Random Driveline Vibrations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaWilly, Jan 13, 2020.
  1. Jan 13, 2020 at 6:43 AM
    TacomaWilly
    TacomaWilly [OP] Well-Known Member
    I was getting some vibrations at 55+ mph so I decided to replace the Center Support/Carrier Bearing on my 06 DCLB Tacoma. Went for a test drive and it rode really smooth. Now 2 days later the vibes are back and seem to be a bit worse but they are intermittent. I'm scratching my head wondering what the heck is going on. The flange bolts on the drive shaft and the bolts on the carrier bearing are good and tight and the U-Joints are all in great shape. I'd like to hear your thoughts guys.
    Thanks,
  2. Jan 13, 2020 at 7:03 AM
    Ricardowelch
    Ricardowelch Member
    Here is the link for your reference. Hopefully it can help you to solve this issue.
    https://www.tacomaworld.com/threads/drive-shaft-vibrations-solved-step-by-step.244535/
    DG92071 likes this.
  3. Jan 13, 2020 at 7:20 AM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    I would go back and double check your u bolts. If they are original they need to be replaced.
  4. Jan 13, 2020 at 7:22 AM
    TacomaWilly
    The U Bolts on my axle/leaf springs?
  5. Jan 13, 2020 at 7:23 AM
    ryfox0276
    Montana
    2013 RC 4x4
    Sorry I meant u joints. The ones in my 2013 were toast after 100k miles.
  6. Jan 13, 2020 at 7:30 AM
    TacomaWilly
    They seemed fine to me, I had them replaced back in the spring, or 5K miles ago. The strange thing is these vibes don't occur until after I drive 5-10km when everything is warmed up and then it comes and goes. Also no lift, it's all stock.
