Random Misfire Problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cody89, Aug 27, 2022.
  1. Aug 27, 2022 at 7:44 AM
    Cody89
    Cody89 [OP] Member
    Cody
    2006 4.0L V6 2wd Tacoma
    Hey everyone, new to the forum and looking for some help. I’m not very mechanically inclined so most things beyond maintenance and upkeep are beyond me. I have a 2006 4.0L V6 2wd Tacoma. It’s throwing up a P0300 Random Misfire code. When you crank it up it shakes, sputters from the tailpipe, & acts like it’s about to stall out. Turn it off and crank it up again immediately and it’s fine idling, but once you get to 30 mph it starts vibrating. Also it only vibrates when pressing the accelerator. Take your foot off the gas and the vibration stops. I’m pretty lost as to the cause. I put 6 new NGK spark plugs in it last year and last week I put 6 new NGK coil packs in but the problem persists. Anyone else ever have this problem or any idea as to the cause then solution? Thankful for any input.
  2. Aug 28, 2022 at 10:47 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    The closest symptoms I experienced to this was a plugged catalytic converter but I think you would see more codes than the one. A bad head gasket also fits the symptoms. Check the obvious signs - milky oil, exhaust smell in coolant, white smoke from exhaust, etc …
  3. Aug 28, 2022 at 3:50 PM
    Cody89
    Cody89 [OP] Member
    Cody
    Thanks I’ll check it all out
  4. Aug 28, 2022 at 4:00 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Have you replaced the valve cover and spark plug tube gaskets? Pop a coil out and see if the tip is dry or covered in oil
  5. Aug 29, 2022 at 7:57 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    2006?
    MAF, fuel pump???
    The mass air flow, you can purchase cleaners at any auto store.
    Fuel pump/filter you'll have to drop the tank to check. I haven't had the opportunity to work on the fuel system of mine so I'm not sure if there's a place to temporarily plug a fuel pressure gauge in the line to check fuel pressure.
  6. Aug 29, 2022 at 9:16 AM
    Cody89
    Cody89 [OP] Member
    Cody
    Haven’t replaced a valve cover or tube gasket. Was thinking about dropping the tank and installing a new fuel pump and filter and see if that does anything next.
  7. Aug 29, 2022 at 9:22 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It would be cheaper to let a mechanic trouble shoot the issue instead of throwing more parts at it
    At least check the fuel pressure before condemning the pump
    Big Red 2nd Gen, Dm93 and Steves104x4 like this.
  8. Aug 29, 2022 at 9:28 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    I’m sticking with the tube gaskets
  9. Oct 4, 2022 at 5:10 PM
    Cody89
    Cody89 [OP] Member
    Cody
    Turned out to be a big vacuum leak. Found out right before I dropped the tank.
    Steves104x4 likes this.
