Random diagnostic codes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rat_Bastard, Nov 7, 2022.
  1. Nov 7, 2022 at 7:04 PM
    Rat_Bastard
    Rat_Bastard [OP] Well-Known Member
    Brian
    Tucson AZ
    2016 OR
    My '16 has been throwing various codes which continues to get worse. Initially, it started with the crankshaft position sensor "A". I replaced the sensor and then received the same sensor code plus:
    multiple cylinder misfire
    cylinder 2 misfire
    cylinder 4 misfire
    Today I changed the sparkplugs which were due to be changed and now getting:
    Intake Air Temperature Circuit High input
    Mass or Volume Airflow Circuit Low Input
    Ex Cam Angle Sensor Signal High
    Camshaft Position sensor "B" circuit High Input (Bank 2)
    Crankshaft position sensor "A" Circuit high input
    Random/Multiple Cylinder Misfire Detected
    Cylinder 2 misfire
    Cylinder 4 misfire
    I'm wondering if this could be the coils as I did not change them yet. Or is it time to just have the dealership have a look?
  2. Nov 7, 2022 at 7:09 PM
    bigoldbeef
    bigoldbeef Well-Known Member
    18 DCSB OR MT, 22 DCSB OR AUTO
    Sorry to hear about your issues. Sounds like it might be more electrical related vs hardware related? ECU or wiring damage? I've got almost 300k on my stock coils.
    Rat_Bastard[OP] likes this.
  3. Nov 7, 2022 at 8:14 PM
    Rat_Bastard
    Brian
    Tucson AZ
    2016 OR
    Yeah, you're probably right. It definitely seems electrical related. Which makes it a pain to troubleshoot.
