Random knock in frontend after lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by riot4wyatt, Apr 16, 2025.
  1. Apr 16, 2025 at 7:07 PM
    riot4wyatt
    riot4wyatt [OP] Well-Known Member
    Travis
    Port Allegany, Pa
    '14 TRD off road spruce mica
    Bilstein 6112/5100 1.5" icon aal Dometic cfx40 fridge
    I installed Bilstein 6112/5100 combo and icon 3 leaf aal a week ago and now I am getting a random knock in my front end. Doesn't matter if your on the brakes, off the brakes, cruising, turning, etc.... Completely random. Changes cv shaft, wheel bearing, brake caliper, removed sway bar and it's still there. PLEASE HELP!!!
    HondaGM likes this.
  2. Apr 16, 2025 at 7:09 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Got a Video of the noise…
  3. Apr 16, 2025 at 7:16 PM
    riot4wyatt
    Travis
    Port Allegany, Pa
    I don't. Like I said, I can't make it make the noise and you can feel it in the truck when it does it.
    HondaGM likes this.
  4. Apr 16, 2025 at 7:22 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    LCA hardware torqued to spec?
  5. Apr 16, 2025 at 7:24 PM
    riot4wyatt
    Travis
    Port Allegany, Pa
    Yes sir. Checked it again tonight and everything is to spec. Idk if one of the ball joints could be causing it?? Didn't do this until I installed the lift...
