Random Blowing/Revving Sound When Idle
Discussion in '4th Gen. Tacomas (2024+)' started by MonkeyTaco12, Apr 25, 2025.
  1. Apr 26, 2025 at 5:28 PM
    baron55
    baron55 Well-Known Member
    2025 Tacoma TRD Sport 4X4
    You can disable the AC to run in auto in the vehicle settings menu. It's enabled by default.
  2. Apr 26, 2025 at 5:59 PM
    Taco Ji
    Taco Ji Well-Known Member
    New Jersey
    2025 TRD OR - Hybrid Bronze-Oxide, Premium PKG.
    Wait. On the temp dial it reads auto but the green led light indicator is not on. Is the AC still running? When I turn off the fan then the temperature data is off completely.
  3. Apr 27, 2025 at 6:04 AM
    baron55
    Yes, in the Auto Mode the AC will run. The green indicator is to let you know you manually (switch position) tuned it on. In auto, the green indicator will not illuminate.
    Taco Ji[QUOTED] likes this.
  4. Apr 27, 2025 at 7:40 AM
    Taco Ji
    New Jersey
    Thank you because the manual is confusing me.
  5. Apr 27, 2025 at 8:18 AM
    baron55
    No, that is just talking about the temperature control in manual mode. The temp control always works regardless of Manual or Auto modes.
    In auto mode, the AC system is commanded to run.
    Read page 645, it shows the setting to determine where the AC runs in auto mode or not. It's enabled on by default
