Random Problems Starting 2000 Tacoma 2.7
Discussion in '1st Gen. Tacomas (1995-2004)' started by Asixstringnut, Apr 10, 2023.
  1. Apr 10, 2023 at 4:15 AM
    Asixstringnut
    Asixstringnut [OP] Member
    Robert
    2000 Tacoma 2.7 4wd manual
    Hi all! New member here looking for answers to my problems with my 2000 Tacoma 2.7 4wd manual transmission!
    I have been having problems starting my truck on some mornings. It will crank, and it will crank, and it will crank but won't start and I will get popping noises when it is trying to start!
    This doesn't happen every day and it doesn't seem to be related to weather.
    I have already change the fuel filter, and what a pain that was!
    I haven't taken it to a mechanic because I can't get it to reproduce the problem once it starts!
    Once it starts after lots of cranking, it runs a little rough for a couple of minutes, and then smooth right out and has normal power.
    Is there a check valve in the fuel pump that could be leaking down?
    I have had to use starting spray a couple of times to get it to start.
    Any and all help would be greatly appreciated
    Robert
  2. Apr 10, 2023 at 12:39 PM
    Asixstringnut
    Robert
    Is this the right place to be posting on here? I am a newbie!
    Thanks
