Random blinking with map lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by shaggy135, Dec 20, 2019.
  1. Dec 20, 2019 at 4:23 PM
    NavyDad
    NavyDad Well-Known Member
    Okay. You are saying when the doors lock or unlock the lights dim lightly and/or briefly correct? Do they dim the same way if you turn on the head/tail lights with the engine not running? What you may be seeing is a brief voltage drop because something else has been switched on. The door locks work with a solenoid that pulls a good bit of juice and that can cause the lights to dim. If your headlights happen to be on when you start your truck you will see them dim a lot because the starter is pulling a lot of juice. Same thing here, but on a smaller scale. Just my 2¢.
    Captqc likes this.
  2. Dec 20, 2019 at 5:16 PM
    shaggy135
    shaggy135 [OP] Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    Yes, they flicker whether then truck is on or off. Whether the headlights are on our of too.
  3. Dec 20, 2019 at 6:37 PM
    CBChief
    CBChief Chief
    Fredericksburg VA
    2018 Black Tacoma TRD SPORT DCSB
    The list has only just begun! Bob's mirrors Homelink mirror N2design Remote Starter Empyre OffRoad Door Sill Decals BDtrims Domed Tailgate Letters Thin Red Line Reflective(Custom made) KTJO 4x4 3rd Gen Plug-N-Play Tailgate Bolt-N-Lock & Tailgate Bolt-N-Open Switch Pro SP9100 Expedition Essentials Sunglass holder for the SP9100 PowerTray Vertical Mount with accessory bundle Anytime Backup Camera Front Camera Old Coots 1 inch Seat Spacers MESOCustoms COIN TRAY CaliraisedLED LOWER BUMPER HIDDEN LED LIGHT BAR BRACKETS LEDOutfitters 30 LED DUAL COLOR COMBO SPOT AND FLOOD LIGHT SINGLE ROW Auto Ventshade Low Profile Matte Black Ventvisor Side Window Deflectors Rogue River Tactical Subdued Thin Red Line Flag Trailer Hitch Cover Redline Tuning 21-27015-02 Hood QuickLIFT PLUS System Tacos4cheap Toyota Tacoma 3rd Gen Glove Box Inserts URPOWER Dog Seat Cover Car Seat Hammock Kavaca REGENERATING PAINT PROTECTION FILM Ceramic Pro Coating 20% Tint on all legal glass 303 Protectant Coated Tonneau cover The Last Coat TLC2/AMP Protected over CP OEM BedMat OEM Truck Bed Header Rail OEM Bed Cleats +4
    Well according to the other posts that are referenced in this thread it appears that you have fried the body control module BCM
  4. Dec 20, 2019 at 7:46 PM
    shaggy135
    So a $400-700 part gets fried because of some $30 LEDs? Something doesn't sound right. And nothing else is wrong with my truck. I'm going to put the old ones back in tomorrow and see what happens. And who's liable for the damages? Meso for making the product and not having instructions or Running 4 Tacos for selling them without any instructions?
  5. Dec 20, 2019 at 8:38 PM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    It only takes 45 seconds to pop the over head console off and unplug it, then change everything from the back like you are suppose to do , never need to open the hood, don't know why people take the long way to do things at times . Its only held on by some push snaps, just grab it and pull down.
    BUT i almost did that when i changed mine out , and OP / sorry i think
    you fried something, hope not...
  6. Dec 20, 2019 at 8:49 PM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    I'd say you're liable.
    I just installed Bilstein 6112"s, they came with no instructions. If I fucked something up that's on me. If I want to offload that risk I have to pay someone else to perform the work.
  7. Dec 21, 2019 at 8:19 AM
    jerkwithkeyboard
    Thanks for the pic.....
    It was late and i didn't remember if i had a photo of it out .. yours it perfect
    The OP will need to put it out now anyways to put the new one in.
  8. Dec 21, 2019 at 10:17 AM
    shaggy135
    You guys are funny. Does anyone do any real troubleshooting? I put some different LEDs in and the flicker is gone. Although now, if I turn both map lights on, once I click the second map light, my dome light flickers. Which is also a Meso ultimate dome light. I don't think there's really anything wrong. I bet there's an inrush of either current or voltage that causes the blink because there isn't enough resistance in the Meso parts. Fried a BCM with some plug and play parts? SMH. More troubleshooting will continue.
  9. Dec 21, 2019 at 10:19 AM
    GreyBaldTaco
    2019 F150 5.0
    You may syh but it's happened before.
  10. Dec 21, 2019 at 2:55 PM
    shaggy135
    Haha, fixed it with some $3 resistors. 5W 150 Ohm in case anyone is wondering. I researched some of the older threads. The 01-04's had a similar issue and a 4W 100 Ohm fixed those. My local electronics store didn't have any so I tried the 5W on a whim. Wired one in parallel with each of the Meso map lights and voila. All back to normal. Everything dims correctly. Turn on when doors open and off when closed. And best of all, no more blinking when the doors lock or unlock. Thanks anyway TW!
    Jdpsurf and GreyBaldTaco like this.
  11. Dec 21, 2019 at 4:09 PM
    Calmlikeabomb
    Calmlikeabomb Well-Known Member
    Hendersonville TN
    2016 Quicksand TRD Sport M/T
    My map lights have blinked since the day I got my truck, I can hit the power mirror switch and they would blank or even the window buttons more noticeable at night really don't notice it during the day. Never had any of the issues from that
  12. Dec 21, 2019 at 7:55 PM
    jerkwithkeyboard
    Glad they’re fixed.
    I have a 2016 and put in cheap Chinese LED lights and map lights two months after I bought the truck and haven’t had a problem with them, so maybe the 2018’s are a little more finicky
    :santa:
    :santa:
    :santa:
    :santa:
  13. Dec 21, 2019 at 8:05 PM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    - no battery cables to disconnect
    - no flashing or fried electronics
    - does not blind your driving when illuminated
    - 6K LED color 194 bulb
    - $11 at most auto parts
    GumShoe and payrow like this.
  14. Dec 21, 2019 at 9:19 PM
    shaggy135
    But they are no where near as bright as the Meso's.
  15. Dec 21, 2019 at 9:22 PM
    #35
    vecdran
    vecdran Barely-Known Member
    Jeremy
    Kirkland, WA
    2020 TRD Pro Super White 6MT
    Financial Black Hole
    I have a similar issue, sort of.
    Of all things, adjusting the lumbar support on the power seat in my 2020 causes the map and dome lights to flicker on dimly.
    Yes, I disconnected the battery when I installed them. Is my truck going to explode?
    Rath89 and Dravyss like this.
  16. Dec 22, 2019 at 10:25 AM
    #36
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Just wait until it rains and they stay on
  17. Dec 22, 2019 at 2:58 PM
    #37
    captainh00k
    captainh00k Well-Known Member
    Pittsburgh, PA
    2023 DCSB
    Happens to me too. When the door locks auto lock at speed the map and dome lights will faintly blink.
  18. Dec 22, 2019 at 3:17 PM
    #38
    shaggy135
    I was wondering if anyone else was experiencing this. Resistors did the trick.
    MisterKitchen likes this.
  19. Jun 17, 2021 at 3:06 PM
    #39
    Dravyss
    Dravyss Well-Known Member
    Nick
    Kentuckiana
    2020 Sport 4x4 6MT
    Sorry for reviving this but figured I would speak up. My 2020 lumbar button also causes the led map and dome lights (both meso brand) flicker when the switch is initially activated and when i release it. Not sure what it is yet
  20. Jun 17, 2021 at 4:43 PM
    #40
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    So this is resolved but wanted to add that LED flicker and even hard blinking is indicative to resistance. Some will pair halogens and LEDs on the same circuit to maintain resistance
    Dravyss likes this.
