random problem starting second time goes fine.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by doons, Dec 15, 2011.
  1. Dec 15, 2011 at 8:42 AM
    doons
    doons [OP] Active Member
    KANADIA
    2011 V6 4X4
    :confused:so every now and then my truck will have a problem starting first try no matter temp and then when i try the second time fires okay a little slow idle then rpms go to normal. i have 91 fuel in it and have tried gas anti freeze and fuel injector cleaner but it never makes a diff. my neighbour heard it this morning and said it could be a glitch in the comp not to worry. i took it to the dealer and they couldnt duplicate the problem
    Specs: 2011 tacoma 4x4
    nothing after market
    temp outside was 38f
    fuel 91
    any sugestions
  2. Dec 15, 2011 at 9:31 AM
    Xshark
    Xshark Well-Known Member
    Michael
    Rogers, AR
    08 Taco
    Icon progressive leaf, 3-leaf pack. Bilstein 5100's on all corners, front set at 2.5" Spidertrax wheel spacers Satoshi Grille Mod
    Fuel pump?
    Try leaving the key in the 'on' position for a few extra seconds before cranking. Maybe that will allow some fuel to reach the engine.
  3. Dec 15, 2011 at 12:09 PM
    JimT
    JimT Active Member
    Jim
    Indiana
    2016 DCLB TRD Offroad
    I have something similar with my '08. Sometimes it will turn over repeatedly and not start, then I try the second time and it takes off. It's been doing this for a few years, so I don't think it's a sign of eminent failure.
