Random Passenger Floorboard Leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by Oscar08, Sep 10, 2014.
  1. Sep 10, 2014 at 11:20 AM
    Oscar08
    Oscar08 [OP] Active Member
    Bill
    Virginia
    03 Xtra Cab 4x4
    Good afternoon all.
    About two weeks ago when I took my truck to the carwash, I pulled up my floor mats and on the underside of the passenger floor mat it was completely soaked. It hadn't rained for quite some time and I hadn't yet gone through the carwash.
    Since then I have left the floor mat off on the side and water is continuing to soak through. It is right in the middle and has no apparent source on the inside of the cab. Any ideas?
  2. Sep 10, 2014 at 3:01 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    You have AC right? I'll bet the drain hose has separated from the box. look at the very front of the passenger area, and pull back the carpet a but and look up at the floorboard. If there is no hose going thru that hole, there it is.
    (Or it's Clogged )
  3. Sep 10, 2014 at 6:37 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Check any grommets on the firewall inside the engine bay to see if any have popped loose. Mine did this on the driver side when routing some wires.
  4. Sep 16, 2014 at 10:46 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    Well?
  5. Sep 16, 2014 at 12:09 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Are you loosing coolant? Your heater core may be leaking.
