Random alarm going off
Discussion in 'Technical Chat' started by Brooke379, Dec 22, 2013.
  1. Dec 22, 2013 at 11:18 PM
    Brooke379
    Brooke379 [OP] Well-Known Member
    brooke
    Claremont 909
    03 Something taco
    took out over load leaf spring, double chamber magna flow, Pink emblem, took off most Decals, 4inch fagtech, 4k HIDs, two 10 p1 rockford fostgate. Aftermarket head unit. 3.73 to a 4.10 gearing, Plasti dip the sides, customized headliner, added a flag mount and slapped on a dirtlawz decal
    So, she's an 03 prerunner 5 lugg 2wd and randomly her alarm goes off for a few seconds then stops. I've noticed no trend. Some days it's every hour and sometimes it won't happen for weeks. I don't know if these two go together but my driver door doesn't lock either.. Like it will click to lock but you can still open it after but with the alarm going off.. Even if I manually lock it but then the alarm won't go off.. I don't think think the system she has is stock. Bought her with this shitty alarm system. Any advice is appreciated!
  2. Mar 14, 2014 at 8:06 PM
    BDBSoCal
    BDBSoCal The Safety Guy
    Brad
    SoCal
    Silver 2008 SR5 V6 4x4 TRD Sport
    Just starting...
    Depending on the alarm, it MIGHT be tied into the power locks and/or is using the electrical system to sense when someone opens the door. Some of them look for an electrical drain to determine if someone has broken into the car. For example, the door opens, the light goes on, the electrical drain is noticed, and the alarm goes off. You'll notice that they don't put little sensors on the doors in vehicle alarms.
    That said, a lower-quality after market alarm could have a short. I had one on a prior car, and it started to destroy batteries. Something about the way they installed it was always draining the battery.
    It's also possible that whatever is causing the door to not lock is impacting the electrical system enough to create a short or a battery drain. If it was trying to actuate, but is stuck, maybe it's drawing from the battery and the alarm becomes convinced that someone has opened the door.
    After my battery-destroying experience, I've opted for dealer-installed alarms since. Never had a problem with them. And they seem to lock themselves if I deactivate the alarm and don't open the door fast enough.
    You may try fixing the door first to see if the problem goes away.
    And given how old this thread is, maybe you already have...
  3. Mar 17, 2014 at 12:57 PM
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    2017 TRD Off Road
    12voltsolutions.com plug-n-play remote start system. OVTuned OEM Bed lights Underhood and footwell lights Garmin dash-cam Weathertech side vents, bug shield, mud flaps and floor mats Extang Encore tonnau cover OME BP51 Suspension Front & Back / Dakar Leaf Springs Light Racing UCA's XD Holeshot 17" x 9" Wheels Nitto Trail Grapplers 265/70/R17 TRD Pro Grille Raptor Lights iJDMToy 30" LED Hidden Bar Light Toyota Bed Step
    Make sure there are no loose connectors going to the alarm module. Alarms can act possessed if there is a loose connector....
