Random question - How long do you allow a lift to settle before...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ChaseUA, Mar 2, 2017.
  1. Mar 2, 2017 at 7:12 PM
    ChaseUA
    ChaseUA [OP] Well-Known Member
    Chase
    Bama
    Present: 2016 White TRD Sport DC Past: 2010 MGM TRD Sport AC 4x4
    having an alignment done on your truck?
    I ordered an Icon shage 3 kit for my 2016 and it should be delivered in the next 2-3 weeks. The install instructions state to allow the new components to settle and then have an alignment done on the truck but the guy that's helping me with the install as well as the local stealership both recommended I do it at the time/immediately after the install.
    What is the consensus? Why would the install instructions state to allow it to "settle"?
    ChadsPride likes this.
  2. Mar 2, 2017 at 7:17 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Install the lift, get an alignment, drive a couple hundred miles and get another alignment after it settles. Firestone has lifetime alignments.
    ChadsPride and 12TRDTacoma like this.
  3. Mar 2, 2017 at 7:18 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    I say an alignment should be in store within a matter of days. After my "level", I got an alignment the very next day. Let's just say that the less miles traveled is better considering it won't produce as much uneven wear on the tires. I drive 30+ miles a day, so I got the alignment as soon as possible. I wouldn't go over 50 miles without an alignment just to play it safe.
  4. Mar 2, 2017 at 10:16 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Yep, I agree with the two above posts. Find a shop that has free tire rotate, balance and lifetime alignment, and have all three done every 5k. You'd be surprised how many more miles you get out of your tires.
  5. Mar 2, 2017 at 10:19 PM
    Bishop84
    Bishop84 Well-Known Member
    100% get an alignment done immediately, suspensions settle but you cannot drive with the toe out wildly. Get it checked again later on after some good miles. Alignments should be routine on Tacomas.
    GPsevinSixx and smitty99 like this.
  6. Mar 2, 2017 at 10:23 PM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    I just drove on rough gravel roads after to settle it prior to the alignment
  7. Mar 3, 2017 at 6:47 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    ASAP after lift... usually takes a few days. The installer should be able to get things "close" at least to drive for a few days.
  8. Mar 3, 2017 at 7:00 AM
    ZachPrerunner
    Southeast TN
    I honestly think it depends on the shop. Some Firestones couldn't care less about the lift and others are very strict.
    smitty99 and Byb127 like this.
  9. Mar 3, 2017 at 7:47 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Yeah I went to firestone for my other truck, asked them if they'd align it after I had a lift installed and they had no problem, the guy even told me there was a special on their lifetime alignment IIRC it was under $200...maybe $180
    One thing I did not ask is if it is only for that particular vehicle. I assume it is.
    ChadsPride, ZachPrerunner and Byb127 like this.
  10. Mar 3, 2017 at 7:56 AM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Yup, do the initial alignment after the lift install to correct basic suspension geometry that WILL be thrown out of whack.
    After a few hundred miles and the springs, bushings settle in with their new neighbors, you really should do it again as the new settled geometry will be different than initial install. If you off road the truck often, the impacts and extra suspension motion will throw things off sooner, so more frequent alignment checks are a good thing on the Tacos.
  11. Mar 3, 2017 at 7:59 AM
    ZachPrerunner
    Southeast TN
    I had the same experience. They knew the suspension had been modified and had no problem with the lifetime alignment. I believe they quoted me $180 as well. I think a lot of it has to due with customer attitude. If you're polite and respectful, it can go a long way.
  12. Mar 3, 2017 at 8:05 AM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    I agree with the installer and the guy at your dealership. It needs to be aligned immediately after the lift because itll be way off and youll cook your new tires if you dont. You also need to get it aligned after it settles which is a very real thing. It will be out of spec when you return after letting it settle.
    As for how long? Id say 500 miles give or take
  13. Mar 3, 2017 at 8:18 AM
    Clearwater Bill
    Billy
    Largo Florida
    Changes in suspension on our race prepped street cars (and lowered, not raised) got about 20 miles driving intentionally on whoopee surfaces like speed tables, speed bumps, guttered drives, etc. then aligned.
    Properly torqued bushings (with the suspension loaded, not drooped) and springs don't really 'settle' much to speak of. All you are really doing is making sure everything is in position and nothing is bound.
  14. Mar 3, 2017 at 8:22 AM
    smitty99
    Scottsdale
    Interesting because I see a lot of folks report their initial lift dropping a bit after a month or several hundred miles. So if it isn't settling it's just because driving around on it is causing it to change the ride height for some other reason?
  15. Mar 3, 2017 at 10:02 AM
    Clearwater Bill
    Billy
    Largo Florida
    Can only site what I've experienced. I do suspect that leafs may settle (de-arch?) a bit more than coils normally do. Also suspect that coils that are preloaded via perch changes (like 5100s) may fatigue a bit as well.
    If I were lifting, I'd drive it a couple of days to address the initial settling potential, have it aligned and measure it up on a flat level surface. If it remeasures lower over the next weeks/months, have it aligned again.
    I'm in a semi unfortunate position of not liking any of the 'lifetime' alignment shops in my area. The crackerjack guy to go to is pay as you go shop. The good news is I don't really beat up the suspension, so I get away with long interval alignments most of the time.
