Random engine misfire? On a 2018 Trd sport
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacofanboy8, Feb 26, 2024.
  1. Mar 1, 2024 at 10:09 AM
    19992021Taco
    19992021Taco Well-Known Member
    1999 and 2021 Tacoma
    A new engine? WTF... Did they check the injectors?
    asuchemist likes this.
  2. Mar 1, 2024 at 10:13 AM
    tacofanboy8
    tacofanboy8 [OP] Active Member
    Alex
    2018 Tacoma TRD Sport - Cement
    none
    Exactly, I'm dumbfounded. Apparently it has been checked by 2 Toyota master technicians..they say all things have been checked at this point.....I have not had a single thing go wrong with this truck before hand
  3. Mar 1, 2024 at 10:26 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Highly unlikely with you milage
  4. Mar 1, 2024 at 10:27 AM
    tacofanboy8
    Alex
    none
    I bought it at 50k miles with a CPO warranty so maybe there is hope. But I'm incredibly dissapointed
    Junkhead and Steves104x4 like this.
  5. Mar 1, 2024 at 10:34 AM
    Vlady
    Issy, WA
    Thats better. Make sure read the warranty for coverage and make sure they give you what exactly failed.
  6. Mar 1, 2024 at 10:36 AM
    tacofanboy8
    Alex
    none
    Will do, thanks for the advice, much appreciated
  7. Mar 1, 2024 at 10:43 AM
    turbosnail
    turbosnail Well-Known Member
    Pa
    18 dbl cab sr5 v6 4x4 , 1985 turbo sr5 pick up
    Did they tell you what actually failed in the engine ?
  8. Mar 1, 2024 at 10:46 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    That’s nice.
    khax likes this.
  9. Mar 1, 2024 at 10:50 AM
    Eddie1958
    Eddie1958 Well-Known Member
    ED
    I feel for you OP. Hope it works out for you. I hope you didn't hit what I call the un lottery. We don't know how the engine was operated or maintained the first 50,000 correct.
  10. Mar 1, 2024 at 10:54 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I would be too dude, extremely disappointed.
    Good luck!
  11. Mar 1, 2024 at 10:54 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    You need someone better at diagnosing problems to be working on your truck than who currently is.
  12. Mar 1, 2024 at 11:11 AM
    turbosnail
    Pa
    I’m having trouble understanding how the truck passed a compression test and a leak down test but needs a whole new engine
    asuchemist, khax, Gfenza89 and 7 others like this.
  13. Mar 1, 2024 at 12:46 PM
    tacofanboy8
    Alex
    none
    Hi folks thanks for all the help you provided. I asked the dealership to send me the mechanic notes and here is what they found. Scoring on the inside of cylinders, they said it needs a new engine for sure BUT after speaking with Toyota, Toyota wants a precise point of failure for the engine which the dealership said would take up to 14 hours of labor at a little under 3k for labor. If the point of failure is found then they send pictures to Toyota and MAYBE they will cover it (engine) and cover the 14 hours of labor. If there's any insight please let me know. They are waiting for my authorization, this feels like playing roulette with 5k which I'm not in the position to do. Any advice or should I just tap out of this car? Thanks allIMG_3786.jpg
  14. Mar 1, 2024 at 12:54 PM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    I would take it somewhere for a second opinion before giving them any more money. Definitely before ripping the engine out.
    Based on your description of their diagnosis, they're just shotgunning stuff. They might have landed at new engine simply because that's easier for them than finding out exactly what's wrong.
    To them, you are a captive customer, since you dropped the truck off with them and can't easily take it away at this time. Not saying they are trying to fleece you, but it would be all too easy to do so.
    drizzoh and HondaGM like this.
  15. Mar 1, 2024 at 12:55 PM
    #35
    turbosnail
    Pa
    They told you a couple days ago that compression was good and leak down test was good , but tech wrote on the back of the RO that compression was low on cyl 2 , did they change their story
    HondaGM and Jakerou like this.
  16. Mar 1, 2024 at 1:04 PM
    #36
    tacofanboy8
    Alex
    none
    I think there was a miscommunication between the service rep and the tech notes which is why I asked her for them. seems like the cylinder did not pass compression after all
    HondaGM and Steves104x4 like this.
  17. Mar 1, 2024 at 1:09 PM
    #37
    turbosnail
    Pa
    Certainly not feeling confident in this service dept . A second opinion may be in your best interest
    HondaGM likes this.
  18. Mar 1, 2024 at 1:32 PM
    #38
    Vlady
    Issy, WA
    Ask them to give you some ideas what causes the scoring? Remember, if the failure happened outside of the "engine" and cause the engine damage, it won't be covered.
    Blown oil cooler won't covered damages to the engine. If something broke inside the intake and got sucked in to the cylinder, won't be covered.
    Hard to advise. Probably do the math to see if you are willing to gamble with the warranty
    HondaGM and turbosnail like this.
  19. Mar 1, 2024 at 2:09 PM
    #39
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Ah that really sucks. Don't envy your current position. Hard to know when to cut your losses in these situations. Used engine may be your best bet moving forward? Hope it works out in your favor in the end.
    Junkhead and HondaGM like this.
  20. Mar 1, 2024 at 2:39 PM
    #40
    tacofanboy8
    Alex
    none
    Thanks all, just spoke to Toyota Corporate. Corporate can't promise me anything but they are higher in command than the rep the dealership has been speaking to. Called since this position of playing maybe with 3 thousand dollars seems like BS. They are calling the dealership to see if anything can be done. I did get clarity that I have the 7year/100,000 powertrain warranty, fingers crossed it applies and corporate can cover the lab that needs to be done to find the point of failure.
    Junkhead, turbosnail and Eddie1958 like this.
