Random Issues 2009 Tacoma Double Cab after new stereo installed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ryangriffin88, Jan 25, 2016.
  1. Jan 25, 2016 at 7:15 PM
    ryangriffin88
    ryangriffin88 [OP] Well-Known Member
    Brevard, NC
    2009 TRD Sport 4x4 DCSB
    3" Toy-Tec lift, Bilstein 5100 shocks, Banks Monster Exhauat, K&N Cold Air Intake, AFE Throttle Body Spacer, Tinted windows, Black Billet Grille, Black Headlights, 8000K HID Head/Fog Lights, Black Tail Lights, Black LED Third Brake Light, LED license plate lights, LED reverse lights, LED parking lights, LED interior lights, Toyota Bed Mat, 3" Oval Nerf Bars
    Recently had a new stereo system put in my 09 Tacoma Double Cab TRD Sport, I have noticed that when the door is opened and key is in ignition there is no chime alarm, also have noticed when the door is open it will lock the door while still opened, the headlights on chime alarm does not seem to go off anymore either, half the time when I open my door (even with it set to door mode) the main interior light will not come on, any ideas on what needs fixed?
  2. Jan 25, 2016 at 7:36 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  3. Jan 25, 2016 at 7:59 PM
    ryangriffin88
    Brevard, NC
    Is there a reason you linked where I posted this in another forum?
  4. Jan 25, 2016 at 8:37 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The door switch is stuck. remove it and test it or replace it.
    It has nothing to do with the stereo installation.
    surforegon likes this.
  5. Jan 25, 2016 at 8:42 PM
    ryangriffin88
    Brevard, NC
    Any info on how to test it and or replace it?
  6. Jan 25, 2016 at 9:00 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Use a multimeter... It is a normally open switch. Unplugged from the circuit and not depressed the switch should read infinite resistance, when you depress the switch it should read very near zero resistance.
    Yours may simply be stuck in the pressed in state.
  7. Jan 25, 2016 at 9:05 PM
    ryangriffin88
    Brevard, NC
    Ok thanks
