my truck at about 80K miles and they were still on there when my truck went to the crusher with 146K miles. I have no complaints about them; they never leaked and performed properly.
