Random question - any how-to's on removing the "GoPro" mount from windshield?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ChaseUA, Dec 5, 2016.
  1. Dec 7, 2016 at 10:56 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Yep, I stumbled on a deal for a gopro clone that has a dashcam mode and easily mounted to that spot. Not as great as a purpose-built dashcam but 1080p recording that starts automatically with the truck for $35 works fine for me for now. :)
  2. Apr 16, 2018 at 3:06 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Every time my wife gets in my truck she says I need to take that stupid GoPro thing off.. I don't see it as a driver. She says it looks cheesy, I do agree, I wish it was a port add-on that could be excluded instead of just coming on it.
    Anyone taken it off successfully? I don't want to break the windshield. Or have it look like something was removed.
  3. Apr 16, 2018 at 3:10 PM
    plode682
    plode682 Well-Known Member
    Southern NJ
    2016 Tacoma TRD Off Road
    I took mine off. It was in the way of installing my visor lights(for the fire department). Like others said, worked the razor blade up there and just slowly got it to peel off. I put go pro mount on the bottom of the light bar so I could still use it.
  4. Apr 16, 2018 at 3:13 PM
    toyotatacomaTRD
    Was yours just attached to the glass? Or did it have the black piece they're mounting it to in the 18s? I'm thinking the razor blade on the black piece will scratch..
  5. Apr 16, 2018 at 4:19 PM
    plode682
    Southern NJ
    There is like a black coating on the windshield where it mounts. I left that. It did not scratch. I just needed the mount gone as it would hit the light, but that spot isn't where the LED's on my light shine through the windshield.
  6. Apr 16, 2018 at 4:21 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Yeah . . . You need a new wife.
    G.
    DA3 and Taka The Tacoma like this.
  7. Apr 16, 2018 at 4:26 PM
    Fortunt1
    Fortunt1 Well-Known Member
    Thomas
    Iowa
    16' SRT Charger...purple
    I’d probably just get a magnet attachment and put a magnet on there that says “because fuck you”..may be a little much for you tho :notsure:
  8. Apr 16, 2018 at 5:22 PM
    bamajoey
    bamajoey Well-Known Member
    Pensacola Florida
    2018 red Tacoma SR5 double cab
    None
    I used the tool supplied with my Street Guardian to pry up the edge on one side. Slid tooth picks under it. Next day, pried it a little more until I could just pull it off. Then mounted the Street Guardian it its place. No big deal.
  9. May 11, 2018 at 11:47 PM
    SparkyEng
    SparkyEng New Member
    Dick
    Redmond, Oregon
    18 TRD PRO
    Woohoo! Door Sill Protectors!
    I also removed mine off my TRD Pro because I chose to put a dash cam in its place. I could not find an adapter solution that would allow the dash cam to fit in the GoPro slot. I used a plastic putty knife to pry up and remove the mount, a credit card to scrape off most of the residue, then Goof Off and my finger nails to remove the rest. I got 99% of it off and it was not as easy as I would have liked. It probably took my an hour and a half but it will be worth it to have the dash cam occupying that spot.
    ccotner112 likes this.
