Random engine misfire? On a 2018 Trd sport
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacofanboy8, Feb 26, 2024.
  1. Feb 26, 2024 at 8:04 AM
    tacofanboy8
    tacofanboy8 [OP] Active Member
    Alex
    2018 Tacoma TRD Sport - Cement
    none
    Hi all,
    I had a random engine misfire ( I suspect) yesterday. I have a 2018 Trd sport with 77k on the odometer. I’m meticulous with maintenance and got an oil change about 2500 miles ago. Was driving really smoothly and suddenly the check engine light started flashing and the engine starting vibrating/chugging. I lost ability to accelerate and had to pull off the side of the road to get towed. It will be looked at by the dealership but was wondering if there’s any advice/ information people have if this is common? I find it really odd for a Toyota, online research points towards spark plugs? Thanks in advance for your help. It doesn’t seem covered by warranty but waiting to ask about that
    Superdave1.0 likes this.
  2. Feb 26, 2024 at 8:24 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Any idea what trouble codes were set?
  3. Feb 26, 2024 at 8:31 AM
    tacofanboy8
    Alex
    none
    Don’t know yet, I didn’t hook up my OBD port. I’m swinging by the dealership to get some stuff out and will update on the codes I get back. Thanks!
    0xDEADBEEF likes this.
  4. Feb 26, 2024 at 8:37 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Can't really do much to help until you find out the codes.
  5. Feb 27, 2024 at 10:42 AM
    tacofanboy8
    Alex
    none
    here's the update so far... Before I got a chance to look at the codes they took it in for diagnosis. They initially thought it would be time to just replace the spark plugs so the tech did that and still got cylinder 2 misfiring. He then swapped ignition coils and still got a misfiring code. they said it could be corrosion on the wiring and requires another hour of diagnosing to look into it further. I have looked into some other forum posts but it seems like corrosion occurs mostly with off-roading which I haven't done. We'll see what they come back with, I have looked into the warranty and they are unsure if something further upstream would be covered. Has anyone else faced this issue (I know anything can happen with cars)? Apologies if I'm not communicating their message well, I'm trying to do as much research as possible on my end
  6. Feb 27, 2024 at 11:05 AM
    turbosnail
    turbosnail Well-Known Member
    Pa
    18 dbl cab sr5 v6 4x4 , 1985 turbo sr5 pick up
    Did they tell you which code number it was actually displaying ?
  7. Feb 27, 2024 at 11:45 AM
    tacofanboy8
    Alex
    none
    okay I have an update here, I asked for the specific code and they are saying it is a T030200 code and they have recommended a replacement of the ECM, praying it is covered under warranty
  8. Feb 27, 2024 at 12:03 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Do you mean P030200? Did they check the compression on #2?
  9. Feb 27, 2024 at 12:13 PM
    tacofanboy8
    Alex
    none
    I just heard from the dealership and they verified that they did check the compression, as well as any leaks around valve units and wiring. Luckily it seems like this is covered under the Emissions 80k warranty. Thanks all, much appreciate it. Thankful for the forum and community of folks always willing to help.
    Junkhead likes this.
  10. Feb 27, 2024 at 12:15 PM
    turbosnail
    Pa
    Did they determine what the problem is ?
  11. Feb 27, 2024 at 12:16 PM
    tacofanboy8
    Alex
    none
    Ah yes, forgot that vital part of the post. They said the ECM needs to be replaced
    Steves104x4 likes this.
  12. Feb 27, 2024 at 12:17 PM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    2025 Tundra Crew Max
    Doesn't sound like they are doing shit for diagnosis. They are just firing the parts cannon at it.
    drizzoh, dangeroso, Junkhead and 2 others like this.
  13. Feb 27, 2024 at 12:20 PM
    turbosnail
    Pa
    Please let us know how this works out , hopefully you are back on the road quickly and their diagnosis is correct
  14. Feb 27, 2024 at 12:23 PM
    tacofanboy8
    Alex
    none
    will keep you all updated, should be back on the road soon but hoping this isn't a deeper issue they did not properly find. Thanks again
  15. Feb 27, 2024 at 12:29 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I would also check for loose spark plugs. Many on TW have reported loose plugs from the factory.
  16. Feb 28, 2024 at 2:22 PM
    tacofanboy8
    Alex
    none
    Another update, after replacing the ECM sure enough it did not solve the problem. It is now getting looked at by a second master technician at Toyota so we shall see. They have checked compression, replaced spark plugs, checked for leaks and checked coils. Really curious what they come back with
  17. Feb 28, 2024 at 2:44 PM
    turbosnail
    Pa
    Keep us in the loop, the fact that it has good compression and passed a leak down test is good news
  18. Feb 28, 2024 at 3:25 PM
    TA2016
    Oregon
    Since all of the above checked out okay, you might ask the second tech about the #2 injector or the injector circuit.
    turbosnail likes this.
  19. Feb 29, 2024 at 3:06 PM
    turbosnail
    Pa
    Any updates from dealer on your misfire today ?
  20. Mar 1, 2024 at 10:01 AM
    tacofanboy8
    Alex
    none
    Just called for an update...i got told it needs a new engine. I'm talking to the service rep and she is getting more details from the tech. She is calling Toyota to see if it will be covered, I'm hoping it will be. Honestly super disappointed, I know these things happen sometimes but I got a Taco hoping anything but the engine would give me trouble. Did I get a lemon?
    Also heard it is a short block rather than a long block so its gonna be a piece of work to be put back together
