Random oil leak???
Discussion in '1st Gen. Tacomas (1995-2004)' started by Oscar08, Apr 11, 2014.
  1. Apr 11, 2014 at 2:02 PM
    Oscar08
    Oscar08 [OP] Active Member
    Bill
    Virginia
    03 Xtra Cab 4x4
    Hello all,
    So the other day while getting off of work I noticed a decent sized oil puddle under my truck looking like it was coming from somewhere above the skid plate.
    Then when I got home I noticed in my usual parking spot there was a larger oil stain (about the size of a large dinner plate). I then went to check my dipstick and it was bone dry. So I went over to Auto Zone and bought 5 quarts of 5W-30 and put the entire thing in there before it registered on my dipstick.
    The last oil change was about 2-3 months ago. I spent the last 7 out of country so my roommate drove it to work about once a week for me.
    The engine is making no odd noises, and it starts and runs fine. The antifreeze is clear. I'm not the most mechanically inclined so I was wondering if anybody has some ideas? Maybe the oil pan gasket?
    Also, since I put oil back in it it hasn't leaked any more yet. I figured if there was an active leak it would be a continuous issue?
  2. Apr 11, 2014 at 2:15 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Take the skid plates off (and whatever else is under there).... Crawl under the truck and do some inspecting. Get some paper towels and degreaser and clean the areas that you see oil. Then.....continue to watch for new oil drippings so you can narrow down the location.
    It could be the oil pan gasket....although, there really isn't a gasket. It's RTV type material. You could try and 'torque' the bolts to see if that helps.
  3. Apr 11, 2014 at 2:16 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    oil filter tight?
  4. Apr 11, 2014 at 2:23 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    If it is the 3.4 v6 they are notorious for leaking on the valve covers. Seems the passenger side at the back always leaks the most. Mine leaks and gradually seeps down the side of the motor.
  5. Apr 11, 2014 at 3:54 PM
    Exhaust
    Exhaust Well-Known Member
    Erik
    Wharton State Forest
    02 DC TRD
    Extended breather, Grey Wire mod, Tundra brakes, Rockford-Fosgate sound, General Spring HDs, 5100s + 880s, Heated Seats, TRD Supercharger, 2.1 Pulley, URD 7th Kit
    +1 on the valve cover gasket. I've owned three of these engines (T100, Taco, 4Runner) and they have all leaked from the VCG.
    Is this the first you've driven it since you've been back? If not, that's a lot of oil to lose in a short amount of time. I don't think a valve cover would leak that profusely.
  6. Apr 11, 2014 at 7:17 PM
    Huntn57
    Huntn57 Well-Known Member
    Justin
    VA
    1995 Toyota Tacoma
    i com 2300 ham radio. for hunting (170 k miles) list of replacements since 166k miles: 4wd solenoid tailpipe muffer catalitytic conver exhaust manifold
    make sure the oil filter is tight. the old gasket from the old filter might be on there. and check the plug where the oil drains out for an oil change. it right beside the skid plate
