Random long cranks after fuel filter change - 5vz
Discussion in '1st Gen. Tacomas (1995-2004)' started by MoonCrawler, Aug 14, 2014.
  1. Aug 14, 2014 at 9:33 PM
    MoonCrawler
    MoonCrawler [OP] Well-Known Member
    Sacramento, CA
    2003 Tacoma V6 4x4 TRD
    I've owned the truck about 2 months, with no crank issues up until now. It's a 5vz. About a week ago I changed the fuel filter, using an OEM filter. Everything went fine.
    BUT, twice this week I've come to my truck after it has sat for a few hours and experienced a long crank, followed by a weak start. After it catches, I can shut it off an start it no problem. As of now, it's a random thing.
    Has this happened to anyone else? Any ideas about what to check out? It's running fine, just these random long cranks.
  2. Aug 15, 2014 at 4:41 AM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    Have you checked your connections at the new fuel filter for leaks? If it's leaking it will cause weak fuel pressure up to the engine.
  3. Aug 15, 2014 at 11:05 AM
    MoonCrawler
    Sacramento, CA
    Yeah, I've checked it a few times and they were dry. But maybe I need to check all day today, right after I shut the car off. Could be that every time I've looked, the gas has already evaporated.
  4. Aug 15, 2014 at 1:18 PM
    Logger
    Logger out for a rip are ya bud?
    Sam
    '13 TRD OR Double Cab
    Sounds like a old / weak battery and not a fuel issue. If that filter was leaking even a little you would smell it. Probably a coincidence, but who knows.
  5. Aug 15, 2014 at 1:31 PM
    vtrguy
    vtrguy Well-Known Member
    Jarrod
    Chico
    '01 Taco TRD xCab SR5
    Deckplate, Full OME kit, Snugtop Camper, Camry ignition ring, TRD Catback
    What does your engine temp look like on restart?
    I know you said a few hours and you're in oakland, so it shouldn't be too hot...
    The pump only primes when the engine is turning and I have hot start issues due to a slowly failing pump. There's a thread hiding somewhere on here where OP worked through the entire ignition/fuel system and only saw an improvement when replacing the pump.
  6. Aug 16, 2014 at 6:00 PM
    tacotundra
    tacotundra Well-Known Member
    Did you put the filter on correctly? in has a flow arrow on it sounds like you have it backwards...
  7. Aug 16, 2014 at 8:49 PM
    MoonCrawler
    Sacramento, CA
    I too am thinking it might be some coincidence. Maybe even the relay that I pulled to do the work is crapping out. It's just hard to diagnose since it's very random now.
  8. Aug 16, 2014 at 8:50 PM
    MoonCrawler
    Sacramento, CA
    Yeah, the filter is on the right way. If it wasn't, I'm sure I'd have more problems than a very intermittent long crank.
  9. Aug 16, 2014 at 8:58 PM
    Bpassmore8
    Bpassmore8 Brian13DCSB
    Brian
    Vacaville, CA
    2013 Super White TRD Sport
    Debadged, N-Fab step bars, LED cup holder lights, LED dome and map lights, TRD stickers, HID retrofit (Morimoto Mini H1 6.0, BHLM, HomerTaco ghost raptor grill, OME 885s with 90021 up front, 60091 in the rear with trim spacer
    my last tacoma was a 2003 2.7L so i know it isn't the same but I had that for the 7 years I had the truck but less frequent. maybe once every other month but it never needed a battery or jump and always started without fail.
