rancho vs bilstein
Discussion in 'Suspension' started by yota243, Apr 9, 2014.
  1. Apr 9, 2014 at 3:08 PM
    yota243
    yota243 [OP] Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Ive got an 05 trd OR and wanna lift it 2" to fit 255/85s under (my first question i guess is, is that enough lift for those tires? ) and secondly, can i do 2" with OR springs and billies, or would the rancho quicklift be better since it is fully assembled with new springs? It seems to be a better deal since for just $50 more bucks i get new springs and its fully assembled. Id also like input on ride quality in repspect to stock OR suspension if anyone has that? Oh and if i should remove sway bar (prerunner so down travel downs effect me too much)
    I use my truck to deer hunt out of and drive around the fields and pastures, ive been to an ooffroad park a time or two, prolly 75% of use is on road tho
  2. Apr 10, 2014 at 3:24 PM
    yota243
    E.J.
    north Alabama
  3. Apr 10, 2014 at 3:43 PM
    Large
    Large Red
    You can fit 255/85 on stock suspension but if you are going to flex it I would hammer the pinch weld flat or you will slice your tires up. To answer your question though I would go with 5100s on the front and move the clip up 2 notches on stock springs. Since you have an 05 your springs might need to be changed anyway, I am sure someone has some stock ones laying around they don't need. I have a pair in a box with a couple hundred miles on I don't mind shipping to you.
  4. Apr 10, 2014 at 6:29 PM
    yota243
    E.J.
    north Alabama
    U mean set at .85 by 2nd notch? Billies ll the way around for $309 at downsouth or where ever is the best deal also right? And how much would u want for ur springs?
    Ar u saying u have a pair of 5100? Misplaced modifier are getting me pretty bad
  5. May 15, 2014 at 7:24 PM
    yota243
    E.J.
    north Alabama
  6. May 16, 2014 at 12:32 PM
    yota243
    E.J.
    north Alabama
  7. May 16, 2014 at 12:42 PM
    yota243
    E.J.
    north Alabama
  8. May 16, 2014 at 6:39 PM
    mainewoodsballer
    mainewoodsballer YESSAHBUD...heyut
    Ol' Waltah
    Maine
    2015 DCLB TRD Sport (Pyrite Mica)
    Check out my Build to See!
    I got my bilsteins and coils all assembled and sent to me from Toytec.
